I still have gigabytes of space left on my iCloud storage and iPhone, yet my iPhone still will not backup. This has been going on for weeks and I am beginning to get worried. Is my phone broken? Do I need to repair it?
Free download AnyTrans to fix iPhone won’t back up to iCloud or iTunes. Back up iPhone photos, messages, music and more with the highest success rate.
iCloud provides 5 GB of free space to back up iPhone data. If your iCloud is full, you need to buy more space to back up successfully.
To back up files on iCloud, you should connect to a smooth Wi-Fi and start. Cellular or poor Wi-Fi connection will influence the process of backup.
Sometimes, an unknown iCloud account error can cause iPhone won’t back up to iCloud issue.
Step 1. Go to settings and tap on your profile.
Step 2. Tap on iCloud and check if the storage is used up.
iCloud Storage on iPhone
Step 3. If it is, you can upgrade to iCloud+ to back up your iPhone.
If you have enough iCloud space, check the next method.
A poor Wi-Fi connection will influence both iCloud backup and iOS updates. You can follow the steps to Reset your network connection and back up your iPhone again.
Or you can connect to a different Wi-Fi network and check if your iPhone still won’t back up.
It’s also a good choice to back up your iPhone files on the computer without iCloud or iTunes. AnyTrans will help to back up your iPhone or iPad with ease on your computer. Just one click, all your data can be backed up in seconds. Check the full features of AnyTrans in the following:
AnyTrans is 100% safe software without viruses, just be free to download AnyTrans and follow the steps below to back up your iPhone data easily and quickly.
Step 1. Install and launch AnyTrans on your computer, plug in your iPhone > Click Backup Manager.
Back up iPhone with AnyTrans
Step 2. Click the Back Up Now option > You can change the Backup Path according to your needs.
Change Backup Path
Step 3. AnyTrans will start to create a backup > When it completes, you will see the following interface.
The Backup Completed Page
Steps to Backup iPhone Data Selectively
Step 1. Install and open AnyTrans on your computer > Plug in your iPhone > Choose Device Manager on the main interface > Go to the category management screen and select one category > We choose Photos for example.
Go to Device Manager and Click Photos
Step 2. Select the pictures you want to backup > Click Send to Mac/PC button to download them to the computer, or click Upload to iCloud button to save them to iCloud.
View Albums with AnyTrans
Step 3. On the top of the interface, select the To PC button to initiate the transferring process.
Select Photos and Send to PC
Then your iPhone will be backed up with AnyTrans. There is no worry about data loss
Also Read: How to Backup iPhone to Computer >
An outdated iOS may cause the iPhone won’t back up to iCloud issues. In this case, you can check for system updates and ensure a successful backup in iCloud.
iCloud error may cause backup failure on iPhone. If you have not checked your iCloud status for a long time, you may not know its latest status. To make your iCloud run normally, it’s better to re-sign into the account and back up later.
The above 5 methods have covered all cases that iPhone won’t back up to iCloud. You can try them out and back up your iPhone to iCloud, iTunes or to the computer. Actually, AnyTrans is highly recommended to back up your iPhone in powerful ways. It can also transfer files from iPhone to iPhone. Download AnyTrans now and enjoy smooth backup for iPhone and iPad.
