Download AnyMiro to help you stream mobile games to PC.
Available for both Win & Mac
Discover the easiest way to stream mobile games to PC. Learn how to use AnyMiro and OBS for a better game streaming experience!
Whether you’re a content creator planning an interactive session.
Or
A casual gamer aiming to share your achievements.
Streaming from mobile to PC offers superior quality and flexibility. It also provides an enhanced control setup using keyboards and a mouse.
While from a viewer’s perspective, the gaming action displayed on a larger screen can create a more enjoyable experience.
This guide gives you easy & clear steps to stream mobile games to PC. And at the end, we’ll also give you some bonus tips to become a good streamer.
Let’s start this exciting journey!
The first step while streaming mobile games on a PC is to transfer the mobile display to the computer screen. So how to do it?
We just need the help of a mobile mirroring app. And one of the best such apps is AnyMiro.
AnyMiro is a specialized tool that can effortlessly mirror your iPhone or Android screen to your computer. It is developed by iMobie and provides 100% secure mirroring. Moreover, this app is more than just a screen mirroring tool. It casts your mobile display and mirrors the background audio, including the game sounds.
Anymiro Official Webpage Interface
Key features of AnyMiro
Here are the Key Features of AnyMiro that make it stand out from the crowd.
AnyMiro provides up to 40 minutes of daily screen mirroring time at no cost. And if you are craving unlimited time, their paid version covers you.
In terms of quality, AnyMiro ensures up to 10+ hours of a stable connection. You also get the ability to mirror up to 4K resolution. So your gaming sessions will be as fluid as they can get.
Achieving audio-visual synchronization is often difficult while streaming mobile games. However, with AnyMiro’s Automatic Video-Audio Sync function, your visuals and sounds are perfectly adjusted. Now you won’t have to worry about missing a beat or a move.
For streamers seeking to share their gameplay with the world, AnyMiro can easily integrate with streaming tools. This compatibility with popular live streaming tools like OBS and Streamlabs makes your streaming process a breeze.
With AnyMiro’s remarkable features, you can easily stream mobile games on YouTube to PC. Let’s now focus on the practical aspect and see this first step. We will show you how to mirror iPhone & Android screens separately.
How to Screen Mirror from iPhone to PC
Here’s a stepwise guide to mirror your iPhone screen via AnyMiro.
Step 1. First, download and install AnyMiro on your computer. Once it’s done, launch the tool and select the “iOS/iPadOS” option.
Select iOS/iPadOS from the Opening Interface of AnyMiro
Step 2. From USB or Wi-Fi, choose the connection method that suits your setup.
Step 3. For USB connections, connect your iPhone using a USB cable. A message will pop up on the iPhone asking you to “Trust” the computer. Confirm it, and you’ll be all set to mirror.
Connect Your iPhone/iPad with a USB Cable
Step 4. Ensure your iPhone and PC are on the same network for a Wi-Fi connection. Then open the Control Center on your iPhone and select Screen Mirroring > AnyMiro_Computer Name.
Voila! Your iPhone screen will now be mirrored to your PC.
But wait! We can’t leave our Android community alone, can we?
Let’s now see how to mirror the Android screen to PC with AnyMiro.
How to Screen Mirror Android to PC
Here are the detailed steps to mirror your Android screen using AnyMiro.
Step 1. Just like before, download & install AnyMiro on your computer. Now launch it and select the “Android” option from the opening interface.
Select “Android” from the Opening Interface of AnyMiro
Step 2. Now you can connect your Android device with a USB cable or Wi-Fi.
Connect Your Android Phone with a USB Cable
Connect Your Android Screen via Wi-Fi
Step 3. Now, select the name of the computer on which you wish to mirror your Android screen. Remember to have both devices connected to the same network.
Step 4. Once successfully connected, you can see your Android screen mirrored on your PC.
Mobile screen mirrored on the computer with AnyMiro
And now we are a step closer to streaming mobile games to PC.
But we haven’t figured out the audio part yet. So how to stream mobile games on pc with audio? Let’s find out.
The thrill of gaming isn’t complete without audio. Similarly, if you stream mobile games to PC, audio significantly contributes to the overall gaming experience. It can turn a good game stream into a great one by capturing.
So here are some methods to stream the phone audio.
Method 1: Use a Microphone
The first method is using a microphone. This traditional method captures the streamer’s voice and the phone’s audio. It’s a simple setup where your microphone picks up the sound from your phone’s speakers. So your viewers can hear what’s happening in the game along with your commentary.
Method 2: Use AnyMiro to mirror mobile phone background audio
If you don’t want to add commentary, then just rely on AnyMiro. Besides mirroring your phone’s screen, AnyMiro also captures the background audio. It then delivers this high-quality sound directly to your stream. This method bypasses the need for a microphone and captures the game’s audio in its purest form.
Now it’s time to move on to the next step.
Let’s see how to stream mobile games to PC with OBS Studio.
After mirroring your mobile screen to your PC, you need the help of streaming software to stream your gameplay. And that is where OBS studio comes to play.
It is an open-source software that allows you to live-stream video and audio content. OBS is widely used among game streamers due to its versatility and functionality.
Here’s a simple step-by-step guide to setting up OBS Studio.
Step 1. Download and install OBS Studio from the official website.
Step 2. Launch OBS and select the “+” button under the “Sources” window. Then, choose “Window Capture.”
Adding a new source in the OBS
Step 3. A new window will appear. Select “Create New,” name your source, and click “OK.”
Name Your New Source and Select “OK”
Step 4. Another window will pop up. Select the window of AnyMiro from the “Window” drop-down menu. Then click “OK.” You will see your phone screen mirrored on the OBS interface.
Step 5. Now go to Settings. You can choose your streaming platform from the drop-down when you open the Stream settings.
Selecting the Streaming Platform from the OBS Setting
Step 6. After that, enter the stream key that you can obtain from the dashboard of your streaming platform. And then click “OK.”
Adding the Streamer Key of the Streaming Platform
And we are all set!
Let’s move on to the last step of how to stream mobile games on PC with audio.
With everything in place, you’re ready to embark on the final leg of your journey. Start playing your game on your mobile phone. Make sure your phone is connected and the game audio is clear. Also, check if OBS captures your gameplay.
Now, all left is for you to hit “Start Streaming” on OBS. Remember, your goal is to engage the audience with a mix of your gaming skills and commentary.
But even after you know how to stream mobile games on PC, you won’t become a good streamer immediately.
So what makes a good streamer? Here we go with the answer.
Streaming is more than just gameplay. It’s about creating a compelling viewing experience.
So follow these expert tips to stand out as a streamer.
Learning to stream mobile games to PC isn’t much difficult. We’ve walked you through a comprehensive guide covering everything. Follow the steps in this guide, and you’ll learn how to stream mobile games on PC.
And remember, AnyMiro stands as a crucial element in this process. It ensures the streams are of the highest quality and run without any lag.
Now you’re well-equipped to share your gaming experiences with the world.
