Home Screen Record How to Fix OBS Recording Lagging
In this article, we will explore the common issue of OBS recording lag. Including addressing its reasons and providing step-by-step solutions to ensure smooth video capture. These tips will help optimize OBS Studio for the best performance.
Roger Smith | Last Updated: Aug. 28, 2024
1808 words|6minute
You’re in the middle of an epic gaming session, crushing your enemies in virtual worlds. The adrenaline is pumping, and you can’t wait to share your triumphs with the world. You fire up OBS Studio to record your gameplay, only to be greeted by the dreaded lag monster.
Your excitement plummets as you watch your smooth moves turn into a jittery mess. But fear not, intrepid gamer! In this guide, we’ll unveil the secrets to defeating the lag beast and reclaiming your gaming glory!
Let’s dive in and level up your recording and streaming skills! Starting with the lagging reason.
Why is OBS Studio Lagging when Recording or Streaming?
OBS needs no lengthy introduction because you’ve probably heard of this innovative tool. With OBS, you can stream Android phones to OBS, create virtual cameras, and even record using your webcam. And that’s not all! The list of features goes on, from adding new sound sources to fine-tuning your audio.
Due to its many features, the popular software can sometimes be glitchy or laggy. Unfortunately, this lag can negatively impact the quality of your recordings. Additionally, other factors contribute to the laggy experience while recording with OBS.
Let’s delve into other factors that contribute to OBS recording lag.
1. Overloaded device
The first and most common reason behind OBS lag is the performance of your device. Sometimes, your device may struggle especially when heavy applications run simultaneously.
OBS can lead to lag issues when combined with resource-intensive games or applications. So, if you find OBS lagging while playing a game, it’s because both OBS and the game demand high performance. And your device might have a hard time handling it all.
2. Network latency
The second cause of OBS lag is network latency. This is a familiar challenge for live streamers streaming with OBS. Network latency occurs due to message delays between your device and the server. If your device’s performance is not the issue, then network problems might be the one.
Now that we understand why OBS Studio lags, let’s dive into the solutions to fix these pesky issues.
How to Fix OBS Recording Lag?
Learn how to stop OBS recording lag and make perfect videos without interruptions! Discover effective methods here.
1. Fix your hardware
When tackling OBS lag, pay attention to your hardware! Sometimes, a faulty Ethernet cable or router can meddle with your video playback. Check for any open or damaged components, and fix or replace them to get OBS running seamlessly again.
2. Swap wireless for an ethernet connection
Wireless connections can be tricky and unstable. If your wireless internet is causing issues, try switching to a more reliable option. Turn off your computer’s WiFi and connect it directly to the router via cable. Most streamers prefer wired connections because they provide stable network connections.
3. Lower the Amount of Bitrate
Streamers also opt for a higher bitrate to boost video quality, which can cause dropped frames. Too many dropped frames may result in OBS recording lag. To avoid this, try reducing the bitrate. This will prevent dropped frames and keep your stream running smoothly. Choose this fix only when you can’t fix network issues.
4. Optimize the Security and Firewall of Your Device
If you’re still facing OBS lag and streaming issues despite a strong internet connection, it’s time to check your security software. Sometimes, it can interfere with smooth video playback. Consider uninstalling it temporarily or adjusting your system’s firewall settings if it’s causing OBS recording lags.
Follow the step-by-step guide to turn off your Firewall.
Step 1. Click on the Windows icon (Start) at the bottom left of your desktop (the flag icon), then click on Settings (the gear icon).
Launch Windows Settings
Step 2. In Settings, go to Update & Security and navigate to Windows Security.
Navigate Windows Security and Click Firewall
Step 3. Look for Firewall & network protection, and choose a network setting.
Navigate Firewall & Network Protection
Step 4. Find Microsoft Defender Firewall and turn it off temporarily. Don’t forget to turn it back on once you’ve resolved the OBS lag issue.
