Capturing your HP Laptop screen is one of the easiest and quickest approaches available for you to record those on-screen events you find noteworthy. And we will look at 10 ways how to screen record on HP Laptop.
No doubt that screen recording is one of the many professional and cost-free techniques available for you to share information with your contacts online. Whether you are an educator, content creator, gamer, or even a business person, screen capturing will come in handy when you need to share some on-screen activities that you find noteworthy with your contact.
The procedure to follow for you to successfully carry out this operation is pretty easy, but not everyone knows how to. Do you have a similar challenge on your end? If so, then this post is for you, as we discuss the best 10 ways to screen record on HP Laptop. Let’s delve in!
HP Laptops come with an in-built screen recording feature called Xbox Game Bar designed to enable you to capture your gaming screen. You can also leverage this tool to record other on-screen events easily and quickly.
Game Bar lets you record your screen in different dimensions at a zero-cost fee. This tool offers a simple yet professional way to capture your screen, as the resulting content is usually of high quality.
To record your HP Laptop screen using the built-in screen capturing feature, use this instructional guide below:
Xbox Game Bar operating interface
Also Reading: How to Fix Xbox Game Bar Not Working >
Screenify is a powerful screen recording utility suitable for capturing all Windows (including HP), and Mac computer screens with high quality. It lets you record your screen in different dimensions. So whether you need to capture your entire screen, a specific window, or a portion, this tool has got you covered.
With this tool, you can record your gaming screen, live events, and any other noteworthy content you find on your computer screen. Screenify is rated the best screen recording solution because of the maximum flexibility it offers plus quality results.
Screenify lets you enter a preset for your recording so you capture a great recording freely and quickly with no watermark. You are allowed to record your screen with or without audio with this screen recorder. Another fascinating thing about this tool is the comprehensive annotation feature
Key Features
Steps to Screen Record on HP via Screenify
Step 1. Download and Install Screenify on Computer.
Step 2. Launch Screenify on your computer, and select Record screen mode.
Select Record Screen Mode
Step 3. Configure Recording Settings aims to configure settings like system audio before recording.
Set Configure Recording Settings
In this setting menu, you can:
1 Choose the System audio.
2 Choose the Microphone you want to record.
3 Choose the Camera you want to use.
4 Choose whether to add a watermark.
Step 4. Select Recording Screen.
Option 1. Full Screen Record
Please select Full Screen mode and choose the display you need to record. Hit Record button to initiate recording.
Select Full Screen
Option 2. Region Record
To record region, you need to manually select the recording area. After selection, you can still adjust the selected area. It supports customize selection, full screen, and proportional selection based on common social media dimensions.
Record Region
Step 5. Wait for the Recording Countdown.
There is a 3-second countdown to help you prepare the recording after you are ready to start recording.
If you would like to see a recording countdown before your recording starts, you can enable the countdown option. Or you can tap it off. View this post to know how to set the countdown option.
Step 6. Start Recording.
The recording will begin after a 3-second countdown. You can make annotations on the recording interface during the recording.
Annotate the Screen during Recording
With the toolbar, you can add the annotation in the screen:
1 Brush: Draw freehand on the screen recording interface to highlight or illustrate specific areas during the recording.
2 Rectangle: Draw rectangular shapes on the screen recording interface.
3 Text: Add written notes or labels directly onto the screen recording interface.
4 Arrow: Draw arrows on the screen recording interface to point out and emphasize specific areas.
5 Line: Draw straight lines on the screen recording interface to underline or connect specific points.
Step 7. Record Screen Process Completed.
When the recording is completed, you can click the red Stop button to end the recording. Your recorded files will be displayed. From here, you can preview and manage the recorded content as needed.
Preview the Recording
You may also want to know: How to screen record protected videos
OBS is another great screen recording utility that powers quality functionalities to help you screen record your HP Laptop with minimal stress. It lets you create a real-time recording of your screen right from the comfort of your home.
This software allows you to capture video, audio, or a combination of both actions for free. Alongside the screen recording feature, you also get to enjoy live streaming services, as it allows you to view live broadcasts. Other cool features integrated into OBS Studio include scene transition, audio mixer, and preview window.
To record with OBS Studio, check out the guide below:
Screen Recorder for PC – OBS Studio
PowerPoint is a wonderful graphics presentation tool designed to help you create professional looking slides, which are often used in tutorials, seminars, project defense, and more. This Microsoft package also comes in handy when you need to screen record your HP Laptop. Thanks to the built-in screen recording function.
You can count on this program to capture a selected portion of your HP Laptop screen. PowerPoint comes with nice editing tools like trimmer, and cutter. It lets you record your screen, with audio embedded.
Using PowerPoint to record your HP Laptop screen is simple. Check the guide below to do this:
Find Screen Recording Option in the Toolbar
Limitations
With the Icecream Screen Recorder, you can also capture your HP Laptop screen with high quality. The screen recording tool has a comprehensive interface that can be easily managed by anyone, whether novice or professional.
