Get a message saying “The iTunes Store is unable to process purchases at this time”? Read this guide to see what the matter is and how to fix it.
The iTunes Store allows us to download songs, apps, TV shows, and films easily, but sometimes it just goes wrong when you want to get some favorite ones. A popup window appears and says that “The iTunes Store is unable to process purchases at this time. Please try again later”. It may also happen when you are not trying to purchase anything but open an app on the device, however, the message just keeps popping up.
The iTunes Store Is Unable to Process Purchases At This Time Error
In addition, many users have been experiencing this problem since yesterday and report this error on Twitter. The good news is that the outage has ended and returned to normal. If you check the Apple System Status page, you will find that it says this issue has been down for about three hours, from 8:00 PM to 11:45 PM. But if you still meet the iTunes Store is unable to purchases at this time problem, please keep reading to get some solutions.
As is known to all, we can easily access anything that we purchased in iTunes Library, however, it’s not that easy to put these items in the right place, it can also lead to data loss for your improper operation. Well, if you always prefer an easy method to manage your iTunes library data, then AnyTrans is here for help.
It’s one all-sided iOS data transfer tool, which is specialized in iTunes Library management.
In a word, it can help you take complete control of your important data, so why not give it a free try? Here we take sync song from iTunes to iPhone as an example.
Download, install and launch AnyTrans > Plug in your device > Click iTunes Library > Click Music > Select the songs you need > Click To Device button to start transferring.
Sync iTunes to iPhone with AnyTrans
When the transfer completed, you can go to your iPhone to check the songs.
Hope this guide can help you fix the iTunes Store is unable to process purchases at this time issue. If you have any other solution, please share it in the comment section to help other users here. And do not forget to have a try on AnyTrans to manage your iTunes library, it will not let you down.
