This guide explains “why is my screen recording black” and covers common issues such as app permissions, outdated software, and display settings. It also offers quick fixes, such as enabling permissions, updating apps, and adjusting display settings. We recommend using Screenify – an efficient screen recording tool – to solve the black screen issue and record without any interruptions.
Try Screenify for free to record screen on Windows or Mac. Whether full-screen or partial-screen recording, recording with sound or with camera, Screenify can do it with ease.
100% Clean & Safe
“Why is my screen recording black?” is an often-asked question. Screen recording is an extremely valuable function for creating lessons, sharing games, and recording problem-solving tutorials. However, instead of capturing what is seen on the screen, it may eventually appear as a blank black screen. This might be annoying, leaving you wondering if the problem is with the app or your device. Do not worry; by the conclusion of this article, we will have explained how black screens appear and demonstrated how to cure them in the blink of an eye. So, let’s begin!
While recording your screen, a black screen may appear instead of the content, but most causes are easy to fix. Let’s explore the common reasons for black screen recordings.
When an app does not have permission to capture what’s on your screen, it cannot capture the screen. You must have permission from app settings to access your screen.
Using outdated apps or device software can cause glitches, including black screen recordings. Ensure your apps and operating systems are updated to the latest versions to ensure smooth functioning.
Certain apps, like streaming services, block screen recording to protect content. This restriction results in a black screen whenever you try to record videos from those platforms.
Your display settings might interfere with screen recording, especially if you’re using features like dark mode or adaptive brightness. Adjust these settings to fix the problem.
Sometimes, the screen recording app itself might glitch. Closing and reopening the app or restarting your device can quickly solve this issue.
Let’s explore common fixes for resolving black screen issues in your screen recordings.
Deleting the cache on your Android device is also useful because it may solve problems with your screen recording app. Collecting excessive data can cause problems, which is why programs that save a lot of information often experience issues like a black screen.
Clearing the cache won’t remove your files; it just gets rid of temporary data that might cause problems. In many instances, this measure alone can help refresh the app and enhance its performance. To use this method:
Step 1. Go to “Settings” and select “Apps.”
Step 2. Find your screen recording app.
Step 3. Select “Storage,” and lastly, choose “Clear Cache.”
Restarting your iOS device can help solve many problems, including black screens in screen recordings. It erases temporary files and refreshes the device’s memory when you restart, which can solve issues that prevent normal operations. The following method is simple and may be performed in seconds. For this:
Step 1. Begin by pressing and holding the “Power” button and “Volume Down” buttons. Hold until the “Power Off” slider shows.
Step 2. Slide the “Power Off” slider to turn off your device.
Step 3. After a few seconds, continue by pressing and holding the “Power” button again until the Apple logo appears.
Restart iOS Device
Sometimes, your screen recording app may behave abnormally because it needs the right permissions. All apps do not have permission to record your screen; if not granted, the screen may appear black. It is easy to check and update these permissions. Granting the app permission to access your screen, camera, and microphone will resolve this problem. Let’s now look at how to check and manage permissions for your screen recording app.
Step 1. Open “Settings” on your device.
Step 2. Tap “Apps” and choose the desired app.
Step 3. Tap “Permissions” to view the list of required permissions.
Step 4. Turn on the permissions you want to grant to the app.
Step 1. Go to “Settings” on your device.
Step 2. Scroll down and select the app for which you want to adjust permissions.
Step 3. You’ll see a list of permissions. Toggle on the ones you want to allow.
Step 4. If prompted, confirm your choice to grant those permissions.
Want to record your screen without encountering a black screen? Screenify is an excellent choice for smooth, high-quality 4K screen recordings at 60 frames per second, ensuring a seamless experience without the common black screen issue.
This versatile tool that supports both Windows and macOS allows every user to capture fantastic 4K movies and not lose a single detail on the screen. It’s ideal for professional gamers and video creators who require reliable, consistent, regular output. It is worth noting that Screenify has no cost for its use; it has friendly graphics without limiting the duration of the recordings.
Here are the steps to record your screen without a black screen.
Step 1. Begin by downloading and installing Screenify on your device to ensure a smooth recording experience.
Step 2. Launch Screenify and select the “Record Screen” option to capture your screen without issues.
Select Record Screen Mode
Step 3. Adjust your recording settings, particularly the audio options, to ensure both sides of the conversation are captured clearly.
Record Setting
Step 4. Choose the area you want to record. You can select “Full Screen” to capture everything or drag to specify a particular section. If needed, resize the recording area for social media before clicking “Record” to start.
Full Screen
Step 5. A countdown timer will appear for three seconds, allowing you to prepare for the recording.
Start recording countdown
Step 6. Once the countdown ends, your recording will begin. During the session, you can add annotations or notes if desired.
Annotate the Screen
Step 7. Click “Stop” to end the recording. You can then review, edit, and save your recording, ensuring no black screen issues occur.
Record Screen Process Completed
In summary, capturing your screen effectively without encountering a black screen is crucial for creating high-quality content. Throughout this article, we’ve explored various methods and solutions to ensure seamless recordings, from adjusting app permissions to using reliable software like Screenify. These steps can help you avoid common pitfalls and achieve professional results, whether for tutorials, gaming, or important calls. We recommend using Screenify for its user-friendly interface and robust features, ensuring you can record easily and clearly while eliminating the frustration of black screens during your recordings.
1. Why does the screen recording not work?
Screen recording might not work due to an outdated version of recording application, permission denial or low storage on the device.
2. Why is iPhone screen recording black screen?
If the app doesn’t have authorization to record or there’s a software bug causing the problem, your iPhone’s screen recording may be dark.
3. Why OBS is showing a black screen?
OBS may show only a black screen if there’s a problem with the video drivers on your computer or faulty settings. Sometimes, if you have no permission to record the selected screen, it will appear black.
4. How can one capture Netflix on an Android device without getting a black background?
To record Netflix on Android without getting a black screen, use a good screen recording app that can bypass content protection and ensure it has the right permissions. We recommend using Screenify to record Netflix on your PC in 4K at 60 FPS.
