If you are searching for free ways to record screen on Acer laptop, this article is what you need. There are 4 methods available for Acer laptop screen record. Check them out now!
Try Screenify for free to record screen on Windows or Mac. Whether full-screen or partial-screen recording, recording with sound or with camera, Screenify can do it with ease.
100% Clean & Safe
Have you ever been in a video conference or an online class and wanted to record everything you see on your computer screen? From recording tutorials to online gaming, screen recording is now an almost indispensable element of our lives.
If you have an Acer laptop, this article will walk you through the best ways to record your screen. Let’s also look into some add-on tools for how to screen record on Acer laptops. By the end of this article, you should be ready to begin capturing your screen without difficulty. So, without further ado, let’s dig in!
In today’s world, screen recording has become a necessity. For those who use computers excessively, screen recording is a blessing in disguise.
Here are some incredibly versatile scenarios where you might need to screen capture your laptop screen.
Screen recording is helpful in more ways than one. In the tech world, leaning on these hacks improves productivity and efficiency.
Before we move on to the tutorial on screen recording on Acer laptops, you must note some prerequisites. You need to prepare your Acer laptop for things like storage and battery.
Here are the boxes you need to check for unbuffered sound screen recording.
Now that our device is completely set up let’s take you on a guide on how to screen record on Acer.
If you have followed our above-listed instructions keenly, you are ready to move to the tutorial on screen recording. Acer laptops with Windows 10 and PowerPoint can record screens without third-party software.
Easily record the screen of your Acer laptop with Windows built-in game box button. Microsoft introduced this feature for gamers in its Windows 10 version. If you do not favor third-party applications, effortlessly capture the screen with the Game bar.
Here is how to record the screen with the Windows 10 Gamebox button.
1. Open the screen or website you want to screen record.
2. Press the Windows + G button on the keyboard simultaneously to open the Game Bar.
3. From the menu panel that opens, choose Capture.
Window Game Bar feature
Alt+text: Window Game Bar feature
4. Click on the Recording button to Start recording.
alt+text: Start recording screen
5. Press the red circle to Stop the recording.
And the recording will be automatically saved in a folder on your Acer laptop. Game Bar has a simple recording feature with decent functionality. Capture your screen in just five simple steps.
For presentations, PowerPoint has a special screen recording feature. If you want to capture your presentation without any third-party interference, this is your go-to option to try!
Follow the steps to record your presentation on Powerpoint.
1. Open your presentation on Microsoft PowerPoint. Open the slide you want to record.
2. From the ribbon, click to open the Record tab. Click the Record button and select ‘From beginning’ or ‘Current Slide.’
Powerpoint record featuure
3. Next, the recording feature will open on the chosen slide. Click the Record button to start and use the markup tools to annotate.
record slide with screen recorder
4. Click Stop to end the recording. The video will automatically be added to the corner of the slide.
screen recording added to the slide
And that is how you can easily capture the screen and add it to your slides.
The above methods are handy for recording a screen instantly or adding video notes to a presentation. For advanced video recording functionality, third-party applications do the job well. Find out our choice for screen recording with specialized features.
The built-in features have limited ease of use and performance. Here are our two top picks from a crowd of third-party recording software.
Screenify is an upcoming screen-recording software for MacOS and Windows. It is a versatile, professional recorder that offers multiple recording modes. With a large set of features, it is a highly functional tool with excellent output.
The interface is extremely simple and intuitive, perfect for beginners and professionals. Screenify offers 4K, 60fps recording for a clear, sharp result.
It offers in-app cropping tools and free text watermarking on videos. You can mark up the video to highlight a specific point. However, OBS doesn’t natively provide in-app markup or editing tools. Its overwhelming interface is also trickier than Screenify.
Use Screenify to Screen Record on Acer:
Step 1. Download and Install Screenify on the Computer.
Step 2. Launch Screenify on your computer, and select Record Screen mode.
Select Record Screen Mode
Step 3. Configure Recording Settings aims to configure settings like system audio before recording.
