A video speaks millions of words, just like a picture! Screen recording is an indispensable function, whether you want to capture a film for later viewing or use it to troubleshoot your HP laptop running Windows 10/11. But thanks to a variety of efficient solutions, capturing the screen of your HP laptop is no longer a problem.
From built-in screen recording tools such as Xbox Game Bar to reliable third-party software Screenify, you can utilize any program to share your game progress, tutorial, or instructional videos with your loved ones. Choosing the right tool can make a difference in recording quality videos and smoothening the process. Let’s explore how to screen record on HP laptop with sound in this detailed guide.
You may record your screen without installing any additional software on your HP laptop, regardless of whether it is running Windows 10 or 11. For this reason, built-in screen recording features such as the Xbox Game Bar work well. There is no complex technique required to screen record your HP laptop using the Xbox Game Bar, even while utilizing the shortcut keys.
Additionally, you may use the Game Bar to examine the performance of your PC, including the CPU, GPU, RAM, and other components. Nevertheless, you may capture the screen of your HP laptop even if the game isn’t open.
Here’s the complete guide to recording screen on HP laptop via Xbox Game Bar:
Step 1. Launch the Xbox Game Bar on your HP Laptop. There are two ways to launch it: via a search bar or shortcut keys. Search “Xbox Game Bar” in Windows search or press the Windows key + G (Shortcut keys) on the keyboard to open it.
Launch Xbox Game Bar
Step 2. You’ll see the floating toolbars and multiple options to adjust. Click on the “Settings” button from the above toolbar to adjust the settings such as widgets, shortcut keys, and more.
Xbox Game Bar Settings
Step 3. You can configure settings such as maximum recording length, video frame rate, video quality, cursor movement capture, and more. To adjust these settings, navigate to “Settings> Gaming and then Captures.” The maximum video length can be up to 4 hours, and the frame rate can go to 60 FPS.
Xbox Game Bar Captures
Step 4. Choose to record the “System Audio” and “Microphone” or both during the screen recording. Adjust the volume with the sliders. Once done, click on the “Start Recording” button to initiate the screen recording process.
You can also press the “Windows Key + Alt + G” to quickly start the screen recording.
Start Recording in Xbox Game Bar
If Xbox Game Bar is not opening on your HP laptop, you’ll need to enable it first from the settings. Navigate to “Settings” on your PC and then “Gaming”. Click on “Xbox Game Bar” and toggle to turn it ON.
While recording a winning moment in your gameplay or an instructional video on your HP laptop, sound capturing is an important step. Screen recording with sound will be easy to comprehend and can engage users effectively. If your HP laptop is recording a screen without system sound and microphone audio, chances are that you might have audio disabled during the recording.
Let’s find out how to screen record on HP laptop with sound.
To start screen recording with system sound or microphone, you’ll need to enable the audio recording first:
Step 1. Navigate to “Settings” and then “Gaming” from the left pane. Click on “Captures” to open the settings of the Xbox Game Bar.
Step 2. Toggle to turn ON the option “Capture audio when recording a game.”
Here’s the complete guide to recording screen on an HP laptop via Xbox Game Bar with sound:
Step 1. Launch the Xbox Game Bar on your HP Laptop. Search “Xbox Game Bar” in Windows search or press the Windows key + G (Shortcut keys) on the keyboard to open it.
Step 2. You’ll see the “Audio” window on the screen. Adjust the volume for “System Sounds” with the sliders in the Mix tab.
Record System Sound in Xbox Game Bar
Step 3. Navigate to the “Voice” tab and then choose the input source for “Microphone”.
Record Microphone in Xbox Game Bar
Step 4. Once done, click on the “Start Recording” button to initiate the screen recording process.
If you’re on the lookout for an advanced screen recording tool for your HP laptop, look no further! Screenify is an all-in-one screen recorder that allows you to capture what’s happening on the screen. The best part about this tool is its multiple-screen recording modes. You can either capture a full screen or a part of the screen, keeping your privacy intact while recording the screen of your laptop.
Another feature called Lock Window is worth mentioning when talking about privacy. You can lock the recording window so that no other contents can be recorded except the opened application/window— even the camera recording will not work in this mode. Whether you want to record an online course training lecture, technical support video, or game content, Screenify will never disappoint in any scenario!
The shortcut key to record the screen on a laptop is Windows Key + Alt + R. Once you press the keys, a screen recording icon will appear in the corner, showing the timer.
You can capture the screenshot on an HP laptop by pressing the Windows Key + PrtSc (print screen) Key simultaneously. The screen will become dim for a moment, showing that the screenshot has been captured. You can also capture screenshots by pressing Windows Key + Shift + S in the snipping tool.
Whether you want to create a technical support video for software or record your winning moment in a game, recording your laptop’s screen is an easy way to do this. Wondering how to screen record on HP laptop? You can record your HP Laptop’s screen using the Xbox Game Bar— a built-in screen recorder tool. Apart from this, you can also use Screenify to screen record with no time limits in 4K/60 FPS quality alongside system audio and microphone.
