Screen mirroring your iPhone and Android to the computer with ease.
Available for both Win & Mac
If you have an Android device and want to screen mirror it to your PC, there are several ways to do so. However, to make things less complicated, we have put together 3 methods to view Android screen on PC via USB and wirelessly.
Do you know that you can display the screen of your Android phone on another device like a TV or computer? This is called screen mirroring, and it’s super handy for watching videos, playing games, or giving presentations.
To mirror your Android phone screen, you can either use the built-in screen mirroring feature on your Windows PC or download a third-party app. In this article, we have discussed 3 easy ways to view Android screen on PC using different tools. But first, let us answer an important question…
You May Also Like: How to Mirror Android to PC without Wi-Fi >
Absolutely! You can easily mirror your Android phone screen to a Windows computer, which is super convenient and versatile. This technology is called screen mirroring or screen casting. It basically wirelessly projects the contents of your phone’s display onto your computer screen.
To use this feature, both your Android phone and Windows PC need to be connected to the same Wi-Fi network. This ensures a smooth and real-time transmission of data. It’s worth noting that the technology used for screen mirroring may vary depending on the phone model and Windows version. However, newer Windows versions often come with built-in support for screen mirroring.
Here are some common ways to mirror your Android to a Windows PC:
By using these methods, you can easily project your Android phone’s screen onto your Windows computer. This is perfect for presentations, gaming, content sharing, and much more! With that sorted, let’s have a look at how to view Android Screen on PC using these 3 methods.
Are you struggling to find a safe and reliable tool to mirror your phone screen on your PC? Well, worry no more because AnyMiro is here to save the day!
AnyMiro is a user-friendly and lightweight screen mirroring tool that can take your mobile device experience to the next level on your computer. It doesn’t matter whether you’re an iOS or Android user or if you’re using a PC or a Mac; AnyMiro can deliver top-notch screen mirroring quality without any barriers.
Plus, it supports both USB connection and wireless screen mirroring so you can use it with any smartphone model, old or new. Give it a try!
Here are the simple and easy steps to view Android screen on PC via USB and Wi-Fi with AnyMiro:
Via USB Connection
Step 1. Download and install AnyMiro on your PC, and select “Android” from the interface.
Step 2. Now connect your Android device to your PC using a USB cable, and click on “USB” from the menu on the left.
Mirror Android to Computer via USB
Step 3. You will get a notification on your device asking to “Allow USB Debugging?” Tap “Allow” to continue.
Enable USB Debugging and MTP Mode for a USB Connection
Step 4. Then tap USB Connection on the AnyMiro app on your Android phone, wait for a few seconds, and you can see your Android phone screen on the computer.
Select the Connection Method
And that’s it! In 4 simple steps, you can easily screen mirror Android to PC with a USB using AnyMiro!
Via WiFi Connection
To view Android screen on PC wirelessly over a Wi-Fi connection using AnyMiro, here’s what to do:
Step 1. Download AnyMiro on your PC and select “Android” from the interface.
Step 2. Make sure your Android phone and PC are connected to the same WiFi network, and click on “WiFi” from the menu on the left.
Mirror Android to Computer via WiFi
Step 3. Scan the QR code displayed on your PC screen with your Android phone to get the AnyMiro mobile app.
Download AnyMiro App on Your Phone
Step 4. Launch the mobile app and select “WiFi Connection” from the options.
Step 5. Select your PC’s name from the list of available devices to connect both devices and initiate screen mirroring.
Select Your PC to Access Android from PC
And that’s how you easily view Android screen on PC using AnyMiro. But why AnyMiro? Let’s have a look!
Features of AnyMiro as A Screen Mirroring Tool
Here are some features that make AnyMiro one of the best screen-mirroring apps:
Now let us discuss the second method to view Android screen on PC Windows 10.
Do you want an easy way to view your Android phone’s content on your PC? Well, you’re in luck! The “Link to Windows” feature is here to help.
This Microsoft app lets you connect your Android phone to your Windows PC. With Link to Windows, you can see your phone’s notifications, reply to messages, make and receive calls, use your phone’s apps, and share files between your phone and PC. It’s available for select Android phones and Windows 10 or later PCs.
To view Android screen on PC via Link to Windows, here’s what to do:
Step 1. Download the “Link to Windows” app on your Android phone from Google Play Store.
Step 2. Get the “Phone Link” app on your Windows PC from Microsoft Store.
Use Phone Link and Link to Windows to Help
Step 3. Launch “Phone Link” on your PC and select “Android” when it asks you to pick up your phone.
Pick Your Phone to View Android Screen on PC
Step 4. As you already have “Link with Windows” on your phone, click “Pair with QR Code.”
Pair with QR Code to View Android Screen on PC
Step 5. Review mobile permissions on your phone to finish pairing the devices.
Review Mobile Permissions on Phone Link
Step 6. Once all the permissions have been reviewed, your Android device will be paired with your PC via Phone Link, and you’re all set to get started!
Use Phone Link to View Android Screen on PC
Did you know that with the Wireless Display + Connect App feature in Windows 10, you can easily connect and view Android screen to PC? This is a great way to view your phone or tablet’s contents on a larger display. It’s really handy!
However, keep in mind that your computer needs to support Miracast for this method to work, and the setup process can be a bit complicated.
Here are the steps to set up and use Wireless Display on your PC:
Step 1. On your PC, go to “Settings > Apps > Optional Features.”
Go to Optional Features from Settings
Step 2. Click on “Add an Optional Feature > Wireless Display > Install.”
Install Wireless Display
Step 3. Now go to “Start > Wireless Display” to launch it on your PC.
Launch Windows Wireless Display
Step 4. On your Android device, enable screen mirroring and select your PC from the list of available devices. This feature might differ based on your device model.
Enable Screen Mirroring to View Android Screen on PC
Now that both devices are paired, you can view your Android screen on your Windows PC.
These were the top 3 ways to view Android screen on PC via USB and wirelessly. However, which method is better, and which one should you opt for?
If you ask us, we recommend using Anymiro…
If you’re looking for the best way to view phone screen on PC via USB or WiFi, AnyMiro is definitely the way to go! It’s way better than Link to Windows and Wireless Display and has tons of benefits that make it the top recommended choice.
Here’s why:
To sum it up, being able to view Android screen on PC makes life so much easier and opens up a whole new world of possibilities. With screen mirroring tools like AnyMiro, Link to Windows, and Wireless Display, it is super simple to connect your Android phone to your Windows computer and enjoy a seamless experience.
However, if you are wondering which method to choose, we highly recommend AnyMiro for its solid performance, many features, and compatibility with a wide range of devices. So why not give it a try and see how much more you can do with your Android on a bigger PC screen?
