OK, got it
Bypass iCloud Activation Lock iPhone/iPad via 4 Ways
Are you stuck on the Activation Lock screen of your iPhone, iPad, or Macbook? This guide will provide you with proven methods to bypass iCloud Activation Lock, even if you don’t have the Apple ID or password. Whether you’re dealing with an iPhone bypass, iPad bypass, or activation lock removal for other Apple devices, we’ve got you covered.
Author Avatar Joy Taylor Last Updated: Mar. 14, 2025
AnyUnlock – Easiest Way to Bypass iCloud Activation Lock
How to bypass iCloud activation lock safely and easily? Just free download AnyUnlock to bypass iCloud activation lock on iPhone/iPad/iPod touch without Apple ID or password. No skills are needed. Available for Windows & Mac.
What iCloud Activation Lock Is
iCloud Activation Lock is a feature included in Find My iPhone function. Once you enable Find My iPhone on your iDevice, Apple ID, and its password will always be required when others try to turn off Find My iPhone, erase your data, or reactivate and use your iDevice. That’s to say, iCloud Activation Lock is designed to prevent the stuff on your iPhone/iPad/iPod from revealing when it is in the wrong hands.
Common Scenarios:
Bought a second-hand iPhone/iPad with Activation Lock enabled.
Forgot your Apple ID and cannot reset security questions.
Inherited an iPhone/iPad that is locked to the previous owner.
iCloud account issues prevent you from using your device.
Also Read: Activate iPhone/iPad If You Forgot Apple ID and Password >
Bypass iCloud Activation Lock on iPhone/iPad in Clicks [Safe & Easy]
As one of the most popular and professional iCloud activation lock removal tools for iOS devices in 2025, AnyUnlock – iPhone Password Unlocker would be the best solution for your iOS device when it is stuck on the “Activation Lock” screen. As a complete iOS unlocking toolkit, AnyUnlock can easily meet your unlocking demands, no matter whether your iPhone is linked to an unknown Apple ID, you need to remove your Apple ID, or you forget your Apple ID email or password. Using its iCloud Activation Unlocker feature, you can easily bypass iCloud Activation Lock without Apple ID or Apple ID password.
AnyUnlock – Bypass iCloud Activation Lock
  • Bypass iCloud Activation Lock with a few clicks. No technical difficulty.
  • It only takes a few minutes to remove iCloud activation lock.
  • It can help you find your Apple ID in minutes if you forget it.
  • Available to use on Windows and Mac computers.
To bypass the iCloud Activation lock, please free download the AnyUnlock – iCloud Bypass Tool. AnyUnlock is compatible with both Windows PC and Mac. Then just follow the below steps to easily bypass activation lock iPad/iPhone. We provide you with 2 guides since the unlock process for the Windows version is a little different from that for the Mac version. Now, let’s see how to bypass activation lock.
How to Bypass iCloud Activation Lock on Windows PC
Step 1. Free get AnyUnlock – iPhone Password Unlocker installed. Launch the software and you will see the page below and tap on Bypass iCloud Activation Lock.
Click on Start Now to Bypass iCloud Activation Lock
Step 2. Connect your device and click Start Now button.
Connect Your iOS Device to the Computer
Step 3. Then, you need to jailbreak your device to allow AnyUnlock to bypass. Read the jailbreak tutorial to do and click Next once finished.
Jailbreak Your Device
Step 4. Then you can start bypassing after clicking Start Now button.
Bypassing iCloud Activation Lock
Step 5. Wait until the process is finished, and you will get iCloud Activation Lock is bypassed successfully page as below.
iCloud Activation Lock Is Bypassed Successfully
How to Bypass iCloud Activation Lock on Mac
Step 1. Free download AnyUnlock – iCloud Bypass Tool, install and run it on your computer > Choose the Bypass iCloud Activation Lock on the homepage.
Choose Bypass iCloud Activation Lock
Step 2. You need to connect your iOS device to the computer now, and then click on the Start Now button to the next step.
Click on the Start Now to Go On
Step 3. Following the indication on the screen of the Bypass iCloud Activation Lock, you need to confirm your iOS device’s information. Put your iOS device into DFU mode, and then the jailbreaking process will start.
Download the Jailbreaking Tool
Step 4. When the jailbreaking process completes, you can click on Bypass Now to start bypassing iCloud Activation Lock on your device.
Tap on Bypass Now to Start Bypassing
  • Once the iOS device has been jailbroken successfully, some functions will not be available.
  • The jailbreak will disable cell phone call making, cellular data using, FaceTime calls making, iMessage sending, etc.
  • Any reset or upgrade processing will lock this iOS device again.
  • Please DO NOT log into iCloud from the Settings on your iPhone iPad iPod touch or factory reset your device which will lock the device again.
Step 5. All you need to do is just wait for a while. After AnyUnlock finished the bypassing journey, you will see the interface on the screen below. Here you can see the iCloud activation lock was gone away from your iOS device.
How to Bypass Activation Lock Using iCloud
If you can get the necessary details from the person who sold you the second-hand iPhone/iPad, using iCloud to bypass activation lock is the quickest solution. Since the previous user can give you the username and password of the device, here are the detailed steps you can follow to bypass iCloud.
Go to iCloud and Click Find iPhone
1. Go to iCloud.com and sign in with the Apple ID username and password of the locked device, and then click on Find iPhone.
