What to do if your iPhone says press home to upgrade? Want to get ways to solve the press home to upgrade problem? Check this guide to fix this issue on iPhone in iOS 15 with ease.
Free download AnyFix to 1-click to fix iPhone press home to upgrade issues. With AnyFix you can also update your iPhone to the newest iOS 15 with ease.
When we upgrade our iPhone/iPad/iPod to the new iOS version, there sometimes occur various problems and issues, even after upgrading, such as iPhone iPad not charging, iPhone/iPad stuck in recovery mode, iPhone iPad data lost/disappeared, and the one above – press home to upgrade problem, etc.
In this tutorial, we will focus on the issue “press home to upgrade”, and provide you with several practical methods to fix it on iPhone/iPad in iOS 15. Read on and check them now.
What do I do if my iPhone says press home to upgrade? This problem is annoying because its message tells you to press the Home button to start upgrading, but when you really do it as it says, the device has no response at all and is stuck there. To fix it, do the following methods one by one.
Take restarting action for like 4-5 times, it will show up the passcode entering screen finally sometimes, according to some users.
Try press Home button on iPhone, and click Try Again on iTunes. If nothing happens, then try disconnecting from the computer iPhone.
If they both do not work for iPhone stuck press home to upgrade the screen, you need to try recovery mode to fix it and set up the device again.
Step1. Make sure iTunes is the latest version.
Step 2. If iTunes is already open, close it. Connect your device to your computer and open iTunes again.
Step 3. Once your device is connected, force restarts it with these steps:
Step 4. When you see the option to Restore or Update, choose Update. iTunes will try to reinstall iOS without erasing your data. Wait for iTunes to download the software for your device. If the download takes more than 15 minutes and your device exits recovery mode, let the download finish, then repeat these steps.
How to Fix “Press Home to Upgrade”
How can I update my iPhone if the home button doesn’t work? Usually, the above 3 solutions can solve the iPhone iPad stuck in the recovery mode loop. But some iOS device users reported they were failed to get out of this issue. So, in this section, we highly recommend you use AnyFix – iPhone System Repair to fix the loop problem.
AnyFix, as a professional iOS system issue fixer, provides a one-stop solution to fix many iOS / iPadOS / tvOS / iTunes troubles in a few minutes without any risks at all. The following steps will lead to an efficient way to fix this problem without iTunes.
Step 1. Download AnyFix and launch it on your computer > Connect your iOS device to the computer > Choose the System Repair.
Using AnyFix to Get out of Press Home to Upgrade
Step 2. Here you need to choose the 50+ iPhone Problems > Click on the Start Now to go on the fix.
Choose iPhone Problems and Start Now
Step 3. In this step, you need to choose a repair mode. Generally, we recommend you to the first one – Standard Repair to start the repair.
Choose Standard Repair Mode
Step 4. Put your iOS device into Recovery Mode > AnyFix will download a firmware file on your computer > After it is finished, you can click on the Fix Now to continue.
Firmware Download Completed
Step 5. You may have to wait for a while. Once AnyFix finished the issue-solve journey, you can get a fine iOS device from scratch.
Well, now you can use your iPhone/iPad as usual. AnyFix is a troubleshoot maker on which committees to solve any iOS issues at ease. Not only an iOS system problem, but it also provides a one-stop solution to fix iTunes issues. Like getting out of iTunes errors while using iTunes, downgrade or upgrade iOS system, etc. Why not give it a try?
For the fourth way above, or other occasions, such as factory reset and wrong operation during jailbreak, there is a possibility that your iPhone/iPad stuck in recovery mode. For this problem, we will tell you how to fix it in the following.
To fix this recovery mode loop issue, you can try PhoneRescue for iOS – the best iOS problem repair tool. It is capable of solving stuck in recovery Mode, black screen, Apple logo, and so on. So why not give it a try now before talking about the detailed steps.
Step 1. Run it on your computer > Connect the device to it > Choose iOS Repair Tool options at its homepage.
Fix iPhone iPad Stuck in Recovery Mode
Step 2. Choose Standard Mode, and do as its instructions to get your iPhone iPad out of recovery mode.
With these three ways, you can totally figure out the issue of press home to upgrade. If you have any questions about it, you can leave your words in the comments below.
