Home Screen Record Fix Screen Recording No Sound on Windows/Mac/iPhone/Android
Facing the screen recording no sound error again? This article considers all these problems and offers ways to correct them. Here, you’ll learn how to fix screen recording with Audio on Windows, Mac, iPhone, and Samsung.
Roger Smith | Last Updated: Oct. 25, 2024
1735 words|5minute
Whether you want to review the meeting’s key points later or create a tutorial like Google Meet recording. In a tech-based world, the handy feature is now available on almost all devices and software. However, there may be times when you record a video, but it lacks audio. Spent hours on a screen recording and ended with no audio? We know how bad it feels. This article presents several ways to fix screen recording no sound on Windows, Mac, iPhone, or Android. Follow along to learn more!
1. Ultimate Way to Fix Screen Recording No Sound on Windows/Mac
For those who are experiencing screen recording no sound on Windows or Mac, the easiest way to fix this issue is using a free screen recorder. Screenify is such a wonderful screen recording tool that helps to record screen with audio in easy steps. You can check the main features of Screenify in the following:
Here’s how to record screen with audio on Windows/Mac.
Step 1. Download and install Screenify on your computer.
Step 2. Launch Screenify and choose Record Screen.
Interface of Screenify
Screenify Main Screen
Step 3. Click on the audio settings and confirm.
Select Recording Device
Screenify Audio Settings
Step 4. Preview the recorded files and export.
Preview and Trim Audio
With Screenify, the screen recording no sound issue can be fixed quickly and easily.
2. Screen Recording No Sound on Windows How to Fix
Windows has an in-built game bar screen recorder, which allows you to record audio on a PC. However, screen recording with no sound is a common issue. This can be due to several reasons. Let’s discuss each reason successively with a common fix to the problem.
Fix 1: Update Windows Audio Driver
When your recorded video lacks audio, the first culprit suspected is faulty drivers. Drivers are software components that help maintain a connection with hardware devices, i.e., microphones. Outdated drivers cannot record the sound.
Here is how to update your drivers, step-by-step:
  1. Go to the Start/Windows option. Open the Settings menu.
  2. Find and open the Update & Security option.
    Open the Update & Security Settings
  3. In the Windows Update section, check for updates. If there are no Updates available, you can skip and move to the next fix.
  4. If it says, Updates Available, choose the updates you want and click Install.
  5. Once updates are completed, Reboot your PC to see if the audio is working.
Fix 2: Clean & Reboot the PC
If updating doesn’t resolve the issue, cleaning the PC may help. Often, third-party applications and background system downloads may hinder audio recording. Here is what to do:
  1. In the Start menu, open System Configuration.
  2. From the General tab, uncheck the Load Startup Items under the option of Selective Startup.
    Uncheck the Load Startup Items
  3. Open the Services tab and select Hide all Microsoft Services. Choose Disable All.
  4. Click on Apply, followed by OK. Reboot your device and check for audio.
Fix 3: Check Microphone Access
Likely, the application you are trying to screen record does not have microphone access. It is best to troubleshoot the microphone settings first to figure out if this is the culprit.
Here is how to do it:
  1. From the Start menu, open Settings > Privacy.
  2. Select the Microphone tab to open the microphone settings.
  3. Check if the Microphone access toggle is on. Scroll down to see if your application has access to the microphone.
Fix 4: Run Audio Troubleshooter
After trying all the above fixes, if you are still facing the no audio problem, run the system audio troubleshooter to identify the cause. This in-built Windows tool detects the bug impeding the audio recording. Follow these steps:
Step 1. From the Start menu, open Settings.
Step 2. Go to Update and Security settings and click on Troubleshooter.
Open the Additional Troubleshooters
Step 3. Open the window for Additional Troubleshooters > Recording Audio. Run the troubleshooter to identify and fix the problem.
Run the Audio Troubleshooter
So, this concludes our list of fixes for screen recording no sounds. The repairs are effective and can help you repair the Windows screen recorder. Let’s move to our next problem.
3. Screen Record with Sound on Mac
For Macbooks, Apple has introduced a screen recording feature, but the audio recording is only limited to microphones. The built-in recorder does not capture internal sounds.
This is where the third-party applications come into play. Fortunately, we know some of the best apps to foster your needs. Here is a brief introduction to the top 2 Mac-friendly audio recorders.
