Learn the simple steps to begin live streaming on Telegram. Create your Telegram live stream, share it to your followers, and interact with viewers in real-time!
Try AnyMiro to mirror Android & iPhone to PC for free via USB and WiFi.
Imagine being able to share something wonderful with your friends or followers instantly. Telegram’s live streaming function makes this possible! You may go live fast and use only your computer or phone; no extra equipment or intricate setup is required. Telegram live streaming lets you connect immediately to share an event, make a presentation, or greet everyone at once.
Start Messaging
This post will explain how to launch a live stream on Telegram on a desktop computer and a mobile device. Let’s dive in and start the Telegram livestream today!
Yes, Telegram can do live streaming! Telegram allows live streams in both groups and channels, with no limit on the number of viewers. This feature lets group admins start a “Video Chat” or channel admins begin a “Live Stream,” making it great for broadcasts and even community events. Viewers can interact by raising their hands to join the conversation. These updates make Telegram a popular choice for content creators and communities to engage with large audiences easily. Here are some benefits of live streaming on Telegram:
Telegram makes it easy to go live directly from your iOS or Android device and interact with others on the go. Its live streaming capabilities simplify broadcasting events or debates in real-time. First, you only need to be an admin of a group or channel. For a short guide, see the steps below.
Step 1. Get Telegram from the Play Store or App Store.
Step 2. Launch the application and decide whether to “Sign Up” to create a new account or “Sign In” to your existing one.
Step 3. Select the channel from the list of channels or groups where you’d like to stream.
Step 4. At the top of the screen, tap the name of the channel.
Step 5. Press the triple dots located in the upper-right corner.
Step 6. Choose to display yourself as a user or your channel, then tap “Start Live Stream.”
Tap Start Live Stream
Step 7. You can “unmute” yourself and turn on the camera during the stream.
Step 8. Tap the red “Leave” option, check the box next to “End live stream,” and then tap “Leave” again to end the stream.
Live streaming on Telegram from your PC is as easy as using your phone. You can broadcast directly from your desktop to share events, hold discussions, or connect with a larger audience. Let’s explore the simple steps to access Telegram on a PC and how to do Telegram Live Streaming from a PC:
Step 1. Begin by downloading and installing the Telegram desktop app on your PC.
Download Telegram for Windows
Step 2. Open the app and either “Sign In” to your account or “Sign Up” if you need to create one.
Step 3. Select the channel or group where you want to start the live stream.
Step 4. Click on the “Options” icon at the top of the screen.
Step 5. Choose “Start live stream” from the dropdown menu.
Choose Start Live Stream
Step 6. To end the stream, click “Leave” to stop the live broadcast.
With AnyMiro, you can easily mirror your phone to your PC for a smooth and immersive experience. This tool is perfect for screen mirroring Telegram from your mobile device to a larger screen. It offers stable, high-quality mirroring, so you can enjoy a steady connection with no lags for up to 10 hours, which is ideal for live streaming. 4K Resolution Support ensures vibrant and sharp visuals, with colors matching perfectly to your original screen.
AnyMiro’s Real-Time Audiovisual Sync keeps audio and video in sync, making it a top choice for gamers and content creators. Easy Streaming Options lets you quickly connect to platforms like OBS Studio, Twitch, or YouTube. Screenshot and Recording Features also allow you to capture memorable moments during live streaming.
Key Features:
Here are the steps for screen mirroring Telegram from phone to PC using AnyMiro:
Step 1. Free download AnyMiro and launch it on your computer and select “iOS/iPadOS.”
Mirror iPhone to Computer
Step 2. Choose the “WiFi connection” option.
Step 3. Ensure your iPhone/iPad and computer are on the same WiFi network.
Connect to the Same WiFi
Step 4. On your iPhone or iPad, open Control Center, tap “Screen Mirroring,” and select “AnyMiro_Computer Name.” Your device will be detected, and screen mirroring will begin.
Step 1. Install AnyMiro on your computer and launch it.
Step 2. Choose “Android” to start the connection process.
Mirror Android to Computer
Step 3. Click the “USB” icon and connect your Android device using a USB cable.
Select the USB Option for Screen Mirroring Android to PC
Step 4. Enable “USB debugging” and select “MTP Mode” on your Android phone when prompted.
Enable USB Debugging and MTP Mode for a USB Connection
Step 5. Your phone’s screen will appear on your computer, confirming the successful connection.
What devices can I use to live stream on Telegram?
You can live stream from mobile devices and PCs. To stream on Telegram through a PC, utilize the Telegram desktop application. If you need a reliable connection and a quality stream, consider using AnyMiro for screen mirroring to your PC.
Why is my Telegram live stream lagging?
A slow internet connection or low device performance can cause live stream lag. Try improving your network speed and closing any unnecessary apps.
During a live Telegram stream, how can I operate my camera?
Depending on your preferences throughout the broadcast, you can select whether to turn your camera on or off by touching the camera icon.
To summarize, live streaming through Telegram is a good means of engagement for your audience. The method is easy, and you can interact with others in real-time using either a PC or a phone. AnyMiro is highly recommended to improve your streaming experience. It helps with smooth screen mirroring, making streaming high-quality content from your mobile to your PC or Mac easier. It’s a great tool to elevate your Telegram live streams and create a more professional experience.
