How to Fix iTunes Error 2009 Easily
Have you ever encountered iTunes error 2009 when you try to update or restore your iOS device? Read this post to find out why it happens and how to fix it.
Author Avatar Joy Taylor Last Updated: Nov. 11, 2021
AnyFix – Fix All iTunes Errors Quickly
Free download AnyFix to 1-click fix iTunes errors, like error 2009 with a few clicks.
For iOS users, when you are trying to update or restore your iOS device, you may face an unknown error – iTunes error 2009. Once it happens, it will prevent you from restoring and updating, until this error is fixed.
And the reasons could be corrupt download or incomplete installation of iTunes, virus or malware infection, program maliciously or mistakenly deleted iTunes-related files, and so on. If you’re annoyed about this error and have no idea of what to do, you’re in the right place. This post sums up several practical solutions to help you out.
Also Read: How to Fix Invalid Response from iPhone 6/7 >
3 Common Ways to Solve This Problem
There are some common ways to solve your problem, which you can complete on your phone.
  1. Check Your USB Connection
  2. Restart Your Computer
  3. Re-install the latest version of iTunes.
Fix iTunes Error 2009 With Simple Clicks
If the above methods didn’t solve your problem, then a third-party iOS system repairer is needed. AnyFix – iOS System Recovery is a useful iTunes/iOS system repair tool. It helps users fix 200+ iTunes errors, like iTunes error 10, iPhone won’t update on iTunes, iTunes error 8003, iTunes could not back up the iPhone, etc.
Besides, AnyFix can also solve system errors for iPhone/iPad/iPod touch/Apple TV. For example, you can use it to fix iPhone stuck on Connect to iTunes screen, the iPad won’t sync with iTunes, iPod touch is disabled. Connect to iTunes, Apple TV cannot connect to iTunes Store, etc. Check some of AnyFix’s main features below:
AnyFix – iTunes System Error Recovery
  • Fix iTunes error 2009 in just a few clicks.
  • One-click detects all the possible system errors and fixes them once.
  • Fix iTunes error 6/21/1429/3194/…with a high success rate.
  • No professional skills are required & no data loss.
Step 1. Download AnyFix and run it on your computer. Connect your iPhone to the computer with a USB cable and select “iTunes Repair”.
Choose iTunes Repair
Step 2. For iTunes error 2009, you can choose “iTunes Connection/Backup/Restore Errors” > Click the “Fix Now” button to start analyzing.
Select iTunes Connection Errors and Click Fix Now
Step 3. Click “OK” to authorize AnyFix the administrator rights after finishing the analyzing process.
Click Yes to Confirm
Step 4. You will see the “Repair Completed” interface below after finishing the repairing process.
iTunes error 2009 Fixed
Get Rid of iTunes Error 2009 With PhoneRescue
If you tried the methods mentioned above but the error still remains, then you can have a try on PhoneRescue – iPhone Data Recovery to return your device to normal. PhoneRescue is a professional data recovery tool dedicated to helping Android and iOS users recover deleted or lost data. Meanwhile, it can be used to fix iTunes errors by restoring the iOS system, including iTunes error 2009.
It’s a safe way for restoring the iOS system and won’t cause any data loss. After that, your device would be equipped with the newest version of the iOS system and the iTunes error 2009 will be fixed as well. Now, let’s see how to use PhoneRescue to restore the iOS system.
Step 1. Download PhoneRescue and install it on your computer. Connect your iPhone to the computer. Click “Device Rescuer” and choose “Repair iOS System”.
Click Device Rescuer and Choose Repair iOS System
Pay attention that there are two repair modes you can choose; they are Standard Mode and Advanced Mode respectively. Only Advanced Mode could restore your iOS system without data loss. The other will wipe all data on your device.
Step 2. Select “Standard Mode”. In most cases, this mode should fix your problem. But if it didn’t, try “Advanced Mode”.
Choose Standard Mode
Step 3. Follow the 3-step instruction in the window to put your device into Recovery Mode, then confirm your device info and select “Download” to download the firmware package.
Put Your Device into Recovery Mode
Step 4. After downloading the firmware document, PhoneRescue will repair your device to normal automatically, and iTunes error 2009 will be solved.
iOS Repairing Completed
Other Ways You Can Try
There are some other ways that can be used to fix the iTunes error 2009, take a look at them.
1. Update Your Antivirus Software
Make sure that your antivirus software is updated or quit it temporarily; this solution may help you out with ease.
2. Disable iTunes Helper
To do this, Mac users can make it with steps: System Preferences > Account > Select Login Items > Find iTunes Helper in the items list > Disable it.
PC users can make it with steps: Start > Run and type MsConsfig > Press Enter > Find ‘iTunes Helper’ and disable it.
3. Take Your Device to An Apple Repair Point
If you tried all the above solutions to fix this issue but nothing worked, consider taking your device to an Apple repair shop and find technical personnel to take care of it. Just Google the address of the Apple repair shop to find one near you.
Hope that these methods introduced above can help you fix iTunes error 2009 on your device. For most users, you can download AnyFix or PhoneRescue to fix your problem. If the problem remains then contacting an Apple-authorized service center or getting in touch with customer support may be useful.
self serviceself service
iMobie Self-Service
reduceclose
customer service
End conversation
