Having the capacity to record everything you do on your PC is essential, so choosing the right tool for this task shouldn’t be taken lightly. There are dozens of great screen recorder apps, and a lot of them have some unique features that give them an edge over the competition. We present ten best screen recorders with audio for the PC platform that are available right now.
Recording your screen while you are playing games, working, or having fun is very convenient if you want to save a reminder or share your activities with someone. It’s even better if you can include system audio or microphone feed in your recordings to complement the visuals. The simplest option is to use a built-in screen recorder in Windows, but this tool is rather limited in terms of advanced features and may not deliver a great experience for every user.
There are countless screen recorders with audio for Windows 10 that you could use instead. Some of these software solutions may be free to download and use, while others require a considerable sum to be paid to unlock all functions. They also differ in terms of interface, features, supported file formats and many other aspects that users care about.
To make the best decision about the screen recorder you will use daily, you should carefully examine the pros and cons of each app and compare them with your realistic needs.
Someone might think that screen recorders are all the same, but that’s definitely not true. The elite screen recorders with audio for PC are packed with advanced features that empower users to create great-looking multimedia clips at home. We selected the best 11 apps from this class that deserve attention if you are looking for a new screen recorder to install on your PC.
Screen recording with audio can be quite easy if you use the right screen recorder – Screenify. It can be applicable to various different situations such as working on an online meeting, showing gameplay, capturing your favorite video clips, etc. Mainly targeted at screen recording users, Screenify allows you to capture your screen with audio and webcam with simple clicks.
Screenify
Computer Capability: available for Windows, Mac, and Web
You know exactly what you are getting when you install CamStudio – a reliable screen recorder that lets your record video and audio with a minimum of effort. This is an open-source app designed to provide users with full control over the media clips they produce, without burdening them with complicated options they would rarely need in normal daily work.
Free Video Recorder for PC – CamStudio
Computer Capability: available for Windows or Mac
Some of the advantages of TinyTake aren’t obvious until you try recording something from your screen with it. It’s a simple app and most of its key features are very easy to find and activate, so you can start producing amazing multimedia materials right from the start. On the other hand, TinyTake might surprise you with its robust recording, editing, and sharing features.
Screen Recorder for PC – Tinytake
Computer Capability: available for Windows, Mac, or Linux
People who prefer open-source software tend to favor ShareX over any other screen recorder, and the reasons for this trend are not too hard to fathom. It comes equipped with a broad spectrum of advanced functionalities that rival some of the most expensive products from this class. On top of that, the software also allows for extensive customization and upgrades with add-ons.
Screen Recorder for PC – ShareX
You can accomplish even the most ambitious tasks without too much effort if you choose Bandicam as your default PC screen recorder with audio. This app has been in the market for a long time, and has a large base of faithful users around theworld. It’s great for recording educational videos, instructional how-to tutorials, gaming clips, and many other types of professional-looking multimedia.
Screen Recorder for PC – Bandicam
Computer Capability: available for Windows and Mac
Some users value usability more than having a ton of extra features, and Screencast-O-Matic could be the right solution for this crowd. With a simple interface, super-fast commands, and plenty of time-saving shortcuts, this app can offer unmatched flexibility. While free version is fun to use, full version can compare to much more expensive premium screen recorders.
Facecam and Screen Recorders – Screencast-O-Matic
In addition to capturing any part of your computer screen, this app lets you make basic improvements to your videos and easily share them with the public. Finding the key functions in ScreenFlow is quite easy, even for those who use this software for the first time. In other words, this is a screencasting and recording tool that could work for literally anyone, from casual users to professional content creators.
Mac Screen Record Software – ScreenFlow
Widely considered to be the best screen recorder with audio for Windows 7 or above, over the years Camtasia has acquired a prestigious reputation in the market. It’s a high-end product primarily intended for those who create multimedia for a living, but is simple enough that even a total novice can harness its power to some extent.
Screen Recorder for PC – Camtasia
This is another fine example of smart software design in practice. With Movavi, creating multimedia clips is so simple that virtually no training is needed. Choosing the part of the screen you want to capture or selecting the audio source is completely intuitive, so you can just install this app and start producing great looking content right away.
Video Capture Software – Movavi
With this screen recorder with audio for PC, anything you are doing could become the theme for your next video. It can easily capture video and audio from any source, and it doesn’t have a steep learning curve. As web-based software that requires no installation, AceThinker is perfect for people who only occasionally need to record their computer screen and/or voice.
Facecam and Screen Recorders – AceThinker
Downloading Debut to your desktop or laptop could be the best decision you made lately. This is a professional-grade screen recorder that brings a lot of unique qualities to the table. It’s a fantastic solution for anyone who doesn’t want to spend a lot on screen recorder but still requires a reliable tool that can produce impressive videos.
NCH Debut Video Capture Software
