  1. The Technology and Methods of Mobile Streaming
  2. How to Stream with Android Phone – Using a Live-Streaming App
  3. How to Stream with Android Phone – Using OBS on PC
  4. What You Might Need for Android Streaming
  5. How to Stream from Android to TV
  6. Bonus Tip: How to Stream to YouTube and Twitch at the Same Time
  7. FAQs
  8. The Bottom Line
Screen mirror and stream Android phone with AnyMiro
  • Fast response time within 10 ms and 60fps frame rate.
  • A stunning visual experience with no color difference.
  • Lag-free screen mirroring and 4k resolution.
  • Works well on both Windows and macOS.
Available for both Win & Mac
Home Screen Mirror How to Stream with Android Phone
Unlock the full potential of your Android for seamless streaming on all major platforms! Learn how to stream with Android phone through a step-by-step guide.
Joy Taylor | Last Updated:Nov. 07, 2023
1846 words|6minute
Are you ready to take your gameplay streaming to the next level? Imagine going live and sharing your experience with the world using your smartphone.
In the era of content creation and live streaming, the Android phone is a jack of all trades. Gone are the days of bulky equipment and dedicated studios. Now, you only need your smartphone and an internet connection to connect with your audience in real-time.
In this article, we will walk you through a guide on how to stream with an Android phone. We will also explore the tools and software that can help make your experience even better.
Let’s get started!
The essential technology behind mobile streaming is the mobile itself. In recent years, Android phones have taken the digital world by storm. They are equipped with every feature that is required to go live on streaming platforms.
The latest Android phones are equipped with high-resolution cameras. These cameras have built-in image stabilization, ensuring smooth and professional-looking footage.
As streaming requires a stable Internet connection to send your content in real-time. Therefore, Android phones support various connectivity options, including Wi-Fi and mobile data.
An Illustration of Mobile Streaming
There are typically two methods of mobile phone streaming which are as follows:
Streaming on mobile phone
Streaming on PC via screen mirroring
When streaming from your Android phone, a live-streaming app is one of the most popular and straightforward methods. There are multiple apps like YouTube, Twitter, and Facebook that have a broadcasting feature. However, the most popular one is YouTube. Many gamers want to do a live stream but don’t know how to stream Android games to Youtube.
Here’s a step-by-step guide on how to get started:
Step 1. Download the YouTube app from the Playstore and sign in with your Google account.
Step 2. Now, click the “+” button on the YouTube home screen and select Go live.
Select Go Live
Select Go Live
Step 3. Allow access/permission to the camera and microphone and proceed.
Step 4. Enter the title for your live stream and configure other settings.
Step 5. Click Next, and you will be live in a few seconds.
Note: If you see the popup showing that you are not eligible for going live. You can download a third-party app like Streamlab from the Playstore and open YouTube Live from there.
Now let’s see how to stream on PC.
If you are a gamer and want to enjoy your gameplay streams on a big screen, AnyMiro got you covered. With this software, you can screen mirror your Android phone to your PC and stream your games with a streaming app like OBS.
The best part is you don’t have to be a tech bee to operate AnyMiro. Due to its basic user interface, you can set it up easily. However, first, we will screen mirror our Android phone and then set up a live stream. Let’s move to the steps now!
Follow the instructions given below to screen mirror your Android phone on PC.
Step 1. Download and install AnyMiro software on your computer.
Step 2. Launch the AnyMiro app and select Android as your mobile type.
Mirror Android to Computer
Select the Android Option
Step 3. Select USB as a connection mode and connect your Android phone to your computer via a USB cable.
Mirror Android to Computer via USB
Select USB as the Connection Mode
Step 4. Enable USB debugging and choose the MTP mode.
Enable USB Debugging and MTP Mode for a USB Connection
Step 5. Once the device is connected, you will see your Android phone mirrored on your PC.
Mobile Screen Mirrored on the Computer with AnyMiro
Android Device is Mirrored Successfully
Now you are supposed to set up a live stream on your PC. Let’s see how to do it!
