You want to show your friends and family your games but don’t know how to record PS4 screen. In this article, we will show you the best four methods for recording your PS4 screen. With the built-in feature or with other fantastic software.
If I wanted to record let’s play videos on a Ps4, what equipment would I need?”
Recording your PS4 screen may be a rewarding and profitable work, whether you want to share great gameplay moments, provide tutorials, or launch your own Play series. Gamers frequently wish to record their screen to show their skills, and entertain the audience. The article will provide you with easy methods to record the screen of your PS4. So stop searching for how to record ps4 screen and instead read this article.
Live streamers and YouTubers share walkthroughs to help their audiences enjoy the game and overcome tough levels. While many screen recording tools exist, you need a reliable program and the know-how to record on a PS4.
Sony’s PS4 and PS4 Pro versions include an auto-record feature that allows users to store and share their favorite game experiences. By default, they save the latest 15 minutes of gameplay in an.mp4 file. Even if you choose to save it, doing so will overwrite the recording of these minutes. The recording time can be adjusted from 30 seconds to 60 minutes. It only supports 30fps.
Step 1: Use your PS4 controller to press the Share button.
Step 2: Select the Capture Video option.
Step 3: Select the length of the video clip you wish to record. It is on you how much recording time you choose within 60 minutes.
Length of Video Clip
Step 4: If you want to record both speech and screen, go to this menu and select “Include Microphone Audio in Video Clips.”
Step 5: Press the Share button twice. Alternatively, pick the Start Recording option to begin recording your PS4 games.
Step 6: Once you’ve completed recording, tap the Share button twice more to stop recording.
Step 7: Your video clip has been saved to your PS4 and can be accessed via the Capture Gallery.
Whenever you need a tool that is free or has no a 30- to 60-minute restriction. Here comes Screenify, a free screen recorder for Windows and Mac. It can be ideal for screen recording your PS4 gameplay. Screenify has no time limit and no irritating ads.
You’ll receive a high-quality video of your gaming. You can also opt to capture either the system or microphone sound. Screenify also provides the answer to the most frequently requested question, “How to record games on PS4” using a webcam. This allows you to record 4k resolution videos at 60 frames per second. It supports the noise reduction feature, which enables noise-free video recording.
Here is how to record video call with Screenify:
Step 1: Download and install Screenify on your computer. Then launch it correctly.
Step 2: Open the program and choose Record screen mode.
Select Record Screen Mode
Step 3: Before you start recording, adjust your settings. Decide if you want to capture system audio, use a microphone, or include webcam footage.
Set Configure Recording Settings
In the settings menu, you can:
Step 5: Choose Full Screen mode or any other area you want to record, then click the Record button to begin.
Choose Full or Region Mode
Step 6: A three second countdown will start before the recording.
Recording Countdown
Step 7: Once the countdown finishes, recording will begin. You can add annotations as you go. When you’re done, click the red Stop button to finish the recording.
If you want to record your amazing PS4 gameplay, you must purchase a video capture card. A capture card, like the Elgato HD60 or 4K60, ensures uninterrupted video quality at the maximum level. Even though the setup seems difficult, it is easy and well worth the superior quality you will get.
Step 1: Before proceeding, please allow the capture card to access the screen.
Step 2: To enable this go to PS4 settings and select the system option, then enable HDCP.
Enable HDCP
Step 3: Connect the capture card to your PS4. Next, launch the game you wish to record. To start the recording, select the record button on the left side.
OBS is free-source software that is entirely free to use. You can use Linux, Mac OS X, and Windows to access OBS Studio. Yet it includes advanced features for recording your PS4 screen. If you are a novice, you will find it tough to use. There is no indicator or time stamp on its main interface to indicate that the recording has begun.
Step 1: Download and install OBS Studio on your computer from “obsproject.com” based on your operating system.
Step 2: Download and install the PS4 from “remoteplay.dl.playstation.net/remoteplay” based on your operating system.
Step 3: After connecting your PS4 to your PC, turn on PS Remote Play. Go to Settings after logging in with your PS4 credentials. Make sure the resolution is set to high for optimal recording quality.
Step 4: Launch the game you wish to play and ensure that PS4 is compatible with it.
Step 5: Launch OBS Studio immediately. Click the “+” symbol in the Sources tab, which is at the bottom. Select Display Capture to capture your screen while playing the video game with the PS4 on your PC.
Step 6: Go to Settings under the Controls tab, then to the Video tab, to confirm that all configuration parameters are properly configured.
Step 7: When you’re ready, click the Start Recording button on the Controls tab. Switch to your game and start playing on PS4. The recording is taking place in the background.
start recording with OBS Studio
Step 8: When you’re done playing, return to OBS and select the Stop Recording button.
Q1. How can you record a WhatsApp video call?
Whatsapp video calls can be recorded using the built-in screen recording feature. But, since internal audio will be utilized for calling, there won’t be any audio.
Q2. Can you record a video while on a phone call?
No, as soon as you receive or begin a call, the video recording stops. A video cannot be recorded when there is an active call.
Q3. Can you screen record a video call with sound?
No, Android and iPhone smartphones have built-in screen recording ability, but they are unable to record internal audio. You can overcome this by using third-party apps.
Q4. Can you record FaceTime calls?
Yes, with the built-in features in your smartphone of screen recording, you can easily record. But your voice will be the only one there.
In this article, we answered the common question: how to record ps4 screen? We covered different ways to do this, from built-in tools to more advanced options. For the best results, we recommend using Screenify. It is easy to use software with high-quality video recordings. Now, you can record and save your PlayStation video calls freely with no restrictions.
