Still troubled by your iPhone stuck on Connect to iTunes screen? Read this guide in depth to learn 5 proven ways on how to solve this problem.
iTunes is certainly a very useful software for iPhone users, but it can be very troublesome when your iPhone stuck on connect to iTunes screen. Because at this time, you can’t use your iPhone at all, and you may even lose all important data on your iPhone.
iPhone Stuck on Connect to iTunes Screen
To fix this problem, first you need to know: why does my iPhone keep saying connect to iTunes? There are many reasons for iPhone stuck on iTunes logo, such as a failed iOS system update. Only when you find the reason can you find out targeted fixes based on the causes. That is why we write this guide. In this guide, we will tell you the reasons why iPhone stuck on connect to iTunes screen and how to get rid of it. Now keep reading to know more!
Many people ask: Why is my iPhone stuck on the iTunes connect screen? To address people’s doubts, here we have listed 4 most common reasons that might cause your iPhone stuck on connect to iTunes screen:
Then, how do I fix my iPhone when it is stuck on connect to iTunes? In fact, you just need to use the correct tool to repair iTunes or iOS issues. And based on the causes we mentioned above, we collect several easy and useful solutions as well as their steps for you to fix this problem. Learn more now!
Don’t Miss: Top 10 Most Common iPhone iPad Restore Error and Solutions >
If you see the connect to iTunes screen, force restarting your device is a quick way to fix it. Now you can follow the steps below to do it according to your iPhone model.
On iPhone 8/8 Plus, iPhone X/XS/XS Max/XR, and later iPhone modes
Force Restart Your Device
On iPhone 7 and 7 Plus
This is the way how to fix iPhone stuck on iTunes logo. And if you want to know how to get out of connect to iTunes screen without computer, you can also try this method.
Generally speaking, iTunes connection issues are a major cause of iPhone stuck on iTunes screen. And to solve the iTunes connection failure, you need an iTunes repair tool. Here, we highly recommend a professional troubleshooter: AnyFix – iOS System Recovery, which supports fixing over 200 iTunes issues. Let’s take a look at its detailed features.
Download AnyFix for free now and follow the detailed steps below to fix iPhone stuck on connect to iTunes screen!
Step 1. Run AnyFix on your computer > connect your iPhone to the computer > choose the iTunes Repair on the right.
AnyFix iTunes Repair Option
Step 2. Choose the iTunes Connection/Backup/Restore Errors and then tap on the Scan Now.
AnyFix iTunes Repair Restore Error
Step 3. You have to authorize the administrator’s rights to AnyFix to repair the iTunes. Click on the Yes and OK button to continue.
Authorize AnyFix on your Computer
Step 4. Then AnyFix will repair the iTunes issues automatically. After that, you can choose OK or go to iTunes via clicking on Open iTunes.
iTunes Repair Completed
Apart from iTunes connection issues, iOS system issues can also cause that iPhone says connect to iTunes all the time. So how do I fix my iPhone when it says connect to iTunes? In fact, you can fix this problem by reinstalling iOS. But what you need to remember is that this reinstall process will erase all existing data on your iPhone, so before reinstalling iOS system, don’t forget to make sure you have backed up your iPhone data before. Here are the steps to fix iPhone stuck on connect to iTunes screen by reinstalling iOS.
Click Update to Reinstall iOS
You May Also Like: How to Backup and Restore iPhone iPad Using iTunes >
If your iPhone stuck on connect to iTunes screen is because of iOS system issues, but you don’t want to lose the original data on your iPhone, then you can also rely on third-party iOS system repair tools to solve this problem. PhoneRescue for iOS is exactly the software you need.
With PhoneRescue, you can resolve common iOS system issues in minutes with a few simple clicks, including stuck on connect to iTunes screen, stuck on Apple logo, recovery mode loop, and more. Most notably, PhoneRescue’s advanced iOS repair mode will not erase any iPhone data, so you don’t need to worry that your precious memories and important files will be gone. Besides, it can also help you selectively recover deleted/lost iOS data like messages, contacts, photos, notes, etc. Now let’s see how to use PhoneRescue to solve iPhone stuck on connect to iTunes screen.
Free download PhoneRescue for iOS on your Mac/PC, then connect your iPhone to the computer via a USB cable.
Run PhoneRescue for iOS > Choose Repair iOS System > Click the blue arrow to continue.
Enter Repair iOS System in PhoneRescue for iOS
Select Advanced Mode and follow the instruction to enter Recovery Mode. Click the Download button to download the firmware for your iPhone.
Choose Advanced Mode
The repair process will start automatically. Just wait for a few minutes.
Wait for the Repairing Process to be Finished
If none of the above methods successfully solve the problem of your iPhone, it is very likely that your iPhone has some hardware damage. For this reason, we recommend that you contact Apple Support and have your iPhone hardware repaired by a professional technician.
That’s all about how to fix iPhone stuck on connect to iTunes screen issue. Hope you have worked out this troubleshoot. If it is iTunes or iOS system problems that caused this situation, in order to make sure that the data in your iPhone is not lost, don’t forget to use AnyFix or PhoneRescue to solve this issue.
