5 Best Messenger Call Recorders 2024
This article reviews the top 5 Messenger call recorders available in 2024 for different platforms. We have provided detailed insights into each tool, including free options. Follow our guide for step-by-step instructions and record calls on various platforms.
Author Avatar Joy Taylor Last Updated: Sep. 03, 2024
In today’s world, communication happens at the click of a button. Recording messenger calls has never been more important. If you want to capture those important calls, this blog will explore the top 5 picks across different platforms. We will discuss different Messenger call recorders for Windows, Mac, Android, and iOS users and discover some free options. We have also set up guides for using these Messenger call recorders.
Also read: How to record FaceTime call with audio
Part 1. What is a Messenger Call Recorder
Facebook Messenger does not offer a built-in feature to record calls. Some Android phones can record calls, but this usually only works for regular phone calls. You need a special tool or app designed to record these calls. These Messenger call recorders capture audio and sometimes video of your conversation. You can save these recordings to listen to or watch them later. This is useful if you want to record important calls, like work meetings or personal conversations with friends and family.
Part 2. Best  Messenger Call Recorder 2024
We have selected the top 5 Messenger call recorders for 2024. The selected tools are compatible with different platforms with benefits and useful features. Whether you’re looking for a free solution or advanced features, we’ve got you covered. Let’s have a detailed look at our first and favorite tool.
1. Screenify-100% Free for Windows & Mac
Screenify is the best screen recording tool for Windows and Mac users. Screenify stands out as the best Messenger call recorder. It offers high-quality recording without hidden costs. Moreover, it does not limit recording time, display watermarks, or annoying ads. With Screenify, you can capture messenger calls with ease.
Key Features of Screenify:
  • Free and Unlimited Recording – Record without any time limits or watermarks, and enjoy a free experience.
  • High-Quality Video and Audio – You can capture your Messenger calls in up to 4K resolution with 60 frames per second.
  • Real-Time Annotation Tools – It offers multiple drawing tools, shapes, and text to highlight important information during calls.
  • Noise Reduction – Automatically reduce background noise to ensure the recordings are clear and focused.
  • Simple and Intuitive Interface – Offers easy-to-use controls even for beginners.
  • Flexible Export Options – You can save your recordings in multiple formats like MP4, MOV, or even as GIFs, and easily share them with others.
Steps to Record Messenger Calls via Screenify:
Step 1. Download Screenify from the official iMobie website and install it on your computer. It is available for both Windows and Mac.
Step 2. Launch Screenify and select your record mode.
Screenify Main Screen
Step 3. Configure the settings before starting the screen or audio recording. Choose a full screen or a region of screen that fits your needs.
Screenify Full Screen Record
Step 4. Select your speakers and microphone, and hit the record button to start recording.
Screenify Record Audio
Step 5. Screenify will start recording the screen after a 3-second countdown. During screen recording, you can use different annotation tools to illustrate something.
Step 6. Press the stop button to finalize your recording. You can now preview and manage the recorded content.
Now, let’s move towards the next choice.
2. Cube Call Recorder – Best for Android
Cube Call Recorder is an easy-to-use app for Android phones. You can set the app to record all your calls automatically or just those you choose. It also works well with VoIP calls, meaning it can record calls made over the Internet. So you can record any WhatsApp, Messenger, or Skype calls. The app records both sides of the call clearly. You can also save your recordings to cloud storage, such as Google Drive. The app is simple and allows you to listen to, edit, or share your recordings with others. Let’s learn how to set up and use the Cube Call Messenger call recorder.
Steps to Record Messenger Calls via Cube Call Recorder:
Step 1. Download Cube Call from the Play Store.
Step 2.Grant permissions to the app.
Step 3. Enable its overlay over the other apps.
Step 4. Set up Auto Reconnect and VOIP Settings. The app is now ready to record calls as per your choice.
Settings in Cube Call Recorder
Cube Call works only for Android. We have another solution for you if you want to record Messenger calls on iPhone or iPad. Let’s explore our next choice.
3. Rev Call Recorder Best for iOS
Rev Call Recorder is an effective and reliable call-recording app for iPhone users. You can easily record calls on Messenger and other apps with Rev call recorder. The app supports both incoming and outgoing calls. Rev Call Recorder offers clear audio quality, ensuring that both sides of the call are recorded clearly. Once your call is recorded, you can easily play it back, share it, or even transcribe it into text. This app is free to use, and the length or number of calls you can record is unlimited. Let’s learn to use this app.
