Pokemon Go has attracted millions of Android gamers across the world, yet many of them have reported that they are facing such problem as GPS signal not found on Android. Check this article to learn how to fix Pokemon Go GPS signal not found on Android issue with ease.
Pokemon Go is one of the most popular online games all over the world and millions of people have been actively playing it since its release. But if you have played the game before, you might notice that there is an error of Pokemon Go GPS signal not found (also called Pokemon Go GPS signal not found 11) on Android occurring during the gaming process. That’s reported by many of its followers shortly after Pokemon Go was launched on their Android or iPhone. And it’s disappointing!
Since Pokemon Go is such a game that requires a steady and strong GPS signal and an internet connection, a problem like this might destroy the whole gaming experience. And it’s urgent that it should be fixed immediately. If you are searching for a suitable solution to how to fix the Pokemon Go GPS signal not found on Android issue, follow this guide to learn why it happened and how to fix it.
It is important to learn the reason for the Pokemon Go GPS is not found 11 issue:
You know that sometimes your device may not be connected to a stable internet connection or the location service on your device may be disabled or not working properly. What’s more, there are chances that the Pokemon Go app may not load correctly on your phone and the damaged Pokemon Go or an outdated version of the application will cause Pokemon Go GPS not accurate too.
After understanding the possible reasons for this problem, you will definitely ask: How do I fix the GPS not found 11 Pokemon Go? Don’t worry, there are seven tips that can help you.
Tip 1. Try to DroidKit – Android System Repair
Besides the internet connection problem, the system issue on the Android phone may cause the Pokemon Go GPS signal not found problem. It is important to check if there is a system issue on your Android device. Then you can try an Android solution called DroidKit – Android Phone Toolkit, which can help you solve Android phone problems with ease.
Step 1. Get the latest version of DroidKit – Android System Repair on your computer > Launch DroidKit > Connect your Android device and tap on Fix System Issues panel.
Click Fix System Issues
Step 2. Once DroidKit detected your device, click the Start button to continue.
Click the Start Button to Continue Fixing
Step 3. DroidKit will match the PDA code of your Samsung Device Automatically > Then click Download Now to download the firmware.
If there is no matching PAD code, you need to put your device into recovery mode and get PDA code.
Start to Download Firmware Package
Step 4. After firmware downloaded, click Fix Now button.
Click Fix Now after Firmware Downloaded
Step 5. Put your device into download mode.
Get Your Phone into Download Mode
Step 6. Once finished, it will automatically start repairing your Android system. After completing the repair process, you will get system fixed successfully page as below. All the system issues fixed and your Android device will be restarted.
System Fixed Successfully
Tip 2. Resetting Location Settings.
1. Go to Settings of your handset.
2. Locate Privacy and safety > Tap on it.
3. Tap on Location.
4. Make sure that Location switch is on > Tap on Locating method (which could also be called Location mode depending on the Android device).
5. Tap GPS, Wi-Fi, and mobile networks (This may also be called High accuracy).
6. Make sure that the Wi-Fi of the handset is turned on throughout the game, even when the smartphone is not connected to a network.
Tip 3. Disabling Mock Locations.
For Android gamers, just go to about phone > Tap software Info about 7 times till the Developer Options pops up > Turn on developer options > Disable mock locations.
Tip 4. Restarting Your Phone.
This one seems easy, but somehow it works for many problems that occur when we use our Android phone. For most Android phone, Long press the power switch till the Restart Your Phone appear > Tap it.
Also Read: How to Get Out When Android Stuck in Recovery Mode >
Tip 5. Turning On/Off the Airplane Mode.
GPS signal has something to do with the internet connection, so turning on and off the airplane mode is sometimes worth a try. For most Android devices, just pull down the notification bar > find the airplane mode button > Tap it twice.
Tip 6. Resetting Network Settings.
It’s not a bad idea to reset network settings when you have issues related to the internet connection. If it is a Samsung Galaxy S9/S8/S7/S6, for example, then go to General Management > Tap Reset > Tap Reset Network Settings > Tap Restore Default Settings.
Tip 7. Stepping Outside.
GPS signal is a tricky thing for most Android phones. No matter what Android phone you have, you may sometimes have problems locating a device, so try stepping outside to check whether the GPS signal not found on Android issue has gone away.
Tip 8. Upgrading to the Latest Version.
Also, some of the experts argue that gamers ought to upgrade Pokemon Go to its latest version because generally, the latest version will fix bugs that occurred in the last version. And it might help to fix the Pokemon Go GPS signal not found on Android issue.
You may have installed many apps like games on your Android phone and don’t want to lose them due to any accidents, then backing up apps from Android to the computer is an option for you. For this purpose, AnyDroid is ready to help you out. Here let’s check some steps to know how to backup apps from Android to computer in a simple and quick way.
Before the start, you need to get AnyDroid to your PC/Mac and then follow the procedures below to transfer apps from Android to the computer.
Step 1. Run it after installing and connect your Android phones to the computer via USB cables > Choose Device Manager > Content to PC on the homepage.
AnyDroid Export Content
Step 2. Go to the categories page and click on Apps > Tap on the Next button to start.
Backup Apps from Android to Computer
With these 8 methods, you can totally fix the Pokemon Go issue of GPS signal not found on Android. If you find this guide is really helpful, please share it with others and help more people. And DroidKit is definitely a great helper to fix your Android system issues, why not give it a try?
