Open source screen recorder demand has increased with the online work trend. Open-source screen recorders have become a must-have for online working people. We will discuss the top five open-source screen recorders and their methodology.
The best open-source screen recorder! What do you think what is it? An open-source screen recorder captures your screen with audio, a webcam, and a microphone. Here, you will read about the Top 2024 Open-source Screen Recorders. We will discuss each tool in detail. Let’s get started with what an open-source screen recorder is and check the best open-source screen recorder.
You may also like: Best free 4K screen recorders
A screen recorder allows users to record content on the device’s screen. Open-source screen recording software is a free screen recorder with access to the source code. It has screen capture and many other customizable options. It offers a range of features and functions for screen and audio recording. Open-source screen recorders are popular among skilled users.
Now, here is a list of the top best Open source screen recorders in 2024:
OBS (Open Broadcast Software) is an open-source screen recorder that does not have watermark limitations or recording time limits. It is also compatible with various platforms. Now, let’s discuss its features.
ShareX is a free open-source screen recorder that allows you to record any section of your screen. ShareX allows its users to share a video within a keypress. Users can also upload images and files to over eighty platforms. It is a user-friendly tool that captures your computer or webcam screen. Below, we will discuss its main features.
SimpleScreenRecorder Website Interface
SimpleScreenRecorder is a very simple but rich-featured open-source screen recorder. It lets you record your entire screen or even your desired screen section. It has several preset profiles and allows you to switch between them.
CamStudio is a free desktop screen recorder for Windows. It records your screen content and system audio. It generates industry-level AVI files. It has a built-in SWF producer and turns videos into bandwidth-friendly Streaming Flash Videos (SWFs).
Captura Interface
Captura is free, open-source screen recorder software. It lets you capture your screen, mouse clicks, and keystrokes. It is best for gaming videos, tutorials, and presentation purposes. Users can customize the frame rate and video and audio quality settings. It also allows video editing, like adding text, shapes, and effects to the video. Now, let’s discuss its features.
Since open-source screen recorders are complicated to use, let’s move on to the details of the most easy-to-use screen recorder, Screenify.
Screenify is the best free screen recorder available for Windows and macOS. Screenify has 4K resolution quality and a 60FPS frame rate. Also, it is watermark-free. You can record the screen for an unlimited time.
It lets you capture the entire screen, as well as specific areas or individual windows. Screenify also supports camera and audio recording and includes noise reduction.
It also allows you to add text watermarks and trim videos after editing.
1. Download and launch Screenify on your Mac or PC. Now select the recording mode.
Select the Recording Mode
2. Configure the settings before recording.
Hit the Record Button
3. Now, choose the recording screen. It has two options: either record full screen or a specific region.
4. Select your preferred mode and hit “Record.”
5. To record a specific region, manually select the region with your cursor. It also provides social media dimensions to choose from.
6. Now, there will be a three-second timer. After this countdown, the recording will start.
7. You can add annotations while recording the screen. You have brush, shape, text, arrow, and line options here.
8. After you have finished recording, click on the Red “Stop” button. Your video will be displayed, and now you can preview and edit it.
Now, we will compare all the screen recorders mentioned above to find the best one for you.
Feature | Screenify | OBS Studio | ShareX | SimpleScreenRecorder | CamStudio | Captura |
Price | Free | Free | Free | Free | Free | Free |
Video Quality | 4k recording and 60Fps frame rate | Customizable video quality settings | Good video quality | Customizable video quality settings | No limit on recording time | Good video quality |
maximum recording time | Unlimited recording time | Unlimited recording time | Adjustable recording time | Extended recording time | It has limits on file size | Maximum recording time |
Watermark | No watermark | No watermark | No watermark | No watermark | No watermark | No watermark |
We have discussed 5 open-source screen recorders that are popular among users. However, if you are a new starter in screen recording, Screenify can be a better choice due to its clear interface and easy steps. Try Screenify for free now and enjoy a wonderful screen recording.
