Want to share your mobile gaming live on YouTube? Learn how to stream mobile games on YouTube.
Download AnyMiro to help you stream mobile games on YouTube
Available for both Win & Mac
In the year 2011, YouTube expanded its approach by introducing a new live-streaming feature. And now, the center stage is taken by people who stream mobile games on YouTube.
Viewers enjoy these live streams not just for the games but for the interesting commentary. Some game streamers like PewDiePie and Markiplier are even attracting millions of YouTube users with their gameplay.
In this article, we’ll talk about how to live-stream mobile games on YouTube. We’ll first show you how to do it on PC. And then, we’ll tell you a method to stream directly from your mobile phone.
So let’s get started.
The short answer is YES! With a little know-how, anyone can start this exciting journey. The basic things you need include a stable internet connection, a YouTube account, and a smartphone for gaming.
And if you want to stream mobile games on PC, you’ll also need a mobile screen mirroring app with a streaming app. On the other hand, if you like to stream mobile games on YouTube directly from your mobile, you can do it from the YouTube app.
But before you go with any method, you’ll first need to enable live streaming on your YouTube account.
Now that we have the overview, let’s jump into the details of these methods.
This process involves two steps. The first is mirroring your mobile screen to your PC. And then, you’ll use a streaming tool to stream your gameplay on YouTube.
Let’s see how to mirror our mobile phone screen using a renowned tool AnyMiro.
AnyMiro is a robust screen mirroring tool that is compatible with both iPhones & Android phones. AnyMiro ensures a seamless experience. It supports high-resolution screen mirroring and offers extensive compatibility with various devices. And it prioritizes user safety and quality customer service.
Anymiro Official Webpage Interface
Key Features of AnyMiro
The application provides screen mirroring up to 4K resolution. So you can stream mobile games on YouTube with detailed graphics and fast-paced action.
AnyMiro mirrors your screen and automatically syncs the background game audio with timestamp adjustments. This offers a better experience for your viewers.
The durability of your stream is key to a good viewer experience. AnyMiro guarantees a stable connection for over 10 hours using USB 3.0 and the AirPlay protocol.
AnyMiro has a fast response time of just 10 ms. It also supports a refresh rate of 120Hz and a 60fps frame rate. This ensures that your streaming experience will be as fluid as possible.
AnyMiro integrates with popular broadcasting tools like OBS to stream your mirrored screen easily.
How to Stream the Mobile Screen to PC
After looking at the key features, here’s a detailed stepwise guide to using AnyMiro.
Step 1. Download & install AnyMiro on your computer. When you launch the program, choose whether you’re planning to mirror an iOS or Android device.
Mirror iPhone to Computer
Step 2. AnyMiro offers the flexibility to connect either via a USB cable or Wi-Fi.
Enable USB Debugging and MTP Mode for a USB Connection
Connect Your Device to the Computer via Wi-Fi
Step 3. You’ll need to install the AnyMiro app on your device for a Wi-Fi connection. You can easily download this from the Google Play Store. Or simply scan the QR code provided by the desktop AnyMiro application.
Scan the QR Code to Download the AnyMiro App
Step 4. Once your device and AnyMiro are successfully connected, your mobile screen will be mirrored onto the computer.
Mirror Screen Successfully
With your mobile screen successfully mirrored onto your PC, you’re one giant step closer to streaming mobile games on YouTube. However, before you start streaming, it’s essential to ensure that live streaming is enabled on your YouTube account.
Follow these easy steps to enable live streaming on YouTube.
Step 1. Sign into your YouTube account. You’ll need to create one if you don’t already have one.
Step 2. Once you’re signed in, click your profile icon in the top right corner of the screen. Now select “YouTube Studio.”
Click on Your YouTube Profile Icon and Select “YouTube Studio”
Step 3. Locate and select the “Settings” option. Then click on “Channel” and “Feature eligibility.”
Go to the Setting > Channel > Feature Eligibility
Step 4. Scroll down until you find the “Live Streaming” option. If your account is verified, Enable it. If it is not, you may need to verify your account with a phone number.
Step 5. To verify your account, click on “Verify Phone Number”. YouTube will send a verification code to this number, which you’ll then enter into the provided field.
