3 Ways to Record Audio on Windows 11
“I am trying to record audio with few songs and conversations and I am checking out if I can use the microphone on the computer to do that? Is there any option for that?” This is a user’s question from the Microsoft community. Other users of Windows 11 may have the same worry as her. This article will tell you how to record on Windows 11 with audio.
Author Avatar Joy Taylor Last Updated: Jan. 03, 2025
With the development of the Internet and Multi-media industries, more and more people would like to record their lives and post them online. The need for screen and audio recording is increasing. Especially after the Update of Windows 11, users may be confused about how to record on Windows 11 with audio. This article will provide 3 methods to do so.
How to record on Windows 11 with Audio
There are many reasons you need to record audio on your computer. You may need to record a podcast, an interview, a meeting, a lesson, or an audio call. Or you just want to record some messages to note yourself. No matter what situation you belong to, there are many tools and apps you can choose to record audio on Windows 11. If you are having trouble with Windows 11 audio recording, this article will give you 3 solutions.
Part 1. Record Audio on Windows 11 via Screenify
Screenify is comprehensive recording software. Its audio recording feature supports Windows and macOS, having received much good feedback from customers. With a few clicks, you can record and trim your audio as you like effortlessly. To record audio on Windows 11 is just one of the functions of this free multi-media tool. It can also record screen, microphone, and webcam together or separately.
Main Benefits of Screenify:
  • Multiple output formats of audio, including MP3, AAC, and OGG without recording time and number limitations.
  • Noise reduction is practical for getting clear audio.
  • Shortcuts are used freely to start, pause, resume, and stop during audio recording.
  • Recorded audio can be trimmed as you like.
  • Various and flexible recording modes, including 4K & 60 fps video, webcam, and audio.
Having known some features of Screenify, let’s move on to its stepwise guidance on how to record on Windows 11 with audio:
Step 1. Download and install Screenify on your PC. Choose Record audio mode.
Choose Record Audio Mode
Step 2. Select the speaker or microphone device you want for audio recording. Adjust the audio volume as you like.
Select Recording Device
Step 3. After clicking Record, there will be a 3-second countdown for you to prepare.
Prepare for the Recording
If you don’t want to see the countdown, you can tap it off before audio recording on Recording Settings. Click Sreenify Guide to learn how to set it.
Step 4. Then you can begin your recording. The button sidebar can be used to pause and stop your audio recording, and clicking the “4” position can hide the sidebar.
Start to Record Audio on Windows 11
Step 5. After completing the audio recording, you can preview and trim the recorded file.
Preview and Trim Audio
It is a good choice to record audio on Windows 11 via Screenify with its simple steps. Before your recording, you can set the output format, shortcuts, and so on in advance to meet your recording needs. You can also use its toolbar to reduce audio noise.
Part 2. Record on Windows 11 with Audio via Sound Recorder
Another way to record audio on Windows 11 is the built-in Sound Recorder. Similar to Screenify, it can choose an output format and microphone you want to record. However, the Sound Recorder cannot trim the audio. And if your surroundings are noisy, the recording audio may not be so clear. The step-to-step instructions are below:
Step 1. Search Sound Record on the Start Menu. Click it.
Launch Sound Recorder
Step 2. You can choose the microphone you want in the bottom-left corner. Then click the red button to start your audio recording.
Start Audio Recording
Step 3. During your recording, you can click the pause button to interrupt the recording and press it again to continue. When completed, the current recording can be stopped by clicking the stop button.
Stop or Pause Recording
Step 4. After recording, your audio recording will show up automatically on the left side, and you can rename and share it.
The operations of Sound Recorder are not complex, but compared to Screenify,  this app has less function and possibility to record audio, such as noise reduction and audio trimming.
Part 3. How to Record Audio on Windows 11 via Xbox Game Bar
Xbox Game Bar is another choice when you find a solution for how to record on Windows 11 with audio. Built into Windows 11 like Sound Recorder, this application initially aims to capture videos or screenshots when users play games on the PC. Recording audio can also be achieved via this software. The step-by-step operations are as follows:
Step 1. Press Windows + G to enable the Xbox Game Bar.
Activate the Xbox Game Bar
Step 2. Click Audio and choose the microphone you want to record.
Step 3. Click Capture and then click the Start button to begin your recording.
Start Recording on the Xbox Game Bar
Step 4. After your recording, click Stop Recording to complete your audio recording.
Xbox Game Bar is a practical method to record audio on Windows 11, while it can only record both video and audio. If you don’t want to record your screen, you can choose other solutions mentioned above.
Nowadays, audio recording on PC is increasingly important, and it helps us in many aspects of our daily lives. To answer the question of how to record audio on Windows 11, this article provides 3 solutions: Screenify, Sound Recorder, and Xbox Game Bar. We recommend you use Screenify for its simple procedures and various functions for free. Download it now, Screenify waits for you to explore!
