Home Screen Record How to Screenshot on Samsung Laptop Easily
This article details how to screenshot on Samsung laptop. From keyboard shortcuts like the PrintScreen Button to built-in features like the Snipping Tool, we have a range of methods to fit your needs. We have also shown you third-party apps like Lightshot to complete this job.
Roger Smith | Last Updated: Aug. 21, 2024
1715 words|5minute
How to take a screenshot on a Samsung laptop? This is the question that most Samsung laptop users are asking.
Whether it’s to save a recipe you found online or keep a record of an email. Or sometimes, you just want to share what’s on your screen with friends. But no matter the situation, taking screenshots on a Samsung laptop is especially useful.
So, in this article, we will guide you on capturing a screenshot on a Samsung laptop step-by-step. Whether you’re using Windows 11 or 10, you can do it without hassle.
So, let’s start with the keyboard shortcuts that can capture screenshots.
The Keys That Can Make Screenshots on Samsung Laptop
Windows operating system comes with the built-in screenshot features. Since Samsung laptops work on Windows OS, there are keyboard shortcuts that can help you capture a screenshot on it. These handy combinations make the task quick and convenient. Moreover, they also eliminate the need to download additional software. So, knowing these shortcuts can save you time and effort.
Let’s look at the three main key combinations that you can use for this task:
1. PrintScreen Button
There is a PrintScreen button on the upper left side of keyboards. This is one of the least understood keys on a standard keyboard. It often leaves people puzzled when they press it because there is no immediate action.
However, what this key does is quite clever. It captures a visual snapshot of everything on your computer’s screen and copies it to your clipboard. Then, you can paste it into any program that supports image pasting. For example, Paint or Word.
Here are the steps to use the PrintScreen button:
  1. Ensure the content you want to capture is visible on the screen.
  2. Press the PrintScreen button on your keyboard. Your screenshot is now in the clipboard.
Make Screenshots with PrintScreen on Samsung Laptop
To edit and save the screenshot:
  1. Go to the search bar that is located in the bottom left corner. Search for the “Paint” app.
    Use Paint to Edit a Screenshot
  2. Now open the app and press “Ctrl + V” to paste the saved screenshot from the clipboard here. You can also make some basic edits here.
    Paste the Screenshot in Paint
  3. Once done, click on the “File” section from the top toolbar and select “Save As” to save this screenshot as an image.
    Save the Screenshot on Your Computer
The function changes slightly when the PrintScreen button is combined with the Windows key. Instead of just copying the screenshot to your clipboard, the computer saves it automatically as an image file. This is ideal for those who prefer to have their captures instantly saved for later use. There will be no intermediary step of pasting and saving the image manually.
For this function:
  1. Simultaneously press the Windows Key + PrintScreen.
    Press PrintScreen + Windows Keys on the Keyboard
  2. Your screen will briefly go black to indicate a successful capture.
  3. Go to the “Screenshots” folder inside “Pictures.” The screenshots will be saved here.
2. Windows Key + Alt + PrintScreen
This particular keyboard shortcut gives a touch of finesse to your screen captures. Unlike the PrintScreen key, the Windows Key + Alt + PrintScreen shortcut targets only the current active window. This is particularly useful when you have multiple windows open but want to focus on capturing just one specific piece. Then, the image will be saved directly in a specified folder.
Here are the steps for it:
  1. Ensure the window you want to capture is in focus.
  2. Press the Windows Key, Alt, and PrintScreen simultaneously.
  3. The screenshot of the current window is saved in the “Videos > Capture” folder.
  4. If you want to make some edits before saving the screenshot:
  5. Press “Alt + PrintScreen” simultaneously. The screenshot is now copied to the clipboard.
  6. Now, you can open “Paint” and paste the screenshot to edit it. Then save the screenshot to your computer.
3. Windows Key + G: Xbox Game Bar
The Windows Xbox Game Bar is often overlooked as a tool for gamers. But its usage extends far beyond just games. You can also use this built-in feature for capturing screenshots. This is especially convenient for users who wish to use more than just the screenshot feature. The Game Bar also offers screen recording, audio settings, and performance monitoring.
