“I got a problem on my Samsung Galaxy. It goes black suddenly but still works. Tried to force restart it or put it into recovery mode, nothing helps. Anyone experience this and how your get out?” – Asked by a Samsung user.
Bothered by Samsung black screen issues and don’t know how to fix them? Try DroidKit. It is a powerful Android system repair tool that helps solve various Samsung system problems easily. Supports all Samsung phones and tablets.
Samsung phone has been a popular device among Android users. Like any other hardware, it can fall into trouble from time to time, even the latest versions. One of the most common issues is Samsung black screen on phones or tablets, including:
Samsung Galaxy Black Screen Issue
So what do you do when your Samsung screen starts turning back? In this guide, we will introduce 6 practical methods to fix the Samsung black screen issue.
There are several reasons why your Samsung screen is black but it still works, main causes are shown as:
As a result, you can fix this Samsung black screen issue according to the possible reasons. Besides, you can try the following guides to get your Samsung back to normal with ease.
SD cards sometimes have compatibility issues with Samsung Galaxy phones. Therefore, removing the SD card could be a reasonable method worth trying, and then rebooting your device to check if the issue still exists.
Fix Samsung Black Screen by Removing SD Card
A soft reset means restarting your Samsung Galaxy phone after cutting off all power to the handset. The procedure involves turning your phone off, removing the battery for 30 seconds, and then restarting the phone after replacing the battery.
If your Samsung Galaxy is encountering a black screen issue, you can go right ahead and remove the back panel of the phone and take the battery out for 30 – 60 seconds. Then, put back the battery and turn on your Samsung phone.
Fix Samsung Black Screen by Soft Removing
If you cannot fix Samsung black screen with the above methods, then you can try an Android solution before going to the retailer. DroidKit is a great choice. It can help you solve all kinds of Android phone problems with ease like your Samsung phone is on but the screen is black, Android recovery mode not working, crashes, freezes, and boot loops, etc. What’s more, with the powerful functions of DroidKit, it can also offer you a complete solution for Android, including Screen Unlocker, System Reinstall, Data Transfer & Backup, etc.
Now, follow the steps below to revive your dead device in a few simple steps:
Step 1. Get the latest version of DroidKit on your computer > Connect your Android device and tap on the System Fix.
Click System Fix Function
Step 2. Once DroidKit detected your device, click the Start button to continue.
Start to Repair Samsung Phone
Step 3. DroidKit will match the PDA code of your Samsung Device Automatically > Then click Download Now to download the firmware.
PDA Code Matched
NOTE: If there is no matching PAD code, you need to put your device into recovery mode and get PDA code.
Step 4. After the firmware is downloaded, click the Fix Now button and put your device into download mode.
Step 5. Once finished, it will automatically start repairing your Android system. After completing the repair process, you will get the system fixed successfully page as below. All the system issues are fixed and your Android device will be restarted.
Completing the Repair Process
Some users from forums said that when the battery runs out, charging the device again would fix the black screen issue, too. And you can have a try with this simple method.
Using Android recovery mode and wiping the cache partition could also help you fix the Samsung Galaxy black screen issue. And here are the detailed steps:
After the cache partition is cleared, the Galaxy phone will reboot automatically.
If you have done everything above, and your Samsung Galaxy is still encountering the Black Screen issue, your handset might have a hardware issue and the best thing to do is to go to your retailer, carrier, or Samsung to have your phone checked.
You can now try these 6 methods above one by one to easily fix Samsung black screen issue. If the common ways don’t solve your problem, DroidKit is a good choice for you to fix the Samsung black screen issue. It can solve almost all Android-related issues without much trouble. Free get DroidKit to have a try! Surely, if you find that this post is truly helpful, please share it with others; and if you have another method for this question, you can also share it in the comments below.
