Google Slides does not have an in-built recorder for live audio insertion. The article will explore the best methods on how to record audio on Google Slides for free. Upload your track to Google Drive and add it anywhere in your presentation.
Try Screenify for free to record voice on Google Slides. Both system sound and microphone can be recorded with ease.
100% Clean & Safe
Have you ever been bored to tears by a slow and monotonous presentation and wanted a little pick-me-up? Perhaps the easiest way to grab the audience’s attention is with music or an audio clip. Many of you who’ve been there know that audio is a real game-changer!
Audios can be significant if a person needs background music, a voice-over, or a sound that contributes to the slide. It instantly catches the audience’s attention. But how to do it? This article is ready to explore the six best ways how to record voice on Google Slides. Let’s dive into the details!
Also read: Best Free Voice Recorders for PC/Mac/Android/iOS
Before we dig into the different ways of adding audio to Google Slides, let’s answer the most common confusion. Can you screen-record a presentation on Google Slides with audio?
Unfortunately, Google Slides does not have a built-in screen recorder. To screen record a presentation, you need a webcam and support from third-party recording tools. Download an external tool or a web-based application to record presentations with Google Slides.
It’s time to explore the different ways to record audio on Google Slides.
You might not be able to screen record Google Slides, but integrating audio is super easy. While the application also limits you to recording voice-overs in real time, you can add pre-recorded audio in just a few simple steps.
Follow these steps to add a pre-recorded audio in your Google Slides:
Insert Audio to Google Slides
Even though Google Slides is utterly convenient, it does not support real-time audio recording or advanced editing. Users can only add pre-recorded audio uploaded to Google Drive.
Use external tools to record real-time audio on Google Slides. Here is a guide for competent audio recorders with versatile audio editing features.
Audacity is an open-source, cross-platform audio recording and editing software addressed to both novices and experts. While used mainly to capture performances through a microphone, it is equally efficient in tweaking audio files to optimum quality. Tempo and speed controls allow users to control the precise speed and pace of audio tracks.
One of its key capabilities is working with multitrack audio, which enables it to mix and overdub different tracks effectively. The software has a fully functional editor with basic manipulations and advanced options like reverberation, echo, and drive. Audacity is versatile and fulfills the needs of most audio editing jobs.
Here are the steps to record Google Slides with voice via Audacity:
Start Recording
With tasks requiring competent work with audio materials, Audacity’s expansive editing windows assist well. The application easily meets all the audio recording needs and allows it to be integrated into presentations.
While there is easily downloadable software, you can also record audio for Google Slides with online applications. Many online extensions are available, but a reliable platform like 123Apps is a favorable choice.
Say hello to 123apps, your go-to free online audio recorder. It’s very easy to use and has a simple design that allows beginners to start recording audio in no time. This 123 app has everything from simple cutting and trimming to more elaborate options, including noise elimination and additional sound effects. 123apps does not require any download, which makes it suitable for anyone who is always on the move.
Get a taste of what it is like to have a worry-free recording and editing experience with 123apps. Follow these steps for a step-by-step tutorial:
Edit Track with Audio Tools
And that is how simple it is to record and add audio to Google Slides. Even though the editing options are limited, 123app is a secure and reliable tool for recording voice-overs on the go.
If you are looking for more elaborate audio and video recording options, try OBS (Open Broadcasting Software).
OBS Studio, the free and open-source screen and audio capture tool, is rightly famous for its number of options and performance. The GUI is a bit hard for beginners, but everything becomes simple once you get the hang of it! The scenes are built from different sources, such as Windows captures, images and texts, and webcams.
OBS offers features like transitioning to the next shot, mixing audio with filters, and customizing the PC configuration. You can also arrange your layout by drag-and-drop and fine-tune with other options for enhanced performance. Here, let us walk you through an easy step-by-step guide.
Refer to the steps below for a detailed walkthrough of OBS screen recording features:
OBS Audio Recording Settings
Capture high-quality audio with OBS in real time and apply filters to enhance it. Even though the interface is not tech-savvy, you will adjust to it after a few trials.
And our final yet favorite pick to record audio on Google Slides is Screenify.
Presenting Screenify, the one-stop shop for recording audio, music, voiceovers, and screens. The application offers all-around screen-capturing functionality, with the option of capturing the entire screen or a specific area. The lock window recording feature ensures that only the window of the selected application is recorded. It also performs well in voice capturing, with options for volume control and noise elimination.
For users requiring more, Screenify offers easy video watermarking and highlighting tools. Compatibility with different formats, including full HD 4K at 60FPS, ensures the quality of the media files is good.
Key Features of Screenify:
Screenify is a premium recorder with a comprehensive interface. It provides easy-to-use tools and various recording modes to help everyone get the professional quality they want.
Q1. Why can’t I record audio on Google Slides?
Google Slides does not allow real-time audio recording for slides. Unfortunately, the application does not have an in-built recorder to support it. However, you can add pre-recorded audio to any slide in the presentation.
Q2. How do I record myself on Google Slides?
Google Slide has no in-built recorders to capture real-time audio and videos. Use third-party recording software to record your presentation on Google Slides. Download a recorder or use online recording websites and extensions like Screenify and 123apps to help you.
Q3. How to add voice to Google Slides?
Google Slides only supports adding pre-recorded audio to the presentation. To add voice to Google Slides, use external third-party tools to record audio. Here is how to do it:
Google Slides does not offer a native tool to record audio, but this article has explored several ways how to record audio on Google Slides. Consider online tools from 123apps to advanced software like OBS Studio or Audacity, all with unique advantages. But for smooth integration and ease of use, try Screenify! The free application offers features catering to the needs of novices or professionals. Try Screenify for free for creative voice-overs, real-time audio, or screen captures!
