This article gives a guide on the “How do you record gameplay on PS4” question. We’ve covered various methods, including the built-in recording features of PS4 as well as an external capture card. Choose the method you like depending upon your situation and share your gameplay with the world.
While playing on PS4, there are moments we all wish to share with the world. But how do you record gameplay on PS4?
Do we need to use some specialized recording tools? Or is there an in-built feature on PS4 for this?
We’ve got the answer to all these questions right here!!! In this article, we’ll show you how to record gameplay on PS4 in a stepwise manner. We’ll discuss every possible method that you can use for different situations.
The PlayStation 4 comes with an in-built recording option. It allows you to capture your gameplay without the need for external hardware. You just need to press some buttons, and your gameplay will be automatically recorded. What’s more interesting is that you can record for up to 720p resolution.
Now, why should we choose the built-in recorder of the PS4? Let’s see.
Here are the steps to record gameplay on PS4 using built-in features.
Step 1. Start your PS4 and launch the game you want to record.
Start Your Game on PS4
Step 2. Press the “Share” button twice on your controller. This will start the recording of your game.
Press the “Share” Button Twice
Step 3. You’ll see a recording logo on your PS4. It shows that your game is currently being recorded. Now, play your game normally.
Start Recording
Step 4. To stop the recording, double-press the “Share” button again. PS4 will stop recording and save the recorded file in the “Capture Gallery.”
Save Recorded Video Clip
If you don’t stop the recording, then it will automatically end after the limit you have set in the settings.
Then, the recorded gameplay will be saved to the Capture Gallery on your PS4. From there, you can edit or share the video as you wish.
Isn’t it easy?
Now, let’s move on to the second method. It uses an external device called a capture card.
Although the built-in recorder of the PS4 is useful, it certainly has some significant limitations. First of all, it can only record for up to 720 resolution and 30 fps frame rate. So, if you want a better quality video, you have to use some other method. Moreover, the editing and customization features of the PS4 recorder are also quite limited. The storage of PS4 is also limited.
But all these limitations can be handled with just a capture card and a PC.
A capture card is a device that connects between your PS4 and a computer. It captures video and audio output from the PS4 and sends it to the computer for recording.
Now, let’s have a look at some reasons to choose a capture card for recording PS4 gameplay.
Connect the Capture Card with PS4 and Computer
Add Video Capture Device as a Source
Click to Start Recording
Before starting the actual recording, run a test to make sure everything is working as expected.
This was all about recording PS4 gameplay with full preparation. But!
What if you encounter an unexpected victory and wish you had recorded that? Let’s help you out in this case.
The PS4 has a feature that automatically records the last 15 minutes of your gameplay by default. This is especially useful when you execute a cool trick or encounter something unexpected in the game. If you don’t save this clip, it will eventually be overwritten by newer footage.
How do you record gameplay on PS4 like this? Let’s see!
Select Save Video Clip
Then, you can go to the Capture Gallery and edit this video.
We have discussed both built-in and capture card methods. Now, let’s give some special tips to the YouTubers since they are the ones who record the PS4 gameplay most of the time.
If you’re planning to use the PS4’s built-in recording feature, it’s important to know that there is a time limit. The system allows you to record up to 60 minutes of gameplay in a single clip. But you can adjust this time limit if you want. Here’s what you need to do:
Head over to the share menu by pressing the “Share” button on your controller. From there, Go to “Sharing and Broadcasts.” Then go to “Length of Video Clip.”
Select Sharing and Broadcast Settings
In this menu, you can set your desired clip length up to a maximum of 60 minutes.
Go to the “Capture Gallery” on your PS4 main screen > Locate the video clip you wish to upload > Select it & press the “Share” button on your controller. This will bring up various sharing options, one of which is YouTube.
Sharing Video Clip to YouTube
If you haven’t linked your YouTube account to your PS4 yet, you’ll be prompted to do so. After that, you can add titles, descriptions, and tags before publishing them to your channel.
If you find that a 60-minute recording limit is not adequate for your needs, use a capture card. This device provides more flexibility in terms of recording duration. It also offers additional features such as higher-quality video and more control over audio settings.
By considering these options, you can choose the method that best suits your requirements for sharing gameplay content on YouTube.
Now, let’s shift our focus to PS5. It’s also popular among many gamers.
The overall concept for recording gameplay on PS5 is similar to PS4. But there are slight differences that you must keep in mind.
We’ll now show you how to start a new recording or record recent gameplay on PS5.
Step 1. Start your PS5 and begin playing the game you want to record.
Step 2. To start the recording, tap the Create button on your PS5 controller.
Press the Create Button
Step 3. After tapping the Create button, you’ll see various options at the bottom of the screen. Select “Start New Recording.”
Start New Recording on PS5
Step 4. The system will now capture your gameplay. A small icon will appear on the screen to indicate that the recording is active.
Step 5. To stop recording, tap the Create button again and choose “Stop Recording” from the menu that appears. Your recorded clip will be saved in the Media Gallery.
Stop Recording on PS5
Here are the steps to record recent gameplay on PS5.
Step 1. After starting your game, press the Create button and select “Save Recent Gameplay.”
Select the “Save Recent Gameplay” Option
Step 2. If you want to save the full video that has been recorded from the start, then select “Save Full Video.”
Save the Full Game Video
Step 3. If you want to save the recent clip, then select “Save Short Clip.” You can use a 15-second or 30-second clip.
Save A Short Clip of 15/30 Seconds
Now, you don’t have to ask, “How do you record gameplay on PS4 or PS5?” ever again.
Before we end, let’s give you another bonus tip.
People don’t just record their gameplay. Taking screenshots of gaming moments is also quite useful. They allow you to save your memorable moments in a still-image format.
So how to take screenshots on a PS4? Let’s see!
Choose Screenshot from Share Menu
How do you record gameplay on PS4? It’s a question that many gamers ask. But the answer to this question is no longer a secret.
In this article, we have shown you multiple ways to record your gaming experiences. You can either use the built-in recording option directly on the console. Or you can use an external capture card for more control over your videos. There’s also an option to record a video clip of your recent gameplay. All these methods have some advantages as well as limitations. So choose the method according to your requirements.