Verify Your Phone Number If the Enable Option Doesn’t Appear
Remember that the verification process may take up to 24 hours. Once completed, enable live streaming, and you’ll have the green light to stream mobile games on YouTube.
After enabling live streaming on YouTube, it’s time to set up OBS. It is a free video recording and live streaming software. Gamers widely use OBS for its customization features and powerful capabilities.
Here’s how to set up OBS and start your live stream on YouTube:
Step 1. Visit the OBS website. Then download and install the appropriate version for your operating system.
Step 2. Open OBS and click on the “+” button under the “Sources” box. Select “Window Capture.” Then create a new source and select the AnyMiro window that mirrors your mobile game.
Adding the AnyMiro Window as the Source in OBS
Step 3. Resize or move the window capture box in the “Scene” preview to display your gameplay as desired.
Adjust the Added Source from the Preview
Step 4. To connect OBS to your YouTube account, you’ll need a “Stream Key.” Go to your YouTube Live Dashboard, click on ‘Stream,” and copy the Stream Key from the right side of the page.
Step 5. In OBS, click on Settings > Stream. Now select “YouTube – RTMPS” in the “Service” dropdown.
Setting YouTube as a Streaming Platform from OBS Settings
Step 6. Then paste your Stream Key into the “Stream Key” field. Click “OK” to save the settings.
Enter the Stream Key of Your YouTube Account
Now, you’re all set to go live. Click “Start Streaming” in OBS to stream mobile games on PC.
Let’s keep the momentum going and move on to stream mobile games on YouTube directly from our mobile.
If you prefer a direct approach, you can stream mobile games directly on YouTube via the YouTube app. This method bypasses the need for PC mirroring. So it’s a more mobile and accessible option.
However, the process differs slightly between iPhone and Android devices. So let’s look at them separately.
Starting a YouTube Stream on iPhone
Allowing Chats from the Additional Settings
Launch the YouTube App and Click on the Plus Icon
Select “Go Live” and Give Permissions
This method brings your game to the audience without the need for a computer. But even if you can’t stream mobile games on YouTube because of some hurdle, don’t feel don’t. Because YouTube is not the only platform where you can stream your mobile games.
Let’s see some other ways you can try.
If you’re looking to explore beyond YouTube, there are ways available. Many streaming apps also offer unique features for streaming mobile games.
Here are a few popular ones:
Twitch
Twitch is particularly famous for its interactive features. It enables direct engagement with viewers through live chats. Twitch also boasts a strong gaming community. So it’s a favoured platform for many streamers.
Streamlabs
Streamlabs is a versatile mobile app allowing you to stream directly to Twitch, YouTube, and more platforms. It’s popular for its extensive customisation options. These include overlays, alerts, and chatbox features.
Nimo TV
A rapidly rising star, Nimo TV is renowned for its focus on mobile game streaming. It hosts numerous popular games and encourages interaction between streamers & viewers.
Each app offers distinct features for different streaming styles & audiences. Experiment with these platforms to find your preferred streaming space!
Before we finish, let’s check some FAQs about how to live-stream mobile games on YouTube.
1. Can I stream without a capture card?
Yes! A capture card is typically used for streaming footage from DSLRs or gaming consoles. But it isn’t a requirement for mobile streaming.
Using modern software like AnyMiro and OBS, you can directly stream mobile games on PC. And you don’t need this additional hardware during the process.
2. What do you need to stream on mobile?
To stream on mobile, you primarily need a smartphone with a stable internet connection. And along with that, a game-streaming app like YouTube, Twitch, or TikTok will finish your job.
You may also require headphones for clear audio. And a tripod stand could be useful for stable video capture.
3. What is a good mobile game to stream?
Choosing a game to stream depends on your preference and your audience’s interest. However, popular mobile games like Fortnite, Minecraft, or Rocket League often draw significant viewership.
“Can you stream games on YouTube?” This is a question that many gamers are asking. The answer is YES and in a variety of ways.
If you prefer the precision of a PC, then you can stream mobile games on YouTube with AnyMiro and OBS. AnyMiro will mirror your mobile screen in high quality and with zero lag. While OBS will stream this mirrored mobile screen.
But if you want to stream directly from your mobile, you can do so from the YouTube app.
