Wondering how to use iMessage on a PC? This guide explains three easy methods: AnyMiro, iOS emulators, and Microsoft Phone Link. We recommend using AnyMiro – an all-in-one screen mirroring solution – for its simplicity, reliable connection, and smooth performance.
Try AnyMiro to mirror Android and iPhone to PC & Mac for free via USB and WiFi.
Wish to use iMessage on PC but don’t know how to set it up? You may be typing on your computer and don’t want to look at your phone to make a reply constantly. Fortunately, there are some methods of using iMessage on Windows PC. We’ll discuss three easy techniques to help you begin. Whether you use an emulator or Microsoft’s Phone Link, you can stay connected without hassle. We recommend using AnyMiro, a user-friendly screen mirroring tool that works smoothly and makes the process much easier. Let’s begin to explore this more!
Utilizing iMessage on a Windows PC rather than an Apple device is more challenging. If you have an iPhone, iPad, or Mac, you may know the remarkable messaging program Apple iMessage, which allows you to send messages to friends and family. The only disadvantage is that iMessage is not designed to work on a Windows PC, but you can use it by following some additional methods and tools. These techniques include installing and utilizing iOS on your PC via emulators or screen mirroring programs.
Let’s now talk about how to use iMessage on a Windows computer.
AnyMiro is a great way to mirror the screen of your iPhone if you’re searching for a simple way to use iMessage on a Windows computer. With 4K quality mirroring for up to 10 hours, you can mirror your phone without interruptions. AnyMiro is flexible for all your demands because it lets you mirror screens, audio, cameras, and microphones. It also supports multi-device streaming, enabling you to simultaneously connect and see various content on many devices. You can record in real time and snap sharp screenshots while mirroring to ensure you get everything. Plus, AnyMiro lets you live stream directly to platforms like YouTube and Zoom, offering flexibility whether you prefer Wi-Fi or a stable USB connection.
Key Features:
Now let’s explore the simple steps to use AnyMiro for this purpose:
Step 1. Start the process by free downloading and installing the AnyMiro application on your computer.
Step 2. Launch AnyMiro on your computer and select “iOS/iPadOS.”
Mirror iPhone to Computer
Step 3. Click on the “USB connection” option. Connect your phone to the PC using a USB cable.
Connect Your iPhone/iPad with a USB Cable
Step 4. When prompted on your iPhone or iPad, tap “Trust” to allow the connection.
Trust Your Computer on iPhone
Step 5. If required, enter your device passcode. Your device is now linked, and you can begin high-quality screen mirroring.
Step 1. Open AnyMiro on your computer and select “iOS/iPadOS.”
Step 2. Select the “Wi-Fi connection” option.
Step 3. Check your iPhone, iPad, and computer have the same Wi-Fi network.
Step 4. On your iPhone or iPad, access the Control Center, tap “Screen Mirroring,” and select “AnyMiro_Computer Name.”
Step 5. Once your device is recognized, you can instantly enjoy high-quality screen mirroring!
An iOS emulator is the alternative method for accessing iMessage on a Windows computer. You may use iOS apps on your computer like you would on an iOS device thanks to iOS emulators, which simulate Apple’s iOS operating system. The iPadian Emulator is considered the finest choice in this regard. Its goal is to enable smooth operation of iOS applications, such as iMessage, on PCs for clients. Although iPadian doesn’t simulate the original Apple App Store, it has a collection of 1000+ iOS apps and games.
To use this:
Step 1. Go to “ipadian.net” and download the available file.
Step 2. Install the downloaded file with the “.exe” extension on your computer.
Step 3. Down and open the simulator and agree to all the terms and conditions.
Download iPadian on the Computer
Step 4. After the installation is complete, start the iPadian software on your PC.
Step 5. Look for the Apple Messenger app within the emulator and open it.
Step 6. You now have quick access to iMessage on your PC!
You can also use Microsoft Phone Link to access iMessage on a Windows PC, but this method is available only for Windows 11 users. Microsoft Phone Link allows seamless integration between your Windows computer and your iPhone. With this tool, you may send and receive messages—including iMessage conversations—directly from your PC. Notification syncing, which allows you to view notifications from your iPhone on your Windows computer, is one of the main benefits. Microsoft Phone Link is a practical solution for Windows 11 users wanting to stay connected with iMessage.
Check out the detailed method below to use Microsoft Phone Link:
Step 1. Download and set up the Windows Phone Link app on your computer.
Step 2. Launch the Phone Link app on your PC and select “iPhone” on the initial screen.
Choose iPhone
Step 3. Follow the instructions on the screen to link your iPhone via Bluetooth.
Step 4. Open the camera on your iPhone and scan the QR code shown on your computer. You can click “open” to pair, or if you regularly use iMessage on your PC, it’s easier to download the Link to Windows app.
Step 5. Tap “Continue” on your iPhone to establish a Bluetooth connection, then click “Pair” on both your iPhone and computer. You will see prompts on both devices; allow any requested permissions and wait for them to connect.
Click on Pair
Step 6. On your PC, click “Continue.”
Step 7. Allow permissions on your iPhone. Make sure to enable the switches for “Show Notifications,” “Sync Contacts,” and “Share System Notifications.” Tap “Bluetooth,” select your PC’s name, and enable the switches.
Show Notifications
Step 8. Click on “Messages” from the Phone Link application on a Windows PC. Now, you can send and receive iMessages straight from your Windows PC!
Use iMessage on PC
Feature | AnyMiro | iOS Emulator (iPadian) | Microsoft Phone Link (Win 11) |
Accessibility | Easy to set up and use | Requires installation of the emulator | Built-in Windows 11 feature |
Device Compatibility | Works with iPhone and iPad | Limited to certain apps | Exclusively for iPhones |
Quality of Connection | High-quality 4K screen mirroring | Varies, not all features may work | Stable Bluetooth connection |
Multi-Device Support | Yes, can mirror multiple devices | Limited to one device at a time | Limited to one device at a time |
Notifications | No built-in notifications | No notification support | Syncs notifications with PC |
File Sharing | Yes, easy file transfer | Limited file sharing options | Supports file sharing |
Ease of Use | User-friendly interface | Slightly complex to navigate | Simple and straightforward |
Real-Time Recording | Yes, allows screen recording | No recording capabilities | No recording capabilities |
Does using iMessage on my PC require having an iPhone?
You must have an iPhone to use iMessage on your PC. Sending and receiving texts with iMessage requires an iPhone or iPad because it is built for Apple products. You cannot use iMessage without an Apple device.
Can I use my PC’s iMessage app to share images and videos?
Using a screen mirroring program like AnyMiro, you can transmit/project pictures and videos over iMessage on your computer. You may use iMessage to send and see your images by sharing the screen of your iPhone.
Can my PC receive iMessage notifications?
Yes, you can receive iMessage notifications on your PC using Microsoft Phone Link. This function lets you be informed about new messages without checking your iPhone.
In conclusion, using iMessage on your PC is possible through different methods, like iOS emulators and Microsoft Phone Link. These options allow you to send and receive messages conveniently. While each method has benefits, AnyMiro is a top choice. It provides high-quality screen mirroring and easy access to your iPhone’s features. Whether you want to share photos or receive notifications, AnyMiro makes it simple and effective. For a seamless experience with iMessage on your PC, we highly recommend AnyMiro for its user-friendly features and reliable performance.