Record Setting
In this setting menu, you can:
1 Choose the System audio.
2 Choose the Microphone you want to record.
3 Choose the Camera you want to use.
4 Choose whether to add a watermark.
Step 4. Select Recording Screen.
Option 1. Full-Screen Record
Please select Full-Screen mode and choose the display you need to record. Hit the Record button to initiate recording.
Full Screen
Option 2. Region Record
To record the region, you need to manually select the recording area. After selection, you can still adjust the selected area. It supports customized selection, full screen, and proportional selection based on common social media dimensions.
Record Region
Step 5. Wait for the Recording Countdown.
There is a 3-second countdown to help you prepare the recording after you are ready to start recording.
Start recording countdown
If you would like to see a recording countdown before your recording starts, you can enable the countdown option. Or you can tap it off. Check how to set the countdown option in Screenify.
Step 6. Start Recording.
The recording will begin after a 3-second countdown. You can make annotations on the recording interface during the recording.
Annotate the Screen during Recording
With the toolbar, you can add the annotation in the screen:
1 Brush: Draw freehand on the screen recording interface to highlight or illustrate specific areas during the recording.
2 Rectangle: Draw rectangular shapes on the screen recording interface.
3 Text: Add written notes or labels directly onto the screen recording interface.
4 Arrow: Draw arrows on the screen recording interface to point out and emphasize specific areas.
5 Line: Draw straight lines on the screen recording interface to underline or connect specific points.
Step 7. Record Screen Process Completed.
When the recording is completed, you can click the red Stop button to end the recording. Your recorded files will be displayed. From here, you can preview and manage the recorded content as needed.
Compared to a recording giant like OBS, Screenify easily clean sweeps it. Screenify is sure to be a tough competitor offering the same quality as OBS.
OBS Studio is a standout performer in the screen recording business. Its professional suite of features and adaptability to various scenarios make it popular among gamers. Although the interface could be more beginner-friendly, its exceptional output convinces users to try it.
Here is a step-by-step guide on how to use OBS studio for recording.
1. From the OBS studio website, download the application for free. Install and set up the program.
2. Open OBS. In the Scenes section, click the + icon to add a new scene.
3. In the Source tab, click the + icon to adjust your audio and camera sources. To capture the entire window screen, click Display Capture. To record on 3D game visuals, choose Game Capture.
OBS Studio source menu
4. Next, set up the output settings. Go to Settings and click Output. Choose a file format and a destination for the output.
5. When ready, click the Start Recording button to capture the screen. Click Stop to terminate it and save it to your PC.
start recording with OBS Studio
OBS is a powerful screen recorder with professional features. Offering different recording modes ensures versatility and quality.
Technical errors during screen recording might cause trouble in the saved file. Here are some tips for a smooth and high-quality video capture.
Following our tips, you can quickly improve the functionality and output of the screen recorder.
1. Can I record the screen on my Acer without installing any software?
Yes. Acer laptop users can record screens without installing software via two built-in methods: using the Windows 10 Game bar button or recording presentations with Microsoft PowerPoint.
2. How do I record the screen and audio on my Acer device?
Use the Windows built-in game bar button to screen record on an Acer laptop. A free, third-party application like Screenify is also a better alternative.
Here is how to record screen on Acer laptop with an Xbox game bar.
3. What should I do if my screen recording lags?
Ensure a fast internet connection for stable online video recording. Turn off notifications from other websites and apps. Moreover, close any heavy applications for a smooth screen recording. Use an external audio device for clear and sharp audio notes.
This guide has shown that screen recording on an Acer laptop is much simpler than you would probably expect. We have solved how to screen record on Acer once and for all. Use Windows 10 Game Bar, which records the screen with a single click. There is also a quick way to capture your screen using PowerPoint as a shortcut. However, for users seeking added functionality, there is a myriad of applications like OBS Studio and Screenify. While OBS is a gamer’s favorite, Screenify is just in the pipeline with even better functionality. Its user-friendly interface and comprehensive options are sure to wow everyone. Try Screenify for a versatile recording experience!