Steps to Record Messenger Calls with Rev Call Recorder:
Step 1. Download and install the Rev Call recorder on your iPhone/iPad.
Step 2. Accept the incoming call or make a call over Messenger or other apps.
Step 3. Launch the Rev Call Recorder and start recording your calls.
Record Calls With Rev Call Recorder
If you don’t want to install software or apps, we have an online solution for you. Let’s explore the online Messenger call recorders.
4. VEED. IO – Online Messenger Call Recorder
VEED. IO is an easy-to-use online tool for recording Messenger calls. You can use VEED. IO on any computer, tablet, or smartphone device. It works directly from your web browser, so there’s no need to download any software. VEED. IO is a convenient choice for anyone looking to record Messenger calls without installing an app. This tool can capture audio and video of your calls with clear quality. Let’s learn how to use this.
Steps to Record Messenger Calls with VEED. IO:
Step 1. Visit Veed.io website and click “Start for Free.”
Step 2. Click the “Record Video” button.
Step 3. Choose the recording mode that you like. It has different options like camera only, audio only, screen only, etc.
Screen Recording Mode in Veed. io
Step 4. Allow the website permission. Share the browser tab, window, or entire screen with veed.io. It will start recording both the sound and audio of messenger calls.
You can edit the recorded calls using VEED.IO’s built-in editor. This makes trimming, adding subtitles, or making other adjustments easy. You can then save your recordings or share them directly from the platform. Let’s explore another free solution for recording Messenger calls online.
5. ScreenApp – Online Messenger Call Recorder
ScreenApp is also an online tool for recording Messenger calls. You can use it directly through your web browser, so there’s no need for downloads or installations. You can use ScreenApp online on computers, tablets, and smartphones to record sound and video. After you’ve recorded your call, you can quickly save the file or share it as needed. It offers free usage but more options and unlimited recording sessions are unlocked after you purchase their pakage. ScreenApp is a perfect solution for those who want to record Messenger calls without any extra steps.
Steps to Record Messenger Calls with ScreenApp:
Step 1. Visit the ScreenApp website and click “Start Free.”
Step 2. Log in or sign up and then Click “New Screen Recording” inside the “Upload, Import or Create” menu.
Step 3. Allow permission to the website.
Step 4. Click start recording.
Step 5. Choose the Browser tab, window or entire screen and click “Share”.
New Screen Recording in ScreenApp
Record your screen with video calls and enjoy. Now let’s check out a comparison chart of all our Messenger call recorders. This will make the choice easy for you.
Comparison of 5 Top Messenger Call Recorder
You can check this comparison table and select the most suitable Messenger call recorder option for you.
Recorder Platform Free/Paid Editing Features Recording Options Audio Recording
Screenify Windows & Mac Free to use – No limits Basic Editing Tools Full-screen, Specific app, Picture-in-picture High-quality Audio with Noise Reduction
Cube Call Android Paid only No Editing Features Audio only Clear Audio
Rev Call iOS Free Transcribe recording, playback, and sharing Audio only High-Quality Audio
VEED. IO Online – any platform Limitations – Depends on plan Built-in Editing Tools Screen and Audio Recording High Quality Audio with Editing options
ScreenApp Online – any platform Limitations – Depends on plan No Editing Features
Sharing options
Screen and Audio Recording Clear Audio
Apps and online solutions are designed for a targeted audience. Let’s check out which specific app is best for you.
Best Suitable Choice For:
Screenify – Users who need a free and flexible tool for recording calls on a computer.
Cube Call Recorder – Android users who want an automatic call recorder for Messenger and other apps.
Rev Call Recorder – iPhone users looking for a reliable and free call recorder with transcription options.
VEED.IO – Users who need a web-based tool for recording and editing Messenger calls.
ScreenApp – Users are looking for a simple, browser-based tool to record Messenger calls without extra features.
This article compares five of the best options available for a Messenger call recorder. Screenify stands out as a prominent choice if you have access to a computer. It’s easy to use, works on both Windows and Mac and has no limits. You can record both audio and video in high quality, with no watermarks or ads. If you want a reliable and free tool to record Messenger calls, try Screenify.
