Videos won’t playing in the YouTube app on Nintendo 3DS or in browsers? It keeps saying “An error while performing this operation”? This tip will help you fix 3DS YouTube error in 4 easy and quick ways.
“Can anyone help, I have been able to watch videos earlier, but now when I try to watch video, I get ‘An error has occurred while performing this operation’, and I have not touched my 3DS since I got home! It happening on the YouTube app and even on the browser! It even wont let me change anything in the settings of YouTube!”
In recent days, you may meet the same situation as the above user that the YouTube app on your 3DS is stop working. Some of videos still work while most of the newly updated videos don’t. And when you click a video it says: An error occurred while performing this operation.
You may have tried deleting and re-downloading the YouTube app but nothing changed, right? Don’t worry. We are here to help you. In this guide we will share you 4 ways to fix 3DS YouTube error with minimal trouble. Keep on.
Remove the cookies and caches, browsing histories stored in your browsers. In addition, delete system and user logs as well as outdated temp files.
iPhone & Mac: Safari > Bookmarks > History > Clear > Choose how much history you’d like to clear > Clear.
Android: Tools > Data > Tap on the data you’d like to clear > Clear.
Chrome: Settings > Clear Browsing Data > Choose the time > Click the data you want to clear > clear browsing data.
In some cases, the system clock may have changed the time, so you just need to set the correct time as suggested. Aside from that, you have to check your 3DS, browser and Flash Player are in the latest version, if they are not, update them to the latest version. Then close the video tabs and try again, you can have access to the video now.
YouTube usually adjusts the quality of the videos so that users can have a better viewing experience by switching definition. But there’s a problem that if the video was recorded using the standard definition, then it will be unavailable in high definition. In order to solve this problem, you should go to Gear icon to change the quality of the videos. What’s more, you’d better set the preference of default video quality in case you will meet the same problem.
With above ways, you may have fixed 3DS YouTube error. If you have any problem, don’t hesitate to contact us via email or leave your comment below.
