12 Loom Alternatives You Can Try for Free [2025]
We’ve listed 12 great Loom alternative options for recording videos and sharing screens easily. These tools help you communicate and collaborate effectively without spending money. We recommend using Screenify, an efficient screen recording tool, for high-quality recordings and a smooth user experience.
Author Avatar Joy Taylor Last Updated: Feb. 27, 2025
If you’re looking for free alternatives to Loom in 2025, this list will help! While Loom is a superb tool for sharing your screen and creating movies, other equally useful, free apps are available. This guide discusses twelve free alternatives for Loom. Using these tools, you may quickly record your screen, create tutorial videos, and send them to others. We also recommend Screenify, a simple and efficient screen recording tool, for smooth recording and easy sharing! So, let’s begin to explore these Loom alternative options!
Part 1: What is Loom?
You can quickly make, edit, and share videos using Loom, a free screen recorder. You may record and capture screen and audio on Chrome, Windows, Mac, iOS, and Android devices. Adding external links to your recordings, sharing with immediate links, and editing videos in the browser are just a few of its features. Nonetheless, there are also disadvantages, such as a 720p video stream in this free version and a restriction of five minutes for each video file. Unfortunately, for longer, higher-quality recordings, one has to subscribe to the pro version of the tool.
Part 2: 12 Loom Alternatives You Can Try For Free
Now, let’s explore 12 Loom alternatives you can try for free:
1. Screenify
Interface of Screenify
Screenify is a fantastic alternative to Loom. It offers unlimited recording time and 4K resolution at 60 FPS for high-quality screen capturing on Windows and macOS. Ideal for gamers and content creators, this versatile tool allows you to add custom text watermarks and offers flexible recording modes, all for free. With its user-friendly interface, Screenify makes professional-grade recording easy for everyone.
Key Features:
  • Record in 4K at 60 FPS, ensuring smooth, high-quality videos with crisp details.
  • Personalize your videos by adding custom watermarks to reflect your brand or style.
  • Flexible recording options include full-screen, specific windows, or selected screen areas.
  • Save in multiple formats to suit your video editing and sharing platform needs.
Check out the simple steps to use Screenify Screen Recorder below:
Step 1. Begin by installing Screenify on your device to set up for recording.
Step 2. Open Screenify and click on the “Record Screen” option to begin capturing.
Select Record Screen Mode
Step 3. Adjust your audio settings to ensure clear recording from both sides.
Record Setting
Record Setting
Step 4. Select the area to record. You can choose “Full Screen” or drag to define a specific section. Resize as needed for social media. After that, click “Record.”
Full Screen
Full Screen
Step 5. A three-second countdown will appear, giving you time to get ready.
Start recording countdown
Step 6. Once the countdown ends, your recording will start. If needed, you can add annotations or notes during the recording.
Annotate the Screen during Recording
Step 7. Once done, choose “Stop” to finish the process. Review, edit, and save your video to avoid black screen issues.
Preview the Recording
2. Camtasia
Camtasia
Camtasia
Camtasia is a powerful alternative to Loom, offering crystal-clear screen recording and advanced video editing features. You can capture a PC screen in 1080p UHD at 60 FPS. It allows you to easily capture the screen, camera, microphone, and system audio at the same time. The tool includes AI-powered editing, drag-and-drop transitions, and dynamic effects for professional video creation.
Key Features:
  • Capture screen, camera, mic, and system audio on separate tracks for flexible editing.
  • Drag-and-drop transitions and callouts simplify video editing for beginners and pros.
  • Dynamic backgrounds and captions add an extra touch to social media content.
  • AI-powered editing helps streamline workflows for faster, high-quality video production.
Limitations:
  • High cost compared to other tools.
  • The learning curve for advanced features.
3. Vidyard
Screen Recorder Extension for Chrome - Vidyard
Vidyard
Vidyard is an excellent alternative to Loom, letting users record their webcam and screen for free. It’s ideal for producing high-quality films quickly and easily because of features like editing tools, 4K video resolution, and simple sharing choices. With each recording, get limitless bandwidth and ad-free playback.
Key Features:
  • Record your screen or webcam in up to 4K resolution for stunning video quality.
  • Use on-screen speaker notes to stay organized and focused during your recordings.
  • Easily track video performance with view counts and notifications for better engagement.
Limitations:
  • Requires a browser extension for recording.
4. OBS Studio
Open OBS Studio
OBS Studio
OBS Studio is also a suitable tool similar to Loom because it is a free and open-source program for streaming and recording. It supports real-time video/audio capturing and recording multiple scenes with diverse transitions. It has an audio mixing tool with per-source filters and a structural UI design suitable for a specific layout. Furthermore, you capture your laptop’s screen in 1080p UHD quality at 60 frames per second, which even supports any videos/animations being played on the screen.
Key Features:
  • OBS Studio offers unlimited scenes for seamless transitions during streams.
  • You can set custom hotkeys for quick scene switching and other actions.
  • Use VST plugin support for enhanced audio control.
  • The Multiview feature lets you monitor up to eight scenes at once.
Limitations:
  • No built-in video editing tools.
  • Setup can be complex for beginners.
5. Screencastify
Screencastify
Screencastify
Screencastify is a fantastic Loom alternative designed specifically for educators. It allows users to create and share interactive videos easily. Its best features include an AI Assistant, a Premium Library, and translation into World Languages, making communication and learning more engaging and accessible for students and teachers alike.
Key Features:
  • The AI Assistant helps you quickly generate titles, descriptions, and captions for your videos.
  • Access a Premium Library to convert YouTube for Education videos into interactive student lessons.
  • Translate captions into over 50+ world languages to reach a wider audience effectively.
  • Use video for instruction, assessment, and student creation to enhance learning experiences.
