This blog explains how to record audio from YouTube on any device. It covers tools like Screenify, Audacity, Dolby On, AZ Screen Recorder, and Voice Memos. Each method is easy to use and works on different platforms.
Have you ever wondered how to record audio from YouTube on different devices? Whether you’re using a Windows PC, Mac, Android, or iPhone, there are several ways to capture the sound from YouTube.In this guide, we will discuss different tools and apps that make it simple to record high-quality audio across all platforms.
We’ll discuss options like Screenify, Audacity, Dolby On, AZ Screen Recorder, and the iPhone’s Voice Memos app. Each method is easy to use and delivers excellent results. Let’s explore which tool suits your needs best.
You may also like: Best YouTube recording software
Before we discuss recording audio from YouTube, let’s consider the legal aspect. YouTube enables you to download videos for offline viewing. But only if they’re not copyrighted. Recording audio is a bit more complicated. Under copyright law, recording audio is usually okay for personal, non-commercial use. Still, you should check the video’s description, comments, or creator’s website.
You can get an idea of whether there are any specific rules about using their audio. If you’re unsure, it’s ideal to ask for permission from the copyright holder. Or you can talk to a legal expert. Always play it safe.
In this section, we’ll explore how to record audio from YouTube on both Windows and Mac. We’ll look at two popular tools: Screenify and Audacity.
Screenify is a free audio recording tool. It lets you capture high-quality audio without any cost. It’s ideal for recording music, podcasts, or any audio from YouTube.
With Screenify, your recordings are clean and professional. There are no watermarks, so your audio stays pure. This makes it ideal for any purpose, from personal use to sharing online.
Screenify lets you record more than just audio. You can capture your screen, use your camera, and record audio simultaneously. This versatility makes it a powerful tool for various recording needs.
Screenify gives you flexible recording options. You can either capture a part of your screen or the full screen. This feature lets you focus on specific content or multitask while recording.
Screenify is compatible with both Windows and Mac. It’s easy to download, install, and use on either system. This ensures that it will work for you on either computer.
Screenify costs nothing. No need to pay subscription fees or hidden charges. You get all the amazing features at no cost. This makes it an ideal choice for anyone needing a budget-friendly recording tool.
Steps to record audio from YouTube using Screenify:
Step 1. Download and install Screenify on your Windows or Mac computer.
Step 2. Launch it and choose Record Audio. Choose system audio or microphone for recording. You can also choose both to record.
Screenify Record Audio
Step 3. Start recording audio from YouTube when you are ready.
That’s all about Screenify! Let’s discuss the following tool on our list to record audio from YouTube.
Ever wish you could save music, audiobooks, or podcasts from YouTube to your computer? Audacity is a free app that works on both Windows and Mac.
It’s well-known and widely used for recording and editing audio. With Audacity, you can effortlessly record and edit YouTube audio. It’s perfect for both professional editing and simple recording tasks.
Audacity Audio Recorder
Below are the steps to use Audacity to record audio from YouTube on Windows or Mac:
Step 1. Download and install Audacity on your Windows PC or PC.
Step 2. Open Audacity and choose Windows WASAPI (for Windows). You can also select Core Audio (for Mac) as the host in the Device Toolbar. If you can’t see the Device Toolbar, enable it in the settings.
Enable the Device Toolbar in Audacity
Step 3. Select Speakers (for Windows). For Mac, select Built-in Output as the input device in the Device Toolbar.
Step 4. Choose Stereo as the input channel, then start recording your YouTube audio.
Set Up Audacity for Audio Recording from YouTube
Step 5. To save your recording, go to File > Export > Export as MP3 (or another format) and pick a location for your file.
Export Your Music Recording
Now that you know how to record audio from YouTube on Windows & Mac.
In this section, we’ll explore how to record audio from YouTube on Android and iPhone using different apps. We’ll cover tools like Dolby On, AZ Screen Recorder, and Voice Memos. Each tool offers a unique way to capture sound. Let’s dive into the details and see how these tools can help you record YouTube audio easily.
Dolby On is a free audio recorder and editor with advanced Dolby audio technology. You can record live music, videos, or import from your library. It also lets you livestream to Twitch or Facebook Live.
Dolby On automatically applies studio effects like noise reduction, EQ, and spatial audio. Enjoy high-quality sound from a studio recorder right on your phone.
Dolby On
Below are the steps to record music from YouTube using Dolby On.
Start Recording Audio from YouTube in Dolby On
You have seen how simple it is to use Dolby On. Let’s jump to the next tool on our list.
Another way to record sound from YouTube is by using screen recorders. Many apps can do this, but we’ll focus on AZ Screen Recorder. After recording the video, you can convert it into an audio file using a video-to-audio converter. Let’s’ see how to use AZ Screen Recorder.
Install AZ Screen Recorder
Video to MP3 Converter
That’s all about using the AZ screen recorder to record audio from YouTube. Next, let’s move to our final tool.
Voice Memos is a built-in application on iPhones that lets you capture audio easily. It’s straightforward and doesn’t require any extra downloads. You can quickly save any sound directly to your phone for later use. This makes it a convenient option for anyone looking to record audio on the go.
Voice Memos
Here are the steps to record music from YouTube on iPhone with Voice Memos.
iOS Voice Memos
We have covered everything about Voice Memos. Let’s conclude our topic!
It has become incredibly simple to record audio from YouTube with the right tools. No matter you are using Windows PC, Mac, iPhone, or Android, there is a method that works. Tools like AZ Screen Recorder and Dolby On offer easy ways to grab high-quality audio. Also, iPhone’s built-in Voice Memos app is perfect for quick recordings. These options allows you to save your favorite music, podcats, or other audio from YouTube easily. If you’re looking for a user-friendly and versatile option, give Screenify a try. It’s a free tool that works well on both Mac and Windows. Thus making it a convenient choice for anyone who wants to record audio from YouTube.
