This post is structured to enlighten you on the four simple ways to record your Windows screen with audio effortlessly.
Recording your screen activity is one of the simplest yet affordable techniques available for you to share ideas, describe a situation, advertise your products, and even conserve those special memories you find noteworthy for later viewing. Regardless of the device you are using, the approach required is straightforward but can be complex when you have to include audio.
If you use a Windows computer system and need to capture your screen activity with the corresponding audio narration, this post is for you. Here, we explore the various ways to include audio while recording your Windows computer. Continue reading!
Screenify is a professional screen recording suite capable of recording your Windows screen with high-end results. The software helps you capture every detail you find on your screen with the corresponding audio narration. You are allowed to record content such as gameplay, meetings, webinars, live streams, YouTube clips, and many more.
With Screenify, you have full control over everything displayed on your Windows screen. It comes with customizable recording dimensions, as you are allowed to select your recording range, whether full-screen, specific tab, or portion. This software also features basic editing tools like markup tools, shapes, numbers, stylus, GIFs, and others that you can choose from to polish your recording, so it’s more engaging and creative.
Another big pro of this screen recording software is the sleek UI. Screenify is built with laymen in mind so your tech proficiency doesn’t matter when using it. This software is not only compatible with Windows, Mac users are also welcome to use it.
Step 1. On your PC, free download Screenify, and then run it. Choose the Record Screen mode from its main page.
Screenify Main Screen
Navigate to the section where you have Screen area, Resolution, and System Audio, and enter your preferred settings to proceed.
Step 2: Once it’s all set, hit the Record button and wait patiently for Screenify to finish the 3-second timer. In no time screen recording will commence.
Hit the Record Button
Step 3: Tap Finish Recording to end the screen recording. Choose your desired destination path to store the recording, then enter a name to complete the process.
VLC Media Player is a well-known video streaming service suitable for recording your Windows 10 screen with the corresponding audio narration. This app captures your entire screen and stores the resulting content directly to your local storage. VLC is super simple to install and the recording feature is easy to operate.
Use the stepwise guide below to record your Windows 10 screen with audio via VLC Media Player:
click on Media > Open Capture Device
choose Desktop underneath the Capture Mode tab
You cannot talk about capturing your Windows 10 & 11 screen without mentioning the Xbox Game Bar, a preinstalled app designed to take screenshots and screen recordings. This app records a number of on-screen activities, such as games and videos with no time limit.
Game Bar is a free screen recorder with a straightforward interface that anyone can understand. It lets you record your screen using hotkeys or by clicking on the corresponding buttons.
Use the steps below to record your Windows 10 & 11 screen with audio via Game Bar:
Step 1: Launch the Game Bar screen recording app on your Windows 10 or 11 computer using the Windows + G buttons simultaneously. Better yet, you can navigate to the quick taskbar and enter Xbox Game Bar in the search field, and click the appropriate icon.
Navigate to the Quick Taskbar and Enter Xbox Game Bar
Step 2: Once the Game Bar app comes up, you will find the recording buttons at the top left corner of your screen with the label Capture on it.
Click on he Microphone icon
Launch the video or game you want to capture to start recording it. To add audio, proceed to where you have the Microphone icon in the Game Bar and click on it.
Step 3: Wait until the screen recording is finished, then click on the Stop button to end the recording immediately. You can find the recorded file underneath the videos folder labeled Captures.
Designed by Adobe, the Adobe Audition software is a powerful audio recording utility built for both amateurs and professionals to capture sounds on Windows. It records your audio in high quality. This software is among the superior choices for capturing your audio because of the powerful features it supports.
Like Screenify, Adobe Audition comes with a host of editing features that you can use to enhance your audio recordings. There’s no limit to the type of content you can capture via this software, as it often records podcasts and music smoothly,
Apply the following instructions to record your audio on Windows via Adobe Audition:
Record Your Audio with Adobe Audition
Yes, you can record your Windows 10 screen with audio simultaneously. Though Windows 10 comes with a built-in recorder, the app has big cons. Game Bar does not support external microphones. You can only record internal audio with it. However, Screenify has worked on this giving you the chance to record both internal and external audio.
The internet is loaded with tons of screen recording tools, which makes selection tough. You might have to test-run each screen recorder you come across to know which is the best one to record your screen with audio.
However, as experts, we’ve handpicked the best 5 screen recorders you can invest in. Find them below:
Having introduced the 4 proven ways to record your Windows screen with corresponding audio narration, select the procedure that’s best for you. Screenify is by far the most reliable screen recording technique from the guide. The software captures your screen with high precision and accuracy. It supports some editing tools you need to manipulate your recordings so they come out with a professional touch.