Limitations:
  • Limited editing features.
  • Some functionalities require a premium subscription.
6. ScreenPal
Screen Record with ScreenPal
ScreenPal is a fantastic alternative to Loom. It offers free screen recording, webcam capture, and audio narration. It also provides features like background removal, video editing, and quick sharing without the need for sign-up or watermarks, making it a simple, powerful solution for creating professional videos.
Key Features:
  • Record any part of the screen and audio with easy-to-use, customizable screen capture tools.
  • Webcams with background removal allow clear recordings and enhance messages or branding.
  • Create and share animated GIFs and add background music or sound effects for added creativity.
Limitations:
  • The free version is limited to basic effects.
7. Snagit
1080p Screen Recorder - Snagit
1080p Screen Recorder – Snagit
Snagit is an excellent alternative to Loom, ideal for effortlessly capturing screenshots and recording your screen. It allows users to capture displays in 4K at 60 FPS. Features like scrolling capture, audio recording, and text recognition help users effectively communicate ideas and processes through annotated visuals. Snagit is perfect for professionals who need advanced screen capture tools.
Key Features:
  • Capture Your Screen easily with options for full screen, regions, or scrolling areas for flexibility.
  • Use Custom Presets to create shortcuts for your most frequent screen capture tasks and improve efficiency.
  • Scrolling Capture lets you capture entire web pages in one go, avoiding the tedious stitching of images.
  • The Library organizes your content neatly, allowing you to easily filter and sync across devices.
Limitations:
  • It may require time to learn all the features.
  • Some advanced options may overwhelm new users.
8. Zight AI
Zight AI
Zight AI
Zight AI is a powerful alternative to Loom for creating engaging visuals and videos. With features like 4K Screen Recording, Screenshot Annotation, and AI-powered titles, Zight AI makes it easy to produce high-quality content quickly. This tool enhances productivity by automating many video production tasks, making communication effortless and effective.
Key Features:
  • The screen recorder lets you record your screen, voice, and face for personalized videos.
  • Use Screenshot Annotation tools to instantly capture, edit, and share your ideas with helpful visuals.
  • Create dynamic GIFs from your screen content effortlessly, adding captions and stickers for flair.
Limitations:
  • It may have a learning curve for beginners.
9. HitPaw Screen Recorder
The Best Online Video Shanper - Hitpaw
HitPaw Screen Recorder is an excellent alternative to Loom. It is designed for seamless screen and webcam recording and offers features like 144 FPS gameplay recording, customizable recording areas, and Green Screen functionality. You can also record audio, schedule recordings, and stream to over 30 platforms effortlessly.
Key Features:
  • Record both screen and webcam simultaneously for engaging presentations and tutorials.
  • Use the scheduled recording option to automate capture for timed events or meetings.
  • Capture full-screen recordings or select specific areas for more focused content.
Limitations:
  • Performance can lag on older devices.
  • Editing tools are limited compared to advanced software.
10. Soapbox
Mac Screen Record Software - Soapbox
Mac Screen Record Software – Soapbox
Soapbox is an excellent Loom alternative for quickly creating professional pitches, presentations, and demos. This freemium Chrome extension from Wistia lets you record your screen, capture your webcam, and switch between full-screen and split-screen views effortlessly. There is no need for complex setups, so that you can create polished videos quickly.
Key Features:
  • Instant Sharing allows you to share your videos right after recording without the hassle of processing.
  • The Freemium Model gives you access to powerful tools without investing in expensive equipment.
  • User-Friendly Interface ensures that anyone can start creating videos with just a click.
Limitations:
  • Limited advanced editing features for detailed video customization.
  • Reliance on Chrome may restrict some users.
11. ScreenRec
Screenrec Website Interface
ScreenRec is a simple Loom alternative that lets you record your screen, computer sound, voice, and webcam with no watermarks or time limits. It’s great for making clear, high-quality videos with cloud recording and a lightweight setup for smooth use. No need to add any watermarks to your screen recordings! However, to improve the recording quality to 1080P, you’ll need to buy a premium plan.
Key Features:
  • Record computer audio clearly for better, professional-sounding videos.
  • Instant sharing via cloud link without needing to wait for uploads.
  • No watermarks or time limits, ensuring clean and polished recordings.
Limitations:
  • No advanced video editing features.
  • Requires internet for cloud sharing.
12. Sendspark
Screen Recorder Extension for Chrome - Sendspark
Sendspark
Sendspark is a great Loom alternative that lets you easily record yourself and your screen. It’s perfect for creating videos with PowerPoint, PDFs, and more. The desktop app auto-updates, so you only need to download it once.
Key Features:
  • Record yourself over presentations for clear and engaging content.
  • Works with PDFs and quotes to make explanations simple.
  • Available for Mac and Windows, offering flexibility for all users.
Limitations:
  • Requires restarting after updates.
Part 3: Conclusion
In conclusion, a reliable screen recording tool can significantly enhance your video creation experience. With features like easy sharing, editing options, and high-quality recordings, these tools help you communicate effectively. They make creating engaging content simple and efficient. Consider downloading and using Screenify for all your recording needs; it’s a great option!
Part 4: Frequently Asked Questions
1. Is there a free version of Loom?
Yes, Loom offers a free version. It allows you to record videos, but its features are limited. It’s good for basic video recording needs with 5 minutes of recording time and 25 video limit storage.
2. Is there a better alternative to Loom?
Yes, there are many alternatives to Loom. Some popular ones are Screenify, Vidyard, Snagit, and Soapbox. They have similar features and can suit different needs.
3. Does Microsoft have something like Loom?
Yes, Microsoft has a tool called Microsoft Stream. It lets you record and share videos easily. It’s great for teams and works well with other Microsoft apps.