Toggle Off Firewall
Toggle Off Firewall
5. Customize the Settings in OBS
Customizing OBS settings for your specific device is crucial to avoid lag during recording. Each device has unique performance capabilities, so tweaking OBS settings becomes essential. Experiment with other configurations until you find the perfect setup that keeps OBS running smoothly without any lag.
Read on to learn more about settings for OBS that are recommended for beginners.
Recommended Articles: How to Fix FPS Drops in OBS for Smooth Streaming >
How to Optimize OBS for Recording?
You can unlock the true potential of OBS by “optimizing” its settings! Well, there are many different guidelines you can find online. So, explore various configurations until you discover what works best for your setup. For starters, follow this simple guide:
Step 1. Launch OBS, navigate to the Settings window, and head to the “Output” tab.
Step 2. Select the Output Mode to “Simple.”
Launch OBS Settings and Set Output Mode as Simple
Step 3. Choose “Software (X264)” as the Video Encoder.
Change Video Encoder
Step 4. Now set Recording Quality to “Indistinguishable Quality.” which results in a large file size.
Change OBS Recording Quality Setting
Step 5. Lastly, change the Recording Format to “Flash Video (.flv).”
Set Recording Format as FLV
Try these settings and refine them until you reach the ultimate OBS performance!
Now the recording issue is sorted. Let’s head to the next session, where we will fix the laggy video after recording.
Fix Laggy/Choppy Video after Recording the Game
If you encounter laggy or choppy video playback after recording a game, it may indicate a playback rather than a recording problem. Try the following solutions:
Now we’re left with our last scenario; OBS recording lags while the game remains unaffected. Read on to discover why this happens and how to address the specific issue.
OBS Recording Lags, but Game Doesn’t?
When you play a game on your computer, the resources are primarily allocated to ensure the game runs smoothly. However, when you add a recording or streaming software like OBS into the mix, there’s now an additional demand on the system’s resources. Even if your game runs smoothly.
But fear not! Let’s dig into some possible solutions.
1. Adjust CPU Priority
One way to tackle the laggy recording issue is to change the OBS Studio settings. Try increasing the CPU priority from “Normal” to “Above Normal” or “High.” This gives OBS more processing power and solves the lag problem.
2. Run OBS as Administrator
OBS Studio has a cool feature (since version 24.0.3) that reduces lag when your game’s FPS fluctuates. To access it, run OBS as an administrator. Sometimes, this simple tweak can work wonders.
3. NVENC Settings
If you’re using NVENC for encoding, check if certain features like lookahead and psycho-visual tuning are turned on. These additions might use more GPU resources, leading to laggy recording. Turn them off and use primary or high profiles instead of baseline for better results.
By trying out these straightforward fixes, you can bid farewell to OBS recording lag and focus on capturing your gaming triumphs without hiccups. Keep experimenting, and soon you’ll have seamless and stunning recordings to share!
Best Alternative: Try no-lagging screen recorder-Screenify
Whether you’re creating a tutorial, an instructional video, or a presentation, having smooth playback is essential. Screenify, an all-in-one 4K screen recorder, ensures a seamless and lag-free experience for sharing your screen activities with friends and colleagues. With Screenify, you get unlimited screen recording time on both Windows and Mac, so you won’t miss a thing.
Capture your screen in stunning 4K quality at 60 frames per second (FPS) without any lag or distortion. The tool offers various recording modes, allowing you to record the full screen or just a specific region for added flexibility. A handy Lock Window Recording feature ensures your personal information stays private by only capturing the active window or application. You can also record your screen, webcam, system audio, and microphone all at once.
OBS recording lag can be a frustrating hindrance to content creators and gamers. Following the information and solutions in this guide, you can optimize OBS settings and troubleshoot issues to achieve smooth and seamless video capture.
Remember to regularly update drivers, close unnecessary applications, and tailor OBS settings to your system’s capabilities. With these adjustments, you can focus on creating captivating content without the distraction of recording lag. Also, if you are tired of trying all these time-consuming efforts, try Screenify-one well-performance screen record software!
Roger Smith
Work for iMobie team for 5 years as well as an Apple fan, love to help more users solve various types of iOS or Android related issues.
