7 Ways to Screen Record on Dell Laptop
Do you want to screen-record your Dell laptop? The seven tools allow you to record your lectures, PowerPoint presentations, webinars, and gameplay.
Author Avatar Joy Taylor Last Updated: Sep. 05, 2024
Screenify – Record Screen on Dell Laptop
Try Screenify for free to record screen on Dell laptop. Whether full-screen or partial-screen recording, recording with sound or with the camera, Screenify can do it with ease.
Record Now
100% Clean & Safe
Screen recording lets you live stream your gameplays, record webinars, save PowerPoint presentations, record lectures, make tutorial videos for YouTube, and much more.
Since COVID-19, online meetings and lectures have increased screen recording functionality. Screen recording and screen sharing are important parts of online interaction. Many live streamers share their gameplay via screen recording.
Depending on the type of device, the operating system, and the version of the operating system, there are several ways to screen record.
Here, we will emphasise screen recording on a Dell laptop. These methods are also applicable to other Windows laptops.
How to Screen Record on a Dell Laptop with Game Bar
If you are using Windows 10 or Windows 11, one way of screen recording and taking screenshots is through the built-in Game Bar. You can record your gameplay and live stream.
The steps of screen recording on your Dell laptop by Game Bar are as follows,
Step 1 – Press the Windows key + G
Step 2 – Choose ‘Yes, this is a game.’
Step 3 – Click the ‘Record’ button or press the Windows key + Alt + R to initiate recording.
Start recording with Xbox Game Bar
Step 4 – Press the Windows key + Alt + R to end the screen recording.
You can access the recording video from Videos > Captures.
Let’s move to another way of screen recording your Dell laptop via OBS Studio.
How to Record a Video on a Dell Laptop via OBS Studio
Open Broadcaster Software (OBS) studio is a third-party application for screen recording and live streaming. It is available for both Windows and MacOS. It is free to use.
You can download it from the Website. The steps for screen recording a Dell laptop using OBS Studio are as follows,
Step 1 – Launch OBS Studio and click the ‘+’ mark.
Step 2 – Select ‘Display capture’, then ‘Create new’, and name it.
Step 3 – Edit the aspect ratio of the video to be recorded.
Start Recording in OBS
This is all for screen recording via OBS Studio. Let’s move on to another way of screen recording via VLC.
How to Screen Record on Dell Laptop via VLC
VLC media player provides more file formats and customisable settings, including boosting audio sound. It is free to use.
You can download the VLC Media player from the Website. Below are the steps to screen record on a Dell Laptop via the VLC media player
Step 1 – Launch the VLC Media player and click ‘Media.’ From the launch bar, click on ‘Convert/Save.’
Step 2 – Select the ‘Capture Device’ tab and choose ‘Desktop’ under ‘Capture Mode.’
Step 3 – In the ‘Destination’ section, click ‘Browser’ to select and name the folder.
Step 4 – Click on ‘Start’ to initiate recording.
Mac Video Recording Software - VLC Media Player
Video Recording with VLC Media Player
Let’s move to the next part to learn about screen recording via ShareX.
How to Record a Video on a Dell Laptop via ShareX
ShareX is a third-party application that allows screen recording. It enables you to screen record in various modes and has multiple customisable options. Also, it is free to use.
To download ShareX, go to the Website. Once you have downloaded and installed the ShareX, follow the steps below.
Step 1 – Launch the ShareX screen recorder
Step 2 – Click ‘Task Settings’ and choose ‘Screen Recorder.’
Screen Recorder for PC - ShareX
Screen Recorder for PC – ShareX
Step 3 – Click on ‘Screen Recording Options.’ To capture audio, click this option and select ‘Audio Source.’
Step 4 – Click ‘Capture’ and select ‘Screen Recording.’ Once you have built the recording windows manually, screen recording will begin immediately.
Another way to screen record a Dell laptop is by using Camtasia. To learn more, read the following part.
How to Screen Record on Dell Laptop via Camtasia
Camtasia by TechSmith is a third-party application that stands out because of its various functionalities, such as video editing, audio editing, cursor effects, and AI. It has a direct recording plug-in to Microsoft PowerPoint.
You can learn more and download Camtasia from the Website. Following is the step-by-step guide on how to use Camtasia to screen record a Dell laptop,
Step 1 – Launch Camtasia and click the ‘Record’ button.
Click New Recording
Click New Recording
Step 2 – Select the screen and click the ‘Record’ button again.
Step 3 – To stop recording, click on the ‘Stop’ button
The following section will cover screen recording via Bandicam. Without further delay, let’s proceed to the next section.
How to Screen Record on a Dell Laptop via Bandicam
Bandicam is another screen recorder that allows you to record webinars, lectures, video calls, PowerPoint presentations, and audio narration.
To download and install Bandicam, go to the Website. The step-by-step guide to screen record is as follows,
Step 1 – Launch Bandicam and select the mode to screen record.
Step 2 – Click the ‘Rec’ button or press F12 to start and stop the recording.
Facecam and Screen Recorders - Bandicam
Click the Rec Button
To record computer sound, choose ‘Default Output Device.’
To record your voice, choose ‘Your microphone device.’
Lastly, we will discuss using Screenify to screen record on a Dell laptop. Without any further delay, let’s move to the next part.
How to Screen Record on a Dell Laptop via Screenify
Screenify is yet another screen recording tool with many features. It is available for Windows and MacOS. Screenify is straightforward and user-friendly for recording and live-streaming gameplay, PowerPoint slides, lectures, webinars, and tutorial videos.
Screenify provides several free features! Some of them are given below,
  • 4K recording at 60FPS.
  • No watermark restriction.
  • Unlimited recording time.
  • There are multiple recording modes to choose from.
  • Audio narration and computer sound input.
  • Video and audio editing.
We have discussed seven ways to screen record your Dell laptop. In the next section, we have listed frequently asked questions regarding screen recording of Dell laptops.
Q1. Does my laptop have a built-in screen recorder?
Yes, you can use Game Bar to screen record your Dell laptop. The Game Bar has a built-in screen recorder. You cannot edit video and audio, but you can simply record your lectures, presentations, webinars, gameplays or whatever you wish. To do so, you can go to Part 1 to see the step-by-step guide.
Q2. How do I record myself on my Dell?
One easy way of doing it is by using Clipchamp developed by Microsoft. Clipchamp is an official Windows video editor. It provides background removal of any image using AI, a free hand rotator, a silence remover, and an audio recorder.
Download and install Clipchamp from the Website. Once you have installed it, follow these steps,
Step 1 – Launch Clipchamp and select the ‘record and create’ tab on the toolbar. Find and click on the ‘Camera option.’
Step 2 – A pop-up window might appear asking for your permission to access your camera and microphone. Once you are ready, click on the ‘done’ button.
Step 3 – Your webcam recording will now start. Before you start recording yourself, check your microphone and camera source.
Step 4 – Click on the red record button. A 3-second countdown will appear before your webcam recording starts. Click on the red stop button to stop it.
You can watch the playback of your webcam video. When done, click ‘save and edit’ to return to the editor.
Final Thought
This article has seven convenient ways to screen record your Dell laptop. Follow the step-by-step guide to screen record your Dell laptop or any other Windows laptop. Some of these tools also support MacOS. We hope you find it helpful.
