Top 5 Mac Cleaner Reviews
You can read on this post – Top 5 Mac cleaner reviews – to find out what is the best Mac cleaner for your Macbook, iMac or Mac mini to run more smoothly.
Author Avatar Joy Taylor Last Updated: Feb. 10, 2022
In fact, even Apple Macs need regular clean up like any other Windows computers. To clean up Mac manually is a laborious task, and it is not nearly enough. That’s how some professional Mac cleaner software comes. An old Mac can store gigabytes of junk files and which can not only take up space but also slows your Mac.
In this article, we have rounded up 5 of the best Mac cleaner software with their reviews and screenshots for you to speed up your Mac by cleaning up all unnecessary junk files on your device. Please check out and find a suitable one for your Mac.
1. Best Mac Cleaner – MacClean 3
Price: $19.99
MacClean offers you “60-Days Money Back Guarantee”, you can ask a refund if you find it doesn’t work well. Get It Now
MacClean is the best Mac cleaner for all Mac desktops and laptops. It is mainly for Mac users who want to clean up and free up Mac hard drive with no effort.
Main Features of MacClean
  1. It is fully capable of detecting and removing all types of junk files – Internet Junk, User Junk, System Junk, Development Junk, and Application Junk from Mac.
  2. It wipes out malicious cookies and malware from Mac to keep your Mac safe.
  3. It provides you with 10 useful tools like Duplicates Finder, Old & Large Files Finder, File Eraser, App Uninstaller, and Extension Manager, etc.
  4. It works all Macs including MacBook, MacBook Pro, MacBook Air, iMac, Mac mini, Mac Pro, etc.
Related Reading: Download MacClean Now >
2. MacPaw CleanMyMac 3
Price: $39.95
CleanMyMac 3 as its name expresses, is an easy to manage Mac cleaning software that made to clean and maintain your Mac. There is a free trial but you need to buy it for $39.95 (License for 1 Mac).
Main Features of CleanMyMac 3
  1. It helps clean the junk files from your Mac like user cache files, user log files, system log files, broken preferences, iOS software updates, etc.
  2. It finds out and removes old files from Mac to free up space.
  3. It manages to delete entire applications, including all the extra files.
  4. It empties the trash can on Mac and makes it unrecoverable.
Mac Cleaning Software – CleanMyMac 3
Also Read: 11 Ways to Make Your Mac Faster >
3. Mac Cleaning Software – Smart Mac Care
Price: $49.95
Smart Mac Care is an all-in-one tool to keep your Mac healthy and secure by removing malware infections, unwanted junk files and privacy traces.
Main Features of Smart Mac Care
  1. Malware Scan: It helps you detect and remove malware infections provide security to your system, eliminating unwanted system crashes and abnormal functioning.
  2. Junk Scan: It can smartly detect cache files, log files, trash etc. that are no longer in use and delete them in few clicks.
  3. Privacy Scan module scans all the browsers installed on your Mac for Internet history, cookies and application cache.
  4. It includes some tools like Uninstaller, Duplicate Finder, Failed Downloads and Login Items etc. All of them can help boost system performance and recover considerable hard disk space.
4. Mac Cleaning Software – Detox My Mac
Price: $24.95
Detox My Mac is basically the Mac software cleaner. It is designed to clean up junk stored in the storage space on the Mac and makes the memory space free. There is a free trial of Detox My Mac which allows you to scan and remove logs and trashes like user logs, trash bin, etc. And you need to unlock the full version for $24.95 for more functions.
Main Features of Detox My Mac
  1. It’s quite simple and easy to use.
  2. It helps remove only those unused files and documents that clutter your Mac, letting you with a lot of free memory on your Mac.
  3. It removes unused language files for applications and systems helping free up more disk space.
  4. It manages to delete unused history files for browsers and applications.
5. Mac Cleaning Software – AppZapper
Price: $12.95
Removing applications from your Mac is an easy job, however, the leftovers like behind folders and preference files still take hard drive space and generally clutter your system. AppZapper allows you to uninstall application as well as the app left – just drag and drop.
Main Features of AppZapper
  1. It is very easy to use, you can uninstall any app by dragging the app onto AppZapper.
  2. It finds all the extra files left on your Mac and allows you to remove them in a single click.
  3. It remembers which apps you want to keep safe, and the log tracks all the files you’ve zapped.
Mac Cleaner Reviews – AppZapper
You May Like: How to Make Mac Faster in Three Methods >
If your Mac computer is getting sluggish, that means its time to clean out it with some Mac cleaner. You can choose one from the above mentioned tools. If you have any good ideas about the best Mac cleaning software, please share it with us in the comment section.