Icecream Screen Recorder allows you to capture webinars, WhatsApp video/audio calls, plus instructional guides freely and quickly. Like Screenify, this tool also comes with a powerful annotation feature that lets you add text, drawings, and arrows to your recordings. One reason it could be used for creating tutorial videos.
Besides screen recording, you can use this software for screenshots, game capture, and audio capture. Recordings captured with this software are either stored on the cloud or directly on your local drive.
Use the stepwise guide below to screen record HP Laptop via Icecream Screen Recorder:
Screen Recorder for PC – Icecream Screen Recorder
For folks looking to record their HP Laptop screen without installing a third-party tool, you can count on some online screen recorders to help you out. Though there are many online tools to use, Screencapture.com is a great option to invest in.
Screencapture.com is a powerful online screen recording utility capable of capturing your HP Laptop screen in multiple dimensions. This program is loaded with cool features such as the share button, which allows you to send recordings to friends, families, and others on your contact list.
You can use the steps below to record your HP Laptop screen using the Screencapture.com online screen recorder:
Clipchamp is a fantastic screen recording solution with versatile recording features that lets you record your HP Laptop screen with or without audio. It allows you to capture your screen, audio, and camera at the same time with minimal stress.
This online screen recording utility offers flexible recording options, as it allows you to resize and customize your recording layout to suit your requirements. With Clipchamp, you can easily capture branded clips with CTAs.
You can follow the directions below to record your screen on HP Laptop using Clipchamp:
Panopto is another online screen recording suite that offers a zero-cost fee screen capturing service on all computer operating systems, whether HP Laptop, Mac, or Linux. This tool lets you create screen recordings, personalized videos, and audio recordings.
Here are the instructions you need to follow to record an HP Laptop screen with Panopto:
Panopto for Chromebook
Limitations
If you need an online screen recording suite that offers a convenient way to capture your screen on HP Laptop free and quickly, Loom is the best tool to use. With this screen recording program, you can easily create short footage of any scene you find online.
Loom makes screen recording simple, quick, and fun to engage in, as it allows you to capture your screen, webcam, or a combination of both simultaneously. Just so you get a recording with a professional look, this online recorder embeds video editing functions. With this function, you can make necessary adjustments to your clips before publishing or sharing them.
To screen record your HP Laptop screen using Loom online screen recorder, check the instructions down here:
Limitations
Screencastify is the last recording option available on this list. It is one of the most outstanding online screen recording programs that offer excellent screen capturing services on HP Laptops, Linux, or Mac.
This online screen recording suite allows you to record engaging footage that you can easily share. Screencastify finds applications in numerous sectors such as education, marketing, engineering, and more. You don’t have to be tech-savvy to use it.
Check these directions given down here to record your screen using Screencastify:
Facecam and Screen Recording Extensions – Screencastify for Chrome
Limitations
Now that we’ve dicussed the various ways to record your HP Laptop screen, and the corresponding screen recording suite to use, which tool is the most ideal HP screen recorder? IIf you find yourself asking a similar question, here are some key factors to consider before making your decision:
The best HP screen recording suite comes with a host of features to ease screen recording process. You should go for a tool that comprise of both screen recording and video editing functionalities, so you don’t start sourcing a professional editing tool to manipulate your recordings after capturing your HP Laptop screen.
Here is another crucial factor to look out for when selecting the best screen recorder for your HP Laptop. Obviously, you don’t want to invest in a screen recorder with expensive pricing plans that you cannot keep up with in the future. So we strongly recommend that you go for a screen recording suite that offers quality services at affordable pricing plan.
Ease of operation is another key factor you need t consider when selecting the best screen recorder for HP Laptops. The screen recording software or program must be simple to operate for anyone, whether experienced in tech space or not. You should be able to find your way and execute all tasks without involving a third-party.
Whether you use the best screen recording suite or are the most skilled video maker, you will likely run into some issues while capturing your screen. Some of the issues include glitches, inability to make payments, and more. When you encounter any of these, you need to contact customer support for a solution. Wiith this in mind, we advise that you invest in a screen recorder with a great support team.
Capturing audio and video on your HP Laptop isn’t a tedious task to engage in once you have the right tool at hand. However, mind you, the quality of the resulting content depends solely on the type of screen recording suite you use.
The most suitable screen recording tool that you can use to record audio and video on your HP Laptop with high quality is Screenify. This software lets you capture your screen with audio, and video in multiple dimensions.
If you are looking to record your HP Laptop via Chrome, then you need to add a screen recording extension to your Chrome. We’ve listed several tools that offer this service in the article above. Here are some of them:
Recording your screen on HP Windows 10/11 is pretty simple. You can leverage the built-in screen recording tool, Game Bar. Otherwise, you select any of the screen recording tools introduced in the article above. Some of the best recording suites include;
Having discussed the various techniques to record your HP Laptop screen, which do you prefer to use? However, mind you, before making your decision, kindly consider the key factors shared in the post. Should you have any suggestions you would like to share, use the comment section.
