Experiencing issues with the Spotify application not responding? Follow these troubleshooting methods and discover how to resolve the problem.
Screen mirroring your iPhone and Android to the computer with ease.
Available for both Win & Mac
Are you encountering the frustrating issue of the Spotify application not responding on your PC? If so, you’re not alone.
Spotify is a popular digital music streaming platform that gives users access to a vast library of music, podcasts, and other audio content. It offers both free and premium subscription services, allowing users to stream music online or download it for offline listening. With Spotify, users can discover music, create playlists, follow artists, and explore a variety of genres and moods.
Some Spotify users may have experienced the application not responding issue, but the good news is that there are various troubleshooting methods that can help you overcome it. In this article, we will guide you through step-by-step solutions to fix this problem on your PC.
Before diving into the solutions, let’s briefly understand some common reasons for the Spotify application not responding issue. Here are the most common reasons for it:
Spotify Is Not Responding
The Spotify application is not responding due to the above reasons. Let’s see how to fix them.
One of the preliminary steps to tackle the Spotify application not responding issue is to end the Spotify process in the Task Manager. You can begin by following these steps:
Step 1. Press Ctrl + Shift + Esc at the same time to open Task Manager or right-click on the Taskbar and select Task Manager.
Open Task Manager
Step 2. Within the Task Manager, navigate to the Processes tab.
Step 3. Click on it and choose End Task.
Spotify End Task
After completing these steps, you can relaunch Spotify and check if the issue persists. If Spotify continues to be unresponsive, you can proceed to the next troubleshooting method.
Sometimes, the Windows Firewall may block Spotify’s connection and cause it to stop responding. To address this, follow these steps:
Step 1. Press the Windows key + R to open the Run box.
Step 2. Type in firewall.cpl and click OK.
Type in “firewall.cpl”
Step 3. Click Allow an app or feature through Windows Defender Firewall.
Click “Allow an app or feature through Windows Defender Firewall”
Step 4. Click Change settings.
Click “Change settings”
Step 5. Scroll down and locate Spotify.exe.
Step 6. Mark the Private and Public checkboxes next to Spotify.exe and click OK.
Corrupted data can also lead to issues with Spotify. Deleting the Spotify user data folder may resolve the problem. Here’s how to do it:
Step 1. Close Spotify completely.
Step 2. Press Win + R to open the Run dialog box, then enter %appdata% and press Enter.
Enter “%appdata%”
Step 3. Locate the Spotify folder > Users folder, and delete it.
Delete Users Date Folder
Step 4. Restart Spotify and see if the issue has been resolved.
If the previous methods haven’t resolved the issue, reinstalling the Spotify app may do the trick. Follow these steps:
Step 1. Close Spotify and ensure it is not running in the background.
Step 2. Press Win + R to open the Run dialog box, then enter appwiz.cpl and press Enter.
Step 3. Find Spotify in the list of installed programs, right-click on it, and select Uninstall.
Step 4. Visit the official Spotify website, download the latest version, and reinstall the app.
If you’re still unable to resolve the Spotify application not responding issue, consider using AnyMiro, a powerful and reliable screen mirroring app. AnyMiro allows you to mirror your mobile device’s screen onto your PC, enabling run the Spotify app on your phone and mirror it to your computer. This can potentially overcome any compatibility or performance-related issues that may be causing Spotify to freeze or become unresponsive.
Features of AnyMiro:
Up to 4K Resolution: AnyMiro supports up to 4K resolution, as vibrant as your original screen, which delivers the best color accuracy for an immersive visual experience.
Flexible Connectivity: AnyMiro stands out with its flexible connection options. Users can choose between WiFi and USB connections to achieve screen mirroring. This flexibility provides customized solutions for diverse user needs.
Stable Connection with No Latency: AnyMiro ensures stable and smooth screen mirroring, providing a seamless connection between your Phone and PC. You can achieve up to 10 hours of mirroring without hassle.
Easy to Use: You will find it super easy to mirror a phone screen to PC using AnyMiro.
Here are the simple and easy steps to screen mirror iPhone to PC with AnyMiro:
Mirror iPhone to PC via USB
Step 1. Download and run AnyMiro on your computer.
Step 2. Select mirror iPhone/iPad to enter iPhone mirroring.
Mirror iPhone to Computer
Step 3. Connect your iPhone to PC with a lightning cable.
Mirror iOS Device to Computer via USB
Step 4. Tap “Trust” on your iPhone, and wait a few seconds, you can see the iPhone screen on the computer.
Trust Your Computer on iPhone
Mirror iPhone to PC Wirelessly
Step 2. Go to iPhone/iPad mirror section.
Step 3. Switch to the WiFi connection part. Connect your iPhone and PC to the same WiFi.
Connect to the Same WiFi
Step 4. Follow the on-screen steps, select your PC from the list, and start mirroring iPhone.
Mobile Screen Mirrored on the Computer with AnyMiro
1. Why is the Spotify application not responding constantly?
Constant unresponsiveness in the Spotify application can be attributed to various factors such as insufficient system resources, outdated software, conflicts with other programs, or network connectivity issues. Trying the methods mentioned in this article can help resolve this issue.
2. How do I update Spotify on Windows 11?
For desktop/app users, open the Spotify app and click on the three-dot menu or Spotify located in the top-left corner, then choose Help, followed by About Spotify. If an update is available, a blue banner will appear, prompting you to restart the app to apply the update. Mobile users should go to their respective app stores (Google Play Store or Apple App Store), search for Spotify, and tap Update if it’s available.
3. Why is my Spotify app not opening?
If the Spotify app is not opening, it could be due to various reasons like a temporary glitch, outdated app version, or conflicting software. Try restarting your device, ensuring you have a stable internet connection, or reinstalling the app.
In conclusion, resolving the Spotify application not responding issue on your PC is crucial for uninterrupted music streaming. By following the step-by-step troubleshooting methods outlined in this article, you can effectively tackle the problem.
From stopping the Spotify process in Task Manager to ensuring Spotify is allowed through the Windows Firewall, deleting the Spotify user data folder, reinstalling the app, and utilizing the third-party mirroring tool AnyMiro, each method offers a potential solution to the issue.
Remember to mirror your iPhone to your PC using AnyMiro to enjoy Spotify on your mobile device and enjoy seamless video from your computer.
If further difficulties arise, don’t hesitate to reach out to Spotify’s support team or consult their community forums for additional assistance.
