In this article, we will learn how to screen record on a Lenovo laptop. We will explore three methods along with their step-by-step guides. We will also introduce you to Screenify, a new screen recorder with impressive features. Moreover, if you want to record the Lenovo laptop screen with audio, this article will cover that, too!
Download Screenify to record screen with audio on Lenovo laptop for free! Supports recording full screen, specific screen, audio, camera, etc. Just record as you like!
There are a large number of users of Lenovo laptops worldwide. More and more users want to capture the screen on Lenovo laptop and search for an easy way. This article will introduce some efficient methods to record screen on Acer laptop for free. Whether it is recording your gaming session, any tutorial, or a simple presentation, that’s pretty easy. You can follow their step-by-step guides and record your screen. Furthermore, we will also learn how you can record the Lenovo screen with audio. Let’s dive in!
You may also like: How to record screen on ThinkPad
Yes, there is a built-in screen recording tool in Lenovo laptops known as the “Xbox Game Bar.” More accurately, it is a Windows built-in screen recorder. This built-in tool is very convenient and doesn’t require any downloading. However, it has some limitations. It might not work with all applications. Also, it lacks advanced features like editing and adding annotations. But for simple screen recording tasks, it’s a great option.
Let’s move forward and explore how to screen record on a Lenovo laptop using Xbox Game Bar and other methods.
Recording Lenovo laptop screens can be easily done using OBS Studio. It is an open-source software program for recording videos from a screen or directly streaming them. Creators, gamers, and streamers mainly use OBS Studio.
This software is unique because it can work on various operating systems without any restrictions. It is free to download on Windows, Mac, or any Lenovo OS. Additionally, this application works with various streaming sites like Twitch, Facebook, and YouTube, among others. People like it because of its enhanced functionalities and simplicity of usage.
Here is how to screen record on Lenovo laptop via OBS Studio:
Step 1. Go to the OBS Studio website and download the app. Then, install it on your Lenovo laptop.
OBS Studio Website Iterface
Step 2. Open OBS Studio. It might look confusing at first. Click the “+” button under Sources to add a new source to record. Select the “Display Capture” option and click “Ok.”
Select Display Capture and Click Ok
Step 3. Next, adjust the settings, such as frame rate, resolution, and audio input, to your preference.
Step 4. Once you have configured all the settings, navigate to “Controls” at the bottom left and click “Start Recording.” OBS will begin recording your Lenovo screen.
Start Recording in OBS
Step 5. When you’re done, click “Stop Recording.” Your video will be saved to the location specified in your OBS settings.
So, this is how to record screen on Lenovo laptop via OBS Studio. It can be helpful, but if you want a more reliable and efficient way, you can try the next one.
Screenify is a screen recorder with impressive features. It’s free to use and offers HD recording without watermarks. Screenify supports both Windows and Mac, making it versatile for different devices. This screen recording tool is designed with user convenience in mind and offers a user-intuitive interface.
Some of the key features of Screenify are given below:
How to record screen on Lenovo laptop using Screenify:
Step 1. Launch Screenify and choose Record Screen.
Screenify Main Page
Step 2. Here you can choose how to record your screen on Lenovo laptop, in full-screen or partial screen.
Customized Screen Recording in Screenify
Step 3. Set the audio recording details if you need to.
Screenify Record Audio
Step 4. Start recording. Once finished, preview and export your recorded files in your preferred format.
Preview and Export Recorded Videos Screenify
The Xbox Game Bar is a built-in feature introduced in Windows 10 and later Windows. It is designed for gamers, but you can use it to record some screen activities.
This tool is easy to access. There is no need for extra downloading. You just need to set it up on your Lenovo laptop.
As discussed in Part 1, this tool is perfect for simple screen recording tasks. While it lacks advanced features, it’s a convenient option for quick recordings.
Here is how to record screen on Lenovo laptop using the Xbox Game Bar:
Step 1. Press this keyboard shortcut: “Windows key + G.” This will open the Xbox Game Bar. If you are using it for the first time, you will be asked to sign in (Not necessary for recording).
Open the Xbox Game Bar Overlay
Step 2. Go to the capture widget and click the “Start Recording” button. You can use the shortcut key “Win + Alt + R” as well.
Start Recording in Xbox Game Bar
Step 3. Once you are done recording, click the “Stop Recording” button in the capture widget. You can also stop recording by pressing “Win + Alt + R” again.
Although this method is pretty easy and readily available, it has drawbacks. You can capture using the Xbox Game Bar’s screen recording feature only in game mode.
This means it is limited to recording gameplay only. If you’re a gamer who likes recording your game streaming, it will be very useful.
But if you want to record some other activities that are being carried out on your Lenovo laptop and want an audio recording as well, keep reading to the next part.
There are several ways to record screens with audio on a Lenovo laptop. However, we will explore OBS Studio software, the one we explored earlier. This tool can also help you record your screen along with the audio, making the recordings more lively and interactive. You can use the audio input either from your computer or microphone.
Here is how to record screen with audio on Lenovo laptop:
Step 1. Download the OBS Studio, launch it, and select the “Display Capture” option.
(Navigate to method 1 to see how to select it).
Step 2. Once you have selected that, click the “+” sign under the “Sources” box again and select “Audio Input Capture.”
Select Audio Input Capture
Step 3. Choose your microphone or system audio as the audio source and click “OK.”
Step 4. Click the “Start Recording” button to record your screen and audio. Then, perform the screen activity you want to capture on your Lenovo laptop.
Click Start Recording
Step 5. When you are done, click the “Stop Recording” button. Your screen recording will be saved automatically in the default location.
1. How do I record screen on Lenovo laptop?
Press the Windows and G key together to launch the default screen recording tool on Lenovo laptop. Then set your own way to record screen and export the recorded videos.
2. How do I record my screen on Lenovo Chrome?
You can use some screen recording extensions to capture the screen on Lenovo Chrome. Or you can use Screenify for any kind of screen recording.
Wrapping it up! This article has explored how to screen record on a Lenovo laptop. It is simple with the right tools. We have explored various methods, including the Xbox Game Bar, OBS Studio, and the upcoming Screenify. You can follow any method that fits your needs. If you want quick recordings without any extras, then Xbox Game Bar is for you. On the contrary, if you want advanced features and high-quality recordings, OBS Studio might be the best option. Furthermore, Screenify promises high-quality recordings without watermarks. So, keep an eye on its official launch.