Audio Recorder – Audacity
Audacity is one of the most popular screen recorders for its wide range of tools and ease. It is the best audio recording tool to capture high-quality audio with minimum distortion. The advanced tool helps cancel the background noise and professional edit audio. Audacity lets users digitize audio from different media platforms and is compatible with different file formats.
Audacity Mac Internal Sound Recorder
Audio Recorder – Recordit
Recordit is a screen recorder that can capture audio from internal devices and microphones. This is a practical application that offers professional audio and video recording. The intuitive interface is fast and beginner-friendly, which makes it very popular among the commoners. Recordit supports file exports in multiple formats owing to its accessibility.
Recordit Fast Screencasts
4. Fix Screen Recording No Sound on iPhone
Are you confused as to why the iPhone screen recording has video but no sound? We are here to unveil the common issues and simple solutions. Let’s begin one by one.
Problem 1: Turned Off Microphone Audio
If you face an iPhone Screen Recording No Sound issue, the first step is to check the Audio settings. The screen recorder will not detect any audio if the microphone audio is turned off. Here is how to do it:
  1. Swipe up to open the Control Panel.
  2. Find the Screen Recording icon. Press and hold it until the Microphone Audio opens.
  3. Tap on the Microphone icon so it turns red. The red icon identifies that the audio is on.
Enable the iPhone Microphone Recording Audio
Problem 2: Internal Bugs Impeding the Recorder
iPhone’s features are often compromised because of glitches and bugs. The best way to refresh all the applications is to restart the phone. It usually troubleshoots and fixes any minor bugs for smooth functionality.
If the problem continues after rebooting, updating the iPhone may help. Occasionally, Apple launches updates that fix bugs and improve overall work. To see if an Update is available: Go to Settings > General > Software Update.
If an update is available, install it to see if it fixes the issue.
Problem 3: iPhone Needs Troubleshooting
If rebooting or updating doesn’t help, reset all your settings. To return the settings to default: Open Settings > General > Reset > Reset All Settings.
Run the screen recorder again to check if it is recording the audio.
Problem 4: Unsupported Audio Recording
Applications with protected content do not support any form of recording. So, the recorder will automatically be disconnected if you are trying to record Apple Music, Amazon Music, WhatsApp, or Messenger.
5. Fix Screen Recording No Sound on Android
Samsung/Android screen recording is a simple feature that allows users to capture the content on screen with audio effortlessly. However, users have commonly faced trouble for screen recording no sound.
We have marked out some common reasons and their solutions.
Fix 1: Check the Screen Recorder Settings
When you encounter an audio recording issue on Android, the primary step is to check the Audio settings. Samsung offers multiple dedicated recording options for audio: Device Audio, Microphone, Device, and Microphone.
Device audio records internal sounds like ringtones. Microphone audio records sound from the mic, while the third option records external and internal sounds. To select the correct settings:
Open the Screen Recorder from the Quick Panel. Choose the preferred sound settings and click Start Recording.
Check the Recording Audio Settings on Android
If the wrong settings are the culprit, this will resolve the issue. Otherwise, proceed to other options.
Fix 2: Unsupported Audio Content
Apps with private content do not support audio. For instance, due to privacy issues, apps like Netflix, Amazon, Spotify, and Snapchat do not support recordings. This can be the reason if you are facing the issue with the same app repeatedly.
Fix 3: Troubleshoot the Device
Minor bugs can cause system glitches. Restarting the device can fix these bugs and restore the default working. Reboot the phone because there is a good chance it will solve the issue.
Recording screens is a nifty feature that caters to users’ different needs. Screen Recording no sound is a common problem encountered on different devices and applications. We have tried to cover each in detail and pointed out the best fixes. If you are experiencing screen recording no sound issues on computer, Screenify is a choice to fix no sound in recording. Download it now and enjoy a smooth screen and audio recording on Windows and Mac!
Screenify-ad
Screenify – Free Screen Recorder for PC/Mac
  • Supports full screen and specific screen recording.
  • Allows to record the screen with sound and camera.
  • Can record 4K, 60FPS videos. Freely set watermark.
  • Totally free to record, with no time limit.
100% Clean & Safe
100% Clean & Safe
Roger Smith
Work for iMobie team for 5 years as well as an Apple fan, love to help more users solve various types of iOS or Android related issues.
