Free 60 FPS Screen Recorders for 1080P Recording
This post reviews the top free 60FPS screen recorder options for 1080p recording. It lists the best tools, such as Screenify, OBS Studio, Fraps, ShareX, and Xbox Game Bar, and defines the basic concept of 60 frames per second. We recommend using Screenify for smooth, high-quality video recording at 4K 60 FPS quality without any lags.
Author Avatar Joy Taylor Last Updated: Sep. 14, 2024
Screenify-ADimg
Screenify – Best Free 60 FPS Screen Recorder
Download Screenify to record your screen in 4K and 60 FPS. No recording time limit and no lag when recording. Support on both Windows and Mac.
Record Now
100% Clean & Safe
A 60FPS screen recorder enables the user to record at 60 frames per second, making your recording look smooth and crisp. This is especially helpful in recording, for example, games or tutorials, since all the movements have to seem precise. Recording videos at 60 frames per second alongside 1080p resolution provides quality videos, making your content appear professional with no lags or blurs. In this article, we will explore the best 60 FPS screen recorders. So, let’s begin to learn about them!
You may also like: Best Free 4K Screen Recorders
What is 60 FPS in Screen Recording?
60 FPS (frames per second) in screen recording indicates that 60 pictures are collected every second to make a movie. This improves the video’s smoothness, particularly when filming scenarios that need fast movements, such as gaming or action. When the FPS increases, the video’s smoothness becomes more evident.
Can I Record a Video in 1080P with 60 FPS?
If you use the right screen recorder, you can record a video in 1080P with 60 FPS. 1080P refers to full HD resolution, and when combined with 60 FPS, it creates smooth and clear videos. Many free tools support this feature, letting you capture high-quality recordings without lag. Ensure your computer has enough power to handle the resolution and frame rate for the best results.
Best Free 60 FPS Screen Recorders
Now, let’s explore some of the best free 60 FPS screen recorders:
1. Screenify
For seamless, high-quality results while recording 60 frames per second videos, Screenify is a great option. Users of Windows and macOS can access it. Record your screen in outstanding 4K quality at 60 frames per second (FPS) with no lags and distortion. Apart from quality recording, the tool provides multiple screen recording modes, i.e., to record on a full screen or in a region, for flexibility.
Screenify Main Screen
It is suitable for professionals, video creators, and gamers who need continuous, perfect, high-definition videos, as it offers a seamless way to record in 60 FPS with no lags. Screenify is the best option if you require a reliable 60 FPS recording with features such as customizable watermarks, multiple recording options, and basic video editing options.
Key Features:
  • You can record videos for as long as you want without time restrictions.
  • Customize and add text watermarks to videos for a more personal touch.
  • Choose between full-screen, selected areas, or specific window recording modes for flexible capturing.
  • Save your recordings in various file formats to suit your needs.
  • Capture stunning 4K videos at 60 FPS, ensuring smooth, crystal-clear video quality.
Pros:
  • Unlimited recording time
  • Free for Windows and macOS
  • Records in 4K and 60 FPS
Cons:
  • The edit feature doesn’t support AI content.
2. OBS Studio
With OBS Studio, it is possible to record videos with the best quality at 60 frames per second. It is also free and an open-source tool as well. Users can easily manage to record 1080P videos at 60fps on this tool which is supported on Windows, MacOS, and Linux OS. It is slightly complex, especially for beginners, due to its settings like the audio mixer, filters to reduce noise, and the ability to capture multiple sources at once.
OBS Studio
OBS Studio
Creating multiple scenes enables you to record from various sources simultaneously. For example, you can add scenes to capture windows, images, texts, and webcam and then switch them during the recording. In no time with the help of various tutorials available online, OBS Studio becomes one of the best 60 FPS screen recorders for professional recording.
Key Features:
  • You can capture video from multiple sources, making it great for complex video projects.
  • OBS Studio also offers various settings and configurations perfect for broadcasting and recording.
  • The tool includes an audio mixer with filters for cleaner sound, such as noise reduction, noise gate, and suppression.
  • Additionally, you can record system audio, microphone, or both and even adjust the volume of each source.
Pros:
  • Free and open-source
  • Records in 1080P at 60 FPS
  • Works on multiple platforms
Cons:
  • Steep learning curve
  • Complex setup for beginners
3. Xbox Game Bar
The best option for Windows video recording at 60 frames per second is Xbox Game Bar. Windows 10 and 11 come with it preinstalled, enabling smooth recording with excellent graphics. The program provides several functionalities that are useful for gamers and content creators. The design and interface are quite user-friendly, and the program cascades well with your system. In case you are looking for a reliable and easy-to-use 60 frames per second recorder, then this is one of the best ones to go for. You can adjust the settings for frame rate, resolution, and more. The only drawback of Xbox Game Bar is that it can record only up to 4 hours.
Record Screen with Xbox Game Bar
Key Features:
  • Start recording with a simple key combination or the Xbox Game Bar interface.
  • Adjust video quality and recording options to fit your needs and preferences.
  • Seamlessly record gameplay and desktop activities with minimal impact on performance.
Pros:
  • Free with Windows
  • Simple and easy setup
  • Integrated with Windows system
Cons:
  • Limited advanced features
  • Only available on Windows
4. Fraps
Fraps is great at recording smooth videos at 60 frames per second. Thanks to it, you may record games and other screen activities with remarkable clarity and detail. It is easy to check the frames per second while recording with Fraps, and it only takes a few seconds to press a button to capture a picture. Fraps favor up to 7680X4800 resolutions with a frame rate of one to 120 frames per second, making it suitable for gamers and digital artists who require a tool that they can use for performance measurement and recording.
Key Features:
  • Capture smooth and detailed videos at 60 frames per second for clear visuals.
  • Measure frame rates between two points to assess performance accurately.
  • Easily take screenshots at any time with automatic naming and timestamping.
  • View the current frame rate in the corner of the screen during recording.
Pros:
  • Reliable frame time benchmarking
  • Easy screenshot capture
  • High-resolution and FPS support
Cons:
  • No updates since February 2013
  • Limited to older features
5. ShareX
ShareX is a versatile and powerful tool for recording 60 FPS videos, offering a range of advanced features. It’s free and open source, making it accessible for anyone needing high-quality screen recordings. Multiple advanced level functionalities are available in task, workflow and hotkeys settings to enhance recordings.
Sharex Website Interface
ShareX supports smooth 60 FPS recording and includes tools for capturing screenshots, GIFs, etc. With over 16 years of development, it’s a trusted choice for users who want customizable and efficient screen recording. The tool offers customizability when it comes to screen recording, such as recording a window only, full screen, a particular region, or more.
Key Features:
  • Capture high-quality videos at 60 frames per second for smooth and clear visuals.
  • Easily create GIFs from your screen with adjustable recording settings.
  • Set up automated tasks for after-capture actions, enhancing efficiency.
  • Choose from fullscreen, active window, region, or scrolling capture options.
  • Supports over 80 destinations for quick and easy file sharing.
Pros:
  • Versatile capture methods
  • Advanced workflow customization
Cons:
  • It may be complex for beginners
  • No direct support for macOS
In conclusion, finding the best 60 FPS screen recorder depends on your needs. OBS Studio offers detailed settings, the Xbox Game Bar is easy for Windows users, Fraps supports high resolutions, and ShareX provides versatile options. For a reliable and user-friendly choice, we recommend Screenify. It offers unlimited recording time, and custom text watermarks and supports 4K video at 60 FPS.