Here are the steps to use the Xbox Game Bar for taking screenshots:
  1. Press the “Windows Key & G” at the same time. It will launch the Windows Xbox Game bar.
    Press Windows Key + G Button
  2. Click on the camera icon when you are using a Window. Remember, it will not work if you are not using any window.
    Click Camera Icon to Take Screenshot
    Click Camera Icon to Take a Screenshot
  3. The screenshot is stored in the “Videos > Capture” folder and will not be saved to the clipboard.
All these methods provide different approaches to achieve the same result. Choose the keyboard shortcut that fits your particular needs. Now, let’s see another amazing tool that can capture a screenshot on a Samsung laptop.
Capture a Screenshot with Snipping Tool
If we don’t want to use the keyboard shortcuts for any reason, then how to take screenshot on Samsung laptop? The answer lies with the Snipping Tool. It’s also a built-in application for taking screenshots on Windows-operated Samsung laptops.
This application is perfect for those who prefer a few more options than just capturing the entire screen or active window. Because in the Snipping Tool, you can also capture a specific part of your screen. The screenshot is automatically shifted to the Snipping Tool editor. So you don’t need to use “Paint” to save the screenshot.
Step-by-Step Guide to Using Snipping Tool:
  1. Go to the search bar & type “Snipping Tool.” Click on the Snipping Tool app and open it.
  2. The Snipping Tool will offer you multiple modes. These are Free-form, Rectangular, Window, and Full-screen modes. Choose the one that suits your needs.
    Selecting the Mode in the Snipping Tool
  3. Click the “New” button to start your capture. If you choose Free-form or Rectangular, you must click & drag to select the area you wish to capture.
  4. After capturing, the image will appear in a new Snipping Tool window. Then edit, highlight, or annotate the screenshot using the “Pen” and “Highlighter” buttons.
  5. Click “File” & “Save As” to store the screenshot on your computer.
After following these simple steps, you can efficiently use the Snipping Tool and capture screenshots on your Samsung laptop. If you are not suited for these in-built features, many third-party tools can help you. One such tool that is extremely popular in the industry is Lightshot.
How to Use Lightshot to Capture Screenshots
Lightshot is a third-party application that’s another option for capturing screenshots on a Samsung laptop. It offers a user-friendly interface and other features like easy editing & quick online sharing. So, if you’re still pondering “How to screenshot on Samsung laptop,” give Lightshot a try. Because it offers more functionality compared to the built-in methods.
You can download Lightshot for Windows and Mac computers. It’s also available in the Chrome web store to add it as a Chrome extension.
Here are the steps to use Lightshot for capturing screenshots:
  1. Visit the Lightshot website and download the software suitable for your operating system.
  2. Launch the tool by clicking on the “Lightshot” icon on the taskbar. You can also press the “PrintScreen” button to launch it.
  3. A dim overlay will appear on your screen. Click & drag to select the area you want to capture.
  4. Once you’ve selected an area, a small toolbar will appear. It allows you to save, edit, or share the capture.
  5. Click the save icon to store the screenshot on your computer, or press “Ctrl + S” to save your screenshot. You can also choose where you want the file to be saved.
Lightshot allows you to share your screenshot via a unique link quickly. Or you can directly upload it to social media.
Before we end our article, let’s quickly summarise how to capture the full screen of a Samsung laptop.
How to Capture the Full Screen of a Samsung Laptop
You’ve learned various methods, from built-in shortcuts to specialized software. But sometimes, you just want to capture everything on display as quickly as possible. And there are ways to do just that.
Below are three methods specifically for capturing the full screen:
  1. The easiest built-in option to capture full screen is using Windows + PrtScn Buttons. Simply hold down the Windows key and hit the “PrtScn” button. This captures and saves your entire screen as a file in your “Screenshots” folder.
  2. To use Xbox Game Bar to capture Samsung laptop full screen, press “Windows Key + G” to open the Xbox Game Bar. Once the bar is visible, click the camera icon. This action will also capture your entire screen.
  3. After launching the Snipping Tool, you can select “Full Screen” mode. Then, hit the “New” button, and you’ve captured everything visible on your display.
Capturing the perfect moment on your screen shouldn’t be a difficult task.
In this article, we answered how to screenshot on Samsung laptop with Windows 10 or 11. You can use built-in keyboard shortcuts like the PrintScreen Button and Windows Key combinations. Or you can go with the versatility of Windows Snipping Tool. There are even third-party tools like Lightshot for those who want extra features.
By using any of these methods, you can easily keep a visual record of important information.
Roger Smith
Work for iMobie team for 5 years as well as an Apple fan, love to help more users solve various types of iOS or Android related issues.