2. Click All Devices when you open iCloud – Find My iPhone.
3. Choose the name and model that you need to bypass to Erase iPhone or Erase iPad Remove from Account.
When the steps are completed, the iPhone/iPad will be deleted from the Apple ID and the Activation Lock should be bypassed.
Further Reading: You may also like this guide How to Factory Reset iPad without Apple ID >
Bypass iCloud Activation Lock on iPhone/iPad via DNS
DNS can also act as an activation lock removal tool to help you bypass iCloud activation lock. But you should note that DNS bypass may be a little complicated and cannot always be successful. Anyway, here is how to bypass activation lock via DNS.
Step 1. Restart your iDevice and choose your country & language > Enter the new DNS server as:
  • USA/North America: 104.154.51.7
  • Europe: 104.155.28.90
  • Asia: 104.155.220.58
  • In the rest of the world: 78.109.17.60
Step 2. Tap back > Connect to your Wi-Fi network > Done > Activation help. Once you logged in, a message will say that you have successfully connected to my server.
Step 3. Tap Menu > Preview the available apps and select the one you can get the details about the previous owner.
Bypass Activation Lock via Apple Business Manager
For some supervised iPhone or iPad, the employees may log into their own Apple ID and enable Find My feature when using the device. However, the employer can be stuck on the iCloud activation lock if the employee leaves without removing the Apple ID and disabling Find My. In this case, organizations using Apple Business Manager (ABM) have access to tools that can disable Activation Lock on supervised devices.
Steps to Request Activation Lock Removal:
1. Log in to Apple Business Manager and go to the Devices section.
2. Use the Search function to locate the device by its serial number and verify its Activation Lock status.
3. Click the ellipsis (•••) next to the device for additional actions.
4. Select Turn Off Activation Lock if the option is available.
– Note: This option is only accessible for devices enrolled in Automated Device Enrollment (ADE).
5. Confirm that Activation Lock is now showing as Off for the device.
Remove MDM or Profile
As macOS devices gain popularity in organizations, it’s essential to ensure Activation Lock is disabled before handing over devices to employees. Mobile Device Manager (MDM) solutions can help streamline this process.
– For MacBooks, the device must be supervised via Apple Business Manager or Apple School Manager to remove Activation Lock using MDM.
– Educational institutions can use Apple School Manager, which functions similarly to ABM for managing devices.
If you feel it difficult to use the Activation Lock bypass code for iPhone/iPad activation lock, AnyUnlock is always a better choice.
How to Remove Activation Lock via Apple Support
Contact Apple Support
Apple Support provides several solutions for removing Activation Lock, depending on the situation and device status:
If you know your Apple ID and password, follow Apple’s official steps to remove the lock.
If you’ve forgotten your Apple ID password, you can recover it using Apple’s recovery process.
If you have proof of purchase, you can submit an Activation Lock support request. The documentation must include the device’s serial number, IMEI, or MEID. Note that the device must be erased to complete the process.
Comparison of Activation Lock Removal Methods
Method Ease of Use Success Rate Requirements Limitations
AnyUnlock – iPhone Password Unlocker ★★★★★ ★★★★★ Requires AnyUnlock software on Windows/Mac Data will be erased; requires jailbreaking the device.
Using iCloud ★★★☆☆ ★★★★☆ Requires Apple ID credentials from the previous owner. Only works if you can access the previous owner’s Apple ID credentials.
DNS Method ★★★☆☆ ★★☆☆☆ Needs access to Wi-Fi and correct DNS server settings. Temporary solution, may not work consistently.
Apple Business Manager (ABM) ★★★★☆ ★★★★★ Device must be enrolled in ABM/ADE. Only available for supervised devices; requires access to ABM account.
Apple Support with Proof of Purchase ★★★★☆ ★★★★☆ Proof of purchase with serial number, IMEI, or MEID. Time-consuming process; may require erasing the device.
Using MDM ★★★★☆ ★★★★★ Device must be supervised via Apple Business Manager or Apple School Manager. Only works for supervised devices.
That is all about how to bypass Activation Lock on iPad/iPhone. Hope you found the three methods useful. And if you wonder about the easiest and fastest way, AnyUnlock must be your best choice. It can help you bypass activation lock iPhone/iPad with simple clicks and steps. And if you need to remove Apple ID or unlock other iOS locks, it can help you as well. So why not free download AnyUnlock now to try it?
FAQs
1. Can you remove iCloud activation lock without password?
Yes, if the previous owner removes the device from their iCloud account. Otherwise, you’ll need to contact Apple Support with proof of purchase.
2. Is it possible to bypass the activation lock?
Yes, it is possible to bypass the activation lock using methods such as contacting Apple Support, using DNS bypass (temporary), or involving the previous owner to remove the device from their account.
3. How do I get past activation lock if I forgot my Apple ID?
If you forgot your Apple ID, you can try recovering it through Apple’s account recovery process at iforgot.apple.com. If recovery is not an option, you may need to provide proof of purchase to Apple Support for assistance.
4. How to remove Activation lock without previous owner for free?
If the previous owner is unavailable, you can contact Apple Support with proof of ownership. Apple may help you remove the activation lock after verifying your ownership.
5. Does factory reset remove Apple ID?
No, a factory reset does not remove the Apple ID associated with the device. The activation lock remains tied to the Apple ID, and you will need the credentials to deactivate it.
