What is Screen Mirroring on iPhone?
Screen mirroring your iPhone and Android to the computer with ease.
  • Fast response time within 10 ms and 60fps frame rate.
  • A stunning visual experience with no color difference.
  • Lag-free screen mirroring and 4k resolution.
  • Works well on both Windows and macOS.
Available for both Win & Mac
Home Screen Mirror What is Screen Mirroring on iPhone?
Are you curious about iPhone screen mirroring? Or do you want to screen mirror your iPhone to a larger screen and enjoy a more immersive experience? If the answer is yes, this article will be very helpful for you.
Joy Taylor | Last Updated: Aug. 16, 2024
1542 words|5minute
Nowadays, the ability to seamlessly share and display content from our mobile devices onto larger screens has become an important feature. This is where iPhone screen mirroring comes into play.
We will explore screen mirroring on iPhone in this article and provide you with a comprehensive guide on how to mirror your iPhone screen to various devices such as PCs, Macs, and TVs. Whether you are a tech enthusiast or a casual user, this guide will equip you with the knowledge and steps needed to make the most out of screen mirroring on your iPhone.
So, get ready to unlock the full potential of your iPhone and elevate your viewing and sharing experience with screen mirroring!
What Is Screen Mirroring on iPhone?
Screen mirroring refers to the capability to duplicate the iPhone’s screen onto another device. And screen mirroring on iPhone means mirroring an iPhone screen to Mac/PC/TV with AirPlay. By doing this, you can share videos, photos, apps, and more on a larger screen, providing a seamless user experience across different screens. Whether you want to show a presentation to your colleagues, watch a movie on a bigger screen, or play games with friends, screen mirroring offers convenience and versatility.
There are several features of screen mirroring:
How to Screen Mirror iPhone to PC/Mac/TV with AirPlay?
AirPlay is a popular wireless mirroring technology that allows Apple users to stream content from their Apple devices, such as iPhones and iPads, to compatible AirPlay receivers.
This technology enables users to enjoy their media on a larger screen without the need for cables or physical connections, which provides a seamless and convenient way to share and enjoy content across different devices in the Apple ecosystem.
It’s easy to screen an iPhone to a PC/Mac/TV. Here’s how you can do it:
Step 1. Ensure that both your iPhone and the device you want to mirror are connected to the same Wi-Fi network.
Connect to the Same WiFi
Step 2. Enable AirPlay on your iPhone by swiping down from the top-right corner of the screen (iPhone X or newer) or swiping up from the bottom (iPhone 8 or older) to open the Control Center.
Step 3. In the Control Center, tap the “Screen Mirroring” option.
Find and Click on the AirPlay Icon (aka Screen Mirroring)
Step 4. A list of available devices will appear. Select your desired device (PC, Mac, or TV) from the list.
Select Mac from List to Share iPad Screen on Mac
Select Your Device from the List
Step 5. Your iPhone screen will now be mirrored onto the selected device. You can navigate your iPhone as usual, and the actions will be reflected on the mirrored screen.
Screen Mirror iPhone to PC with AnyMiro [Recommend]
AnyMiro offers a user-friendly interface and allows for a seamless and high-quality mirroring experience. It enables users to share their phone screen with a PC, making it convenient for activities such as presentations, gaming, or watching videos on a larger display.
It is compatible with both Windows and Mac platforms, providing versatility in terms of the devices you can mirror your phone. With its intuitive interface, reliable performance, compatibility, and high resolution, AnyMiro is highly recommended for screen mirroring your Phone to a PC.
Some key features of AnyMiro include:
How to Mirror iPhone to PC with AnyMiro
Mirror iPhone to PC via USB
Step 1. Download and run AnyMiro on your computer.
Step 2. Select mirror iPhone/iPad to enter iPhone mirroring.
Mirror iPhone to Computer
Step 3. Connect your iPhone to your PC using a USB cable.
Mirror iOS Device to Computer via USB
Step 4. On your iPhone, when prompted with a message asking for your trust, tap “Trust” and wait for a few seconds. Soon, you will be able to see your iPhone screen mirrored on your computer.
Trust Your Computer on iPhone
Mirror iPhone to PC Wirelessly
Step 2. Go to iPhone/iPad mirror section.
Step 3. Switch to the WiFi connection part. Ensure that both your iPhone and PC are connected to the same WiFi network.
Step 4. Follow the on-screen instructions and select your PC from the available list. Once selected, start mirroring your iPhone screen onto your PC.
Screen Mirror iPhone to PC with ApowerMirror
Another screen mirroring tool is ApowerMirror, which is a screen mirroring and casting application that allows users to mirror the display of their mobile device or computer to a larger screen. It supports both Android and iOS devices, as well as Windows and Mac computers.
Here are the key features of ApowerMirror:
Android Screen Mirroring App ApowerMirror
Now let’s See How to Mirror iPhone to PC Using ApowerMirror:
Step 1. Download ApowerMirror on your PC and iPhone and connect both under the same Wi-Fi network.
Step 2. Open ApowerMirror app on your iPhone and tap “LocalCast”.
Step 3. Search for your computer and then tap “Mirror Phone to PC”.
Step 4. Go to Control Center on your iPhone and tap Screen Mirroring icon. Select the name of your computer.
Then your iPhone screen will be streamed on PC.
However, ApowerMirror is a little bit expensive for some users, which needs $69.95 for the personal license (lifetime).
FAQs
1. What is the purpose of screen mirroring?
The purpose of screen mirroring is to show videos, photos, presentations, apps, or any other content from your mobile device on a bigger display. It allows for a more immersive and shared experience, making it easier to engage and interact with content on a larger scale.
2. Is it safe to screen mirror on iPhone?
Yes, screen mirroring on an iPhone is safe. Just ensure that you are using a secure Wi-Fi network and trusted screen mirroring applications like AnyMiro.
3. How to turn off screen mirroring?
To turn off screen mirroring on an iPhone, you need to swipe down from the top right corner of the screen to open the Control Center. Then tap the screen mirroring icon and choose the ‘Stop Mirroring’ option.
In conclusion, iPhone screen mirroring opens up possibilities for sharing, collaborating, and enjoying content on a larger screen. By following the steps outlined in this article, you can easily mirror your iPhone screen onto a PC, Mac, or TV using AirPlay, or explore alternative tools like AnyMiro. With the user-friendly interface and compatibility across different devices and platforms, the app makes screen mirroring accessible to users.
You may have known what is screen mirroring on iPhones. Now is the time to take advantage of the power and versatility of iPhone screen mirroring. So, start mirroring your iPhone screen today and elevate your viewing and sharing experience to new heights.
AnyMiro – Real-Time Screen Mirroring Tool
Joy Taylor
