Record Video Without Sound on Windows/Mac/iPhone/Android 2024
Don’t know how to record screen without sound on your computer or mobile phone? Check some easy ways to record video without sound on Windows, Mac, iPhone and Android.
Author Avatar Joy Taylor Last Updated: Aug. 19, 2024
Introduction
You might not always like to record screen with sound. There can be various possible reasons, such as you’re in a noisy environment and cannot record the microphone sound or your system sound does not match the video. In all such scenarios, you can record the screen on your Windows/Mac/iPhone and Android with an audio source at mute. Wondering how to record a video without sound?
For this purpose, the screen recorder you’re using must support the screen capturing without audio. Multiple third-party tools enable users to mute the audio sources before recording the screen. This detailed guide will explore methods to record video without sound on Windows/Mac/iPhone/Android and how to screen record without background noise as well. Let’s delve into the details.
Part 1. Record Video Without Sound on Windows/Mac
Recording a video without sound is a challenging task, and few screen recorders support muting the audio sources. When it comes to Windows or Mac, Screenify can be the ultimate choice. No matter if you want to mute both the system audio and microphone sound, Screenify can do both. Apart from muting both sources, Screenify also enables users to mute a single source, either microphone sound or system audio.
Are you in a noisy environment? No worries! You can adjust the volume for each audio source and even use the noise reduction feature to minimize the noise level. The best part about this tool is that it offers unlimited screen recording time, irrespective of whether you’ve enabled the audio recording or not.
Multiple screen recorders have a watermark enabled for audio recording. Screenify offers a freely set text watermark where you can choose not to have a watermark or a customized text watermark. You can record your PC screen in 4K resolution at 60 FPS. All in all, with multiple screen recording modes and flexibility in exporting formats, Screenify can be your all-in-one choice!
Key Features
  • Screenify lets you disable or mute the audio sources before screen recording.
  • You can record the screen with or without system audio/microphone and even adjust the volume.
  • Best 4K screen recorder at 60 FPS to eliminate lags and interferences.
  • It offers unlimited screen recording time, multiple screen recording modes, and simple cropping for a customized experience.
  • Utilize the noise reduction feature to eliminate background noise.
Part 2. Record Video Without Sound on an iPhone
You can utilize the iPhone’s built-in screen recorder to capture the screen. However, you can only choose to mute the microphone sound while screen recording on your iPhone, not the system sound, unless you turn the volume down. Therefore, we recommend using the V Recorder to record video without sound on the iPhone.
V Recorder lets users adjust the volume before initiating the screen recording process. You can set the volume for internal sound (system sound) and microphone from both settings. Apart from this, V Recorder comes with brilliant post-production editing features as well. You can choose to mute the recorded video even if you forgot to turn down the volume beforehand. The dub option enables users to add a narration or commentary after you’ve recorded the screen.
V Recorder also has multiple AI-integrated features, such as Smart Subtitle and Voice Changer. Smart Subtitle lets you add subtitles automatically via speech recognition technology, while a voice changer can modify your voice/tone.
Key Features
  • Adjust the volume of the system sound and microphone to record video without any audio.
  • Record in 1080P at higher FPS to eliminate lags and blurriness.
  • Utilize a voice changer to modify the voice/tone after screen recording.
  • The mute button enables users to remove any audio from the screen recording.
  • You can dub or add any sound effect to the screen-recorded clip.
Steps to Record Screen Without Audio on iPhone
Let’s find out how to record a video without sound on an iPhone via V Recorder.
Step 1. Download, install, and launch V Recorder on iPhone.
Step 2. Enable the permission asked for. Navigate to “Settings” and the “Recording Volume”. Keep both at zero if you want to record the screen without audio.
Keep the Recording Volume at Zero on iPhone
Step 3. Swipe down the Control Center from the upper right corner of the iPhone. Tap on “V Recorder” and then “Start Broadcast.”
Start Recording in V Recorder
Part 3. Record Video Without Sound on Android
Wondering how to record a video without sound on Android? Look no further! We have the AZ Screen Recorder as a solution. This screen recorder tool has a specified option to mute the screen recordings. AZ Screen Recorder enables users to record both the system sound (internal audio) and microphone simultaneously. The best part is you can even record only system sound or mute all audio sources with a single tap. The control bar that appears floating on the screen lets you control everything easily.
The AZ Screen Recorder is a free screen-casting tool for your Android smartphone that lets you capture anything on the screen. No matter if you want to screen-record tutorials, games, or even live shows from any streaming platform, this tool is an all-in-one solution.
Key Features
  • Record screen in 1080p resolution at 144 FPS with or without sound.
  • Mute all audio sources seamlessly with a single tap.
  • Adjust settings like screen resolution, frame rate, audio sources, and more.
Steps to Record Screen Without Audio on Android
Here’s how to screen record Android without Audio via AZ Screen Recorder
Step 1. Download, install, and launch AZ Screen Recorder on your Android.
Step 2. Tap on “Settings” from the above toolbar. Then, tap on “Audio Source.” Choose “Mute” from the available options.
Mute in AZ Screen Recorder
Step 3. Click on the “Record” button to start recording without audio.
Part 4. How to Screen Record Without Background Noise
Wondering how to screen record without background noise? Being in a noisy environment can ruin the quality of your screen recording. Whether you want to screen record a presentation lecture, tutorial, instructional video, product demonstration video, or more, noise in your background can ruin the video quality. Imagine yourself in place of a user who wants to watch a step-by-step tutorial guide with background noise— irritating, right?
Screenify is the solution to this problem! It’s an all-in-one screen recorder that offers a brilliant noise reduction feature, enabling users to eliminate any irritating background noise with just a single click. You can even reduce the noise after you’ve recorded the screen. Navigate to the Noise Reduction feature in the toolbar and simply upload a file to get a noise reduction effect.
Apart from this, users can also adjust the volume of audio sources, i.e., system audio and microphone, while screen recording. Finally, you can also adjust the overall volume of the recorded clip during the playback preview.
Download and use Screenify, and never screen record your important meetings or video calls with background noise!
Recording a screen with background noise not only damages the quality but also enhances user engagement. No one would like to watch a tutorial or an instructional video with a noise or irritating sound. That’s where you can record video without audio and add narration afterward. Wondering how to record a video without sound? We have compiled all the methods to record screens without sound in Windows/Mac/iPhone and Android. You can try Screenify— a free 4K screen recorder for Windows and Mac— due to its multiple recording modes, audio mute option, and no watermark features.
