Get ready to delve into the fascinating world of screen mirroring. We will guide you through enabling USB debugging and introduce cutting-edge tools like AnyMiro and Scrcpy. Further, we will explore the connection between screen mirroring and the realm of live streaming.
See how to view phone screen on PC via USB with AnyMiro
Available for both Win & Mac
Welcome to a world where your phone and PC seamlessly converge. This grants you unparalleled access to your mobile screen right on your computer. As our lives become increasingly intertwined with technology, the need to bridge the gap between devices has never been more crucial.
Picture this: effortlessly mirroring your phone’s vibrant display on the expansive canvas of your PC. This will unlock many opportunities for productivity, entertainment, and creativity. In this article, we will let you in on the secrets of viewing your phone screen on your PC via USB. Let’s explore different methods and see which one suits you the best.
To establish a seamless connection between your Android phone and PC, it is essential to enable USB debugging. This feature allows for the exchange of data and commands between the two devices. This enables a smooth screen mirror Android to PC via USB.
But why is USB debugging necessary?
By enabling USB debugging, you grant your PC permission to access the inner workings of your Android device. This empowers you to perform advanced tasks such as installing custom firmware, debugging apps, and, in our case, mirroring your phone screen on your PC.
Let’s see how you can enable it.
To enable USB debugging on your Android phone, follow these simple steps:
Step 1. Go to your Android device’s “Settings” menu.
Step 2. Scroll down and select “About phone.”
Android USB Debugging about Phone
Step 3. Look for the “Build number” or “Software information” option.
Tap Build Number Seven Times
Step 4. Tap on the “Build number” seven times until a message states that you have become a developer.
Step 5. Go back to the main “Settings” menu and search for “Developer options” or “Developer settings.”
Step 6. Tap on “Developer options” to enter the menu.
Tap Developer Options
Step 7. Scroll down and locate “USB debugging.”
Enable USB Debugging on Android
Step 8. Toggle the switch to enable USB debugging.
After finishing the USB debugging process. Moving on, we will guide you on how to view your Android screen on PC via USB.
Now that you have enabled USB debugging let’s explore two methods to view your Android phone screen on your PC via USB.
If you wish to view your phone screen on a PC via USB, you can use AnyMiro, an innovative screen mirroring app. It is a handy tool for effortlessly mirroring your iPhone or Android screen to your PC. With it, you can say goodbye to complex setups and software installations. AnyMiro offers a range of powerful features that enhance your mirroring experience to new heights.
What You Can Get from AnyMiro:
*With this method you need to download both the AnyMiro software and the mobile app.
Step 1. Download to get the AnyMiro desktop version, and enter the Android mirroring path.
Mirror Android to Computer
Step 2. Enable USB debugging of your Android phone. If you don’t know how to do it, there is a guide inside AnyMiro tells you how.
Mirror Android to Computer via USB
Step 3. Then open the AnyMiro app on your phone, tap Start in USB connection, and wait a few seconds, you can see your Android screen on your PC.
Select the Connection Method
Another method to view your screen on a PC is to use Scrcpy. Scrcpy is another powerful tool that lets you view your Android phone screen on your PC via USB. It provides a straightforward, reliable screen mirroring experience.
Here is a guide to using Scrcpy to view your screen on a PC.
Step 1. Download Scrcpy.
Download Scrcpy from Github
Step 2. Connect your phone to the PC via a USB cable. Ensure you have USB debugging activated on your phone.
Step 3. Extract Scrcpy into a folder of your choice.
Step 4. Run Scrcpy. It will detect your phone automatically.
Step 5. After connecting your device, you can view your phone screen on your PC.
View Phone Screen on PC with Scrcpy
The above methods are about how to view Android phone screen on PC, now let’s see how you can view your iPhone screen on PC via USB.
If you are an iPhone user looking to view your screen on a PC via USB, we have just the thing for you. Unlock the power of seamless connectivity between your iPhone and PC by exploring the methods below.
Step 1. Download and run AnyMiro on your computer.
Step 2. Select mirror iPhone/iPad to enter iPhone mirroring.
Mirror iPhone to Computer
Step 3. Connect your iPhone to PC with a lightning cable.
Mirror iOS Device to Computer via USB
Step 4. Tap “Trust” on your iPhone, and wait a few seconds, you can see the iPhone screen on the computer.
Trust Your Computer on iPhone
To mirror your iPhone screen on your PC via USB, you can also use AirDroid Cast. AirDroid Cast is a screen mirroring and remote-control application that projects a phone’s screen on a computer. It lets you view and interact with your device’s screen in real-time. This provides a convenient way to access and control your mobile device from a larger display.
Here is how you can use AirDroid Cast to view your iPhone screen on a PC via USB.
Step 1. Download the AirDroid Cast app on your iPhone and PC.
Download AirDroid Cast App
Step 2. Launch the app on both devices.
Step 3. Connect your iPhone to the PC using the USB cable.
Step 4. Open the app on your PC and choose the USB Cable mode to mirror your iPhone’s screen.
Choose the USB Mode in AirDroid Cast
Step 5. Choose your iPhone from the list of compatible devices.
Step 6. On your iPhone, a prompt will appear asking you to trust the computer. Tap “Trust” to establish the connection.
Step 7. Once the connection is made, you will see your iPhone screen mirrored on your PC.
Now that we know how to view your phone screens on a PC via USB, let’s take a look at its application in daily life. Phone screen mirroring to a PC has numerous practical applications in our daily lives.
But most importantly, the combination of screen mirroring and live streaming creates an immersive experience. This will revolutionize audience interaction and content sharing.
In conclusion, viewing your phone screen on a PC via USB opens up a world of possibilities. Whether for productivity, collaboration, gaming, or entertainment, screen mirroring enhances your digital experience. With tools like AnyMiro, Scrcpy, and AirDroid Cast, you can seamlessly connect your Android or iPhone to your PC. This will unlock a new level of convenience and functionality.
