4 Ways to Fix iCloud Music Library Not Showing Up 2025
With iCloud Music Library fails to work, your Apple music or iTunes match music becomes inaccessible on your device. So, here, we have given some solutions to iCloud Music Library not working issue.
Author Avatar Joy Taylor Last Updated: Nov. 29, 2024
iCloud Music Library is an amazing feature in Apple devices that lets users sync their music to all of their devices. It is available in both iTunes Match and Apple Music, which are both Apple’s music subscription services. With iCloud Music Library, you can store your device’s music in iCloud and it will be available to all of your devices that have the same Apple ID and iCloud Music Library feature turned on. The iCloud Music Library can store up to 100,000 music files and what’s more, they don’t take up your iCloud space.
iCloud Music Library is a very convenient way to keep all your music with you at all times. However, there have been regular reports from iPhone and iPad users about iCloud Music Library not working and users being unable to sync their music across their devices. In this article, we will introduce how to fix the iCloud Music library not working issue in simple and easy ways.
Why don’t I see my music library on iCloud?
There are several reasons why your iCloud music library not showing up, you can check them in the following part.
  • iCloud Music Library (Sync Library) is not enabled on your device. You can go to the settings and enable the sync library.
  • You are signed in with a different Apple ID on the device.
  • There is no active subscription to Apple Music or iTunes Match.
  • Your network condition is too poor to sync iCloud music library.
  • The library is still uploading or syncing music to iCloud.
  • There are incompatible file formats or DRM restrictions for certain songs in the library.
  • Outdated software on your device.
  • Temporary server or account issues with Apple. If this is the case, you have to wait for the official solutions.
Knowing why iCloud music library not showing up, you can refer to the following 4 methods to fix this issue without effort.
How to Fix iCloud Music Library Not Working
It is very troubling when your iCloud Music library not syncing on your iPhone or iPad or iTunes on your Mac. There wouldn’t be any purpose to having an iTunes Match or Apple Music subscription if your iCloud Music Library not showing up. So, below we have given some of the effective solutions to fix the iCloud Music Library not working issue.
Fix 1: Turn On/Off iCloud Music Library
If your iCloud Music Library not showing up on your devices, firstly go to Settings > Music > Join Apple Music, then try to turn off your iCloud Music Library and then again turn it on. To do this, go to the Settings > Music and then tap on iCloud Music Library switch to turn it off. Wait for some time and then again turn the iCloud Music Library on and then go to Music app.
How to Fix iCloud Music Library Not Working - Turn On/Off iCloud Music Library
If you don’t subscribe to Apple Music or iTunes Match, you won’t see an option to turn on iCloud Music Library. So you need to subscribe first, then turn on/off iCloud Music Library.
In iTunes, go to iTunes menu > Edit > Preferences > General > Uncheck the iCloud Music Library. Then after some time, enable the iCloud Music Library by the above same steps. Your iCloud Music Library music should turn up on your device.
On Mac, open the Apple Music > Choose Music > Preferences > General > Select Sync Library to turn it off then on.
Fix 2: Check Apple System Status
Sometimes your iCloud Music library doesn’t work is only because Apple is carrying out routine maintenance on specific iCloud services. Before you got mad about your iCloud Music error messages, you could check the Apple system status to see if it is the reason why your iCloud Music not showing up.
Fix 3: Update iCloud Music Library manually from iTunes
iCloud Music Library automatically uploads your music from iTunes Match or Apple Music to iCloud. But sometimes due to some error, it may not be able to update itself. Then you can manually update the iCloud Music Library to fix the iCloud Music Library not showing up in your iTunes. To manually update the iCloud music library from iTunes, go to File > Library > and then click on Update iCloud Music Library. Any tracks that are not uploaded or synced will be matched to the iTunes Match or Apple Music catalog.
 How to Fix iCloud Music Library Not Working - Update iCloud Music Library
How to Fix iCloud Music Library Not Working – Update iCloud Music Library
Fix 4: Sign in and sign out of iTunes
If even after trying everything to solve the iCloud Music Library not working issue, you can try to sign out and again sign in of your iTunes. Open iTunes on your computer and go to Accounts/Store menu. Click on Sign out to sign out from your iTunes. Then follow the same steps to sign in again. Then enable the iCloud Music Library by following the steps mentioned above.
How to Fix iCloud Music Library Not Working - Sign in/out of iTunes
How to Fix iCloud Music Library Not Working – Sign in/out of iTunes
Bonus Tip: How to Transfer Music from iPhone to iPhone without iTunes
Get tired of tedious iTunes to sync music and want to transfer music from iPhone to iPhone without using iTunes? For this purpose, AnyTrans is recommended for you to sync music from iPhone to iPhone without iTunes. It’s capable of transferring data from iOS device to device, from computer to device and from device to computer without any trouble. Let’s check some of the detailed steps below:
Firstly free download AnyTrans to your Windows or Mac computer and then follow the steps below to transfer music from iPhone to iPhone without iTunes.
Step 1. Launch AnyTrans on computer and plug in your two iPhones. Once your iPhones are recognized, select your old iPhone, choose Device Manager and click Music.
Run AnyTrans and Connect your Device
Step 2. Select the songs you want to transfer and click the To Device button to transfer music from one iPhone to another.
Transfer Music from iPhone to iPad with AnyTrans
iCloud Music Library is a great way to sync your iTunes Match or Apple Music to all your devices. But, if you encounter iCloud Music Library not working or not showing up the issue, then you won’t be able to access the music on your synced devices. And AnyTrans is definitely a great helper to transfer music from iPhone to iPhone without iTunes. Just get it to your computer and start a free trial >
