If your Samsung tablet has got frozen and does not respond to your actions, you may want to find a fix to the issue and get the issue sorted out. There are 6 ways to do it as the post below explains.
While most of the tablets developed by Samsung are stable and usually never cause any issues, there are times when things go wrong and these tablets start to behave abnormally. Just as the above users reported. If your Samsung galaxy tab not responding and gets frozen for no apparent reason, you are in the right place.
Here are Samsung solutions and a system repair tool to help you fix the freezing issue or Samsung Galaxy black screen issue you are currently facing with your tablet. Most of the methods are easy to apply and they get the job done for you.
DroidKit is software that allows users to solve various system problems and freezing issues. Now, download DroidKit to fix Samsung not responding and unfreeze it. Supports all tablets with Android OS 5 to 11.
Further Reading: How to Use Android Recovery Mode and Fix when it Stuck >
When your tablet gets frozen, the first thing you may want to do is force reboot the tablet. What force rebooting your device does is it forcibly shuts down the operating system of your device. When this happens, it gives a brand new start to your device and ensures you do not face the frozen issue on your tablet.
To force reboot your Samsung tablet if device is frozen:
Forcibly reboot the Samsung tablet
If your Samsung tablet gets frozen only once in a while and works great for the rest of the time, you may use the Device Maintenance feature while the tablet works to fix the issue you face. Device Maintenance is a feature located in settings on your tablet. It allows you to optimize your device to ensure there are no errors on it.
The following shows how you can fix the frozen and unresponsive tab:
Use Device Maintenance to resolve the issue
If your tablet won’t turn off either tried the power button, volume button, home button and got the green downloading screen, what can you do is utilize a system repair tool – DroidKit. It is a complete Android solution, which provides you with an excellent Samsung system repairing tool for freezing issues and stuck issues.
No matter your Samsung tablet froze on black screen and won’t turn off, keep freezing, or frozen on downloading screen or startup screen, DroidKit can help you unfreeze and restart your Samsung tablet normally. Besides, DroidKit addresses various issues concerning system errors, including Samsung phone keeps restarting, firmware update error, safe mode won’t turn off or turn on, etc. Check how can DroidKit help you unfreezing your Samsung:
If your tablet frozen won’t turn on or off even bricked, repair Samsung tablet:
Step 1. Download the latest version of DroidKit on your computer and connect your Samsung tablet to it. Launch the program and go to the Fix System Issues mode.
Click Fix System Issues
Step 2. On the “Fix System Issues” interface, connect your Samsung tablet to the computer via a USB digital and hit Start to proceed.
Click Start Button to Continue Fixing
Step 3. The software will try to match your Samsung device based on its PDA number. If it completes, you should hit Download Now to get the corresponding firmware package.
Start to Download Firmware Package
If the program fails to match your Samsung device since there is no any PDA code, you need to follow the on-screen instructions to put your Samsung tablet into recovery mode.
Step 4. When the firmware is downloaded, tap on Fix Now. Later, DroidKit will start the repairing process.
System Fixed Successfully
If none of the above methods worked for you, your final resort should be to reset your tablet to the factory settings. Resetting the device will remove all the contents and settings and let you customize your device from scratch.
Reset the tablet to factory settings
To do so, head to Settings > General management > Reset > Factory data reset > Reset and tap on Delete All to reset your device.
It should definitely fix the freeze issue for your device as it removes all the content from your device.
One of the possible reasons why your tablet gets frozen is you have too much content stored on your device. If you do admit you have stored a lot of files on your device and there is not much free memory space available, you may want to back up some of your data to your computer and then delete the data from your tablet.
Use services like Samsung Cloud to back up tablet data
When it comes to backing up content on a Samsung device, you have several backup options to choose from. Either you can use Samsung Cloud from Settings > Cloud and accounts > Samsung Cloud or you can use a dedicated app like AnyDroid to have your tablet data backed up to your computer with ease.
AnyDroid is made for Android devices management, you can easily back up your Android device. Just Download AnyDroid and keep your Android data safe from freezing up.
AnyDroid Overview
If you have recently installed any apps on your tablet, it could be these apps are causing your tablet to freeze up. If that is the case, you may want to reboot your device into safe mode and get rid of these apps from your device.
Utilize safe mode to investigate and resolve the freeze issue
Rebooting a Samsung tablet into the safe mode is pretty easy. To do it, turn off your tablet, press and hold down the Power button until you see the Samsung logo, let go of the Power button and press and hold down the Volume Down button and you should enter the safe mode on your device.
You may then get rid of any of the items that you think could be causing the frozen issue on your tablet.
If you are upset about getting your Samsung tablet frozen up every now and then, you may want to try DroidKit indicated above to fix the issue once and for all on your Samsung device.