Here’s a step-by-step guide on how to stream with Android phone on PC.
Step 1. Download and install OBS Studio on your computer.
Step 2. Open the OBS app, and click Tools > Auto-Configuration Wizard.
Opening Auto-Configuration Wizard
Step 3. Now select Optimize for streaming, recording is secondary, and click Next.
Select the Highlighted Option
Step 4. Select the platform where you want to broadcast your live streaming.
Step 5. On OBS, click the “+” icon to add sources and then click Window Capture.
Open the Window Capture Option
Step 6. Give a name to your Window Capture screen and select your Android phone’s window. Finally, you are ready for live streaming.
When it comes to live streaming on Android phone, there are few tools you should consider. These tools can enhance your streaming quality and viewer experience. Let’s explore some of the essential tools.
1. Microphone
No doubt, the built-in microphone on your Android phone can work. But, investing in an external microphone can improve audio clarity.
2. Tripod or phone mount
Stability is crucial during a live stream. Using a tripod or a phone mount can keep your device steady and prevent shaky footage.
3. Lighting equipment
Good lighting can enhance the visual quality of your stream. They can improve visibility and make your stream look more engaging and professional.
4. Power bank
Streaming can quickly drain your phone battery. To avoid sudden shutdowns, having a power bank is beneficial to keep your Android phone charged.
Remember, these tools are not mandatory to start streaming on Android. However, they can enhance the overall quality.
Most Android phones have built-in screen mirroring features. You just need to connect it to your TV via WiFi. Here are the instructions that you can follow:
1. Make sure that both devices are connected to the same WiFi network.
Check the WiFi Connection
2. Enable screen mirroring/casting on your TV.
3. Enable screen mirroring/casting on your Android device from the quick settings panel.
4. Select your TV from the list of available devices and follow the on-screen instructions.
Select the TV
Select the TV
5. Once connected, your Android device’s screen or content will be mirrored or cast to the TV.
Android to TV Stream Succeeded
Let’s explore how to broadcast streams on multiple platforms.
If you want to stream on both YouTube and Twitch simultaneously, you can use Restream. It is the most convenient and user-friendly app that allows you to stream on multiple platforms. You can easily integrate it with OBS and start streaming. Here are the steps to do it:
1. Create an account on Restream and link your channels to the app.
Add Your Channels
Add Your Channels
2. Now enter your YouTube and Twitch account credentials to log in.
3. Launch the OBS Studio app, open Settings, and click the Stream tab.
Open the Stream Tab from Settings
4. Click Restream.io from the drop-down menu.
Open Restream.io
Open Restream.io
5. Click Connect Account and enter your Restream credentials.
Enter Your Restream Credentials
6. Now click Ok in the OBS settings window to save your settings.
7. You can manage your live streams with the Restream widgets menu in the OBS studio.
That is the way that can help you stream on YouTube and Twitch at the same time.
FAQs
Q. Can Android stream to Apple TV?
The answer to “Can Android stream to Apple TV” is no. Because the Apple TV is designed to integrate with Apple devices only. However, you can stream content from Android phones to Apple TV through third-party apps like Chromecast.
Q. Can I use my phone as a streaming device?
Yes, you can use your phone as a streaming device. Many smartphones have built-in streaming capabilities. On the other hand, streaming apps can also help broadcast your content and live streams to different platforms.
Q. What are the best apps for Android streaming?
Many apps can help your live stream your content from an Android phone. However, YouTube, Hulu, Amazon Prime Video, and Twitch are the most popular. You can broadcast your streams on these platforms and reach a large audience.
Streaming with an Android phone is becoming more common nowadays. Your Android phone is the solution if you are a content creator and want to reach a wide audience without any extra equipment. You can easily stream on many platforms with the right apps and tools.
After reading this guide on how to stream with an Android phone, we hope you succeeded in doing so. Plus, if you want to enjoy your streaming on a bigger screen, AnyMiro is here to rescue you. So, download AnyMiro now and start streaming!
AnyMiro – Real-Time Screen Mirroring Tool
Joy Taylor
