2024 Solved: Why Is Screen Recording Not Working
This article discusses some handy solutions to fix the issue of screen recording not working on your device. It also highlights “Screenify” as an all-in-one solution for effortless screen recording on both platforms.
Author Avatar Joy Taylor Last Updated: Sep. 10, 2024
Part 1: Introduction
Screen recording is an essential tool used for creating tutorials, recording gaming sessions, or simply recording videos to watch them later. However, it’s common to face issues while using this feature on Windows or Mac. This can be caused due to different reasons such as application conflicts, system updates and disabled recording permission.
If you are facing the same issue, it is important to resolve it quickly to avoid disruptions and ensure system stability. In this blog, we’ll discuss “Why is Screen Recording not working on your Windows or Mac?” and list effective solutions to solve this issue.好
Part 2: Screen Recording Not working on Windows? How to Fix
If you’re encountering problems with screen recording on Windows, these solutions might help get rid of the issue:
Way 1: Restart your computer
Before you opt for any other troubleshooting options, try restarting your windows. Most times, this is the simple solution can get your screen recording working instantly.
Step 1: Click on the start Menu. Press the power button and then click on “Restart.”
Step 2: Once your device has restarted, check if the screen recording has started functioning.
Way 2. Check your Task Manager
At times, the system can get overloaded, causing screen recording to stop working on your computer. Here’s how to check if your task manager is operating manually:
Step 1: To open the task manager, press Ctrl + Shift + Esc buttons from the keyboard.
Step: Check the applications and process running on the system. Look for any applications that might be using a high percentage of CPU or memory resources.
Check Process
Check Process
Step 3: To free up resources that are not necessary to your current tasks just right click on them and click on “End Task.”
Click End Task
Click End Task
Make sure not to pause any processes that may be critical to the system.
Way 3: Update Graphics Driver
An outdated graphics designer can cause your computer/laptop’s screen recording to stop working. To resolve this problem, you will need to update the graphic card to the latest version.
Step 1: Open the Windows Start menu. Type in “Device Manager” and click open.
Step 2: Right-click on “Display Adapters” to view your graphics card.
Step 3: Go to the Driver tab, click “Update Driver,” and choose “Search automatically for updated driver software.”
Update Drivers
Update Drivers
Step 4: Follow the prompts to download the latest version of the graphic card available on your device.
Way 4: Enable X-Box Game Bar
The Xbox Game Bar is a built-in screen recorder for Windows and is commonly used by Windows users because it’s free. However, it won’t function if it’s not enabled.
Step 1: Go to the Start menu and select Settings.
Step 2: Click on the Gaming category.
Step 3: Select the Game Bar tab.
Step 4: Ensure the option “Record game clips, screenshots, and broadcast using Game Bar” is turned on. If it’s off, toggle it on.
Toggle Game Bar on
Toggle Game Bar on
Part 3: Screen Recording Not Working on Mac? How to Fix
Tired of wondering, “Why is Screen Recording not working on your Mac?” and how to fix it? Try these solutions to get the problem fixed:
Way 1: Check Recording Options
Sometimes, a few minor adjustments can solve the issue of screen recording not working. Here’s how to check if your Mac’s screen recording setting is configured properly:
Step 1: Open the Apple menu and go to System Settings.
Step 2: Next, click on Security & Privacy in the sidebar.
Step 3: Select “Screen Recording” from the left pane and choose the web app you want to allow access.
Allow Access
Allow Access
Step 4: Adjust recording settings. Restart the app and check if the screen recording works.
Way 2: Update Your System
An outdated macOS version can cause screen recording issues. Follow these steps to update your Mac to the latest version:
Step 1: Open the Apple menu and click on General
It is recommended that any important data and files be backed up before proceeding.
Step 2: Click on “Software Update.”
Step 3: Tap “Check for Updates” to view any new updates. Choose the updates you want to install, then follow the instructions provided on the screen.
Way 3: Free Up the Storage
If the screen recording was working fine before but is becoming an issue now, then it’s recommended to free up some storage stage on your device. First, try emptying the trash. If this doesn’t create sufficient space, consider deleting unused applications. You can consider deleting any videos, film or music that you no longer need. Clearing the cache can also help free up disk space.
Way 4: Enable the Keyboard Shortcuts
If you’re trying to start screen recording by pressing the keyboard shortcuts, but it doesn’t record, this might be because the shortcut is not enabled.
Step 1: Open “System Settings” on your Mac.
Step 2: In the left menu, click on “Keyboard.”
Step 3: Click on “Keyboard Shortcuts” on the right side of the window.
Step 4: In the new window, select the “Screenshots” tab from the left menu.
Step 5: Look for the shortcuts related to recording.
Check the Recording Option
Step 6: If the shortcut isn’t enabled, check the box next to it. You can also modify the shortcut by clicking on it and setting a new combination.
Step 7: Click “Done” to save your changes, then close the window. Test the Screen Recorder tab to ensure it’s working.
Part 4.  How to Record on Both Windows & Mac easily | Recommend
For high-quality recording with maximum clarity, Screenfiy is the best option. This software allows you to screen record effortlessly on both Windows and Mac. Moreover, users have the option to choose between different recording modes, such as tab & window recording and selected area recording.
To Record With Screenify:
Step 1: Download and install, then open Screenify on your Windows or Mac.
Step 2: Click on the recording mode of your choice. If you want to record screen, then choose Record screen option.
Select Record Screen Mode
Step 3.Configure Recording Settings aims to configure settings like system audio before recording.
Set Configure Recording Settings
In this setting menu, you can:
1 Choose the System audio.
2 Choose the Microphone you want to record.
3 Choose the Camera you want to use.
4 Choose whether to add a watermark.
Step 4. Select Recording Screen. Please select Full Screen or Region mode and choose the display you need to record. Hit Record button to initiate recording.
Choose Full Screen or Region as You Need
Step 5. Wait for the Recording Countdown.
There is a 3-second countdown to help you prepare the recording after you are ready to start recording.
Part 5:Conclusion
If screen recording is not working on your device, there’s no need to worry! Instead of stressing over why is screen recording not working on your device, just try the solutions we’ve listed above to get the problem solved. Download Screenify today to make screen recording on your device as effortless as possible.
