How to Stream Android Phone Screen to OBS with Ease
The tool helps capture Android phone screen on OBS – Anymiro
  • Fast response time within 10 ms and 60fps frame rate.
  • A stunning visual experience with no color difference.
  • Lag-free screen mirroring and 4k resolution.
Available for both Win & Mac
Home Screen Mirror How to Stream Android Phone Screen to OBS with Ease
Discover how to stream Android to OBS effortlessly! Learn the methods, tools, and steps to do so and engage your audience like never before with your live streams.
Joy Taylor | Last Updated: Aug. 28, 2024
1837 words|6minute
Are you tired of keeping your mobile gaming victories confined to your smartphone screen? Do you wish to enjoy them on the big screen? Well, we’ve got an easy way to do it!
In this digital era, streaming is the best way to showcase gaming skills and connect with the audience. Whether you are a YouTuber or want to share your gameplay on Twitch or Discord, streaming is the best way. However, if you are wondering how to stream Android to OBS, Don’t worry! In this article, we will walk you through a step-by-step guide on how to stream Android phone screen using OBS. Let’s dive in!
Can I Use a Phone to Stream on OBS?
With the increase in popularity of mobile gaming, you must wonder if you can stream Android to OBS. Well, the good news is, yes, you can! Android phones have evolved to be versatile devices capable of handling various tasks. You can get high-quality video and audio from your phone directly to OBS.
Whether for gameplay streaming or other broadcasting, your mobile is the jack of all trades. It has everything you need, including a good camera, a high-speed processor, and a 4K resolution screen. So you don’t have to buy a webcam or other heavy equipment for streaming.
Here are the tools to help stream Android screens to OBS:
One popular approach is to use a screen mirroring app like AnyMiro. It allows you to display your Android phone on a big screen, and then integrate with a desktop streaming tool to provide users with a smooth streaming experience and audio/visual customization options.
You can also connect your phone to a capture card like Elgato HD60 S or AVerMedia Live Gamer Portable. These capture the gameplay footage for streaming directly in OBS.
For a wireless and streamlined approach, you can use OBS Ninja. It is a web-based tool that enables you to stream your mobile games to OBS without any setups.
Now that we know it is possible, let’s see how to do it.
How to Stream Android Screen to OBS
To stream your Android screen to OBS, you can use a screen mirroring app like AnyMiro. It mirrors your Android phone screen to the computer and then makes it possible to window capture the PC part of AnyMiro with OBS.
It offers a smooth streaming experience with high-quality audio/visuals. The good part is you don’t need to be a tech bee. All you need to do is, download the app and mirror your Android/iPhone screen to your PC. Then capture it as a source in OBS for your streaming needs. Streaming could never get this simple, right?
This part tells you how to capture an Android screen to OBS via USB. Let’s start by learning how to mirror the Android screen to the PC with a USB cable.
1. Mirror Android to Computer with AnyMiro
To capture your phone screen to OBS, you need to first mirror the screen to the computer. You can mirror your Android screen to your computer with AnyMiro. This method requires a USB cable. If you’re ready, keep reading and follow the guide:
Step 1. Download and install AnyMiro software on your computer.
Step 2. Launch the app and select Android as your mobile type.
Step 3. Select USB as a connection mode and connect your Android phone to your computer via a USB cable.
Select the USB Option for Screen Mirroring Android to PC
Step 4. Then, enable USB debugging and choose the MTP mode.
Enable USB Debugging and MTP Mode for a USB Connection
Step 5. Once your Android phone is connected successfully, you will see its screen mirrored on your PC.
Let’s explore why you should choose AnyMiro over any other mirroring app. Here are a few features that make AnyMiro the best choice:
Now that we know why AnyMiro is the best among other screen mirroring apps let’s explore how to set up OBS.
2. Set up OBS to Capture Android Screen
After the screen mirroring, you are supposed to set up OBS to stream Android. Here are the steps to do so:
Step 1. Download and install the OBS Studio on your computer.
Step 2. Launch the app, and click Tools > Auto-Configuration Wizard.
Opening Auto-Configuration Wizard
Step 3. Now select Optimize for streaming, the recording is secondary and click Next.
Optimize for streaming, recording is secondary
Step 4. Select the platform where you want to broadcast your game streaming.
Step 5. On OBS, click the + icon to add sources and then click Window Capture.
Open the Window Capture Option
Step 6. Give a name to your Window Capture screen and select the Android screen window. Once done, you are ready for live streaming.
Video Guide: Stream Android Screen to OBS via USB
Here is a video guide that shows you the whole process of how to use the screen mirror app – AnyMiro to stream an Android phone’s screen to OBS via USB.
How to Stream Android with Streamlabs OBS
There is one more way to stream your gameplay on YouTube and other platforms from Android. It is by using Streamlabs that allows you to stream directly to OBS without any computer or other tools. Therefore, all you need is a mobile video game and a live-streaming app installed to finish this method.
Here are the steps to directly stream Android to OBS with Streamlabs:
Step 1. Download the Streamlabs app for your Android device from the Play Store.
Step 2. Once installed, open the app and log in with any account you want to link with it.
Log into Streamlabs Account
Step 3. You will see two options on your Android screen. Select Stream your games and proceed.
Choose What to Stream
Step 4. You can also customize and add widgets to your live stream screen to enhance the experience.
Customize Stream Screen
Step 5. Once you are ready to broadcast, click the Go Live button. Then, choose the platform you want to broadcast to. Add the title and description of your stream.
Select the platform and start streaming
Bonus Tip: How to Stream Phone Screen to Computer?
Screen mirroring allows you to display your phone’s screen on your computer. It is an excellent way to stream your phone’s content to a larger audience. Whether you want to showcase your gaming skills or show an app, screen mirroring provides a convenient solution.
Here, we’ll explore both wired and wireless methods using AnyMiro for screen mirroring.
1. Wired method
This method enables you to mirror the Android screen to OBS or other desktop software via USB.
  1. Download and install the AnyMiro app on your computer.
  2. Launch the application and select Android on the screen.
  3. Now click the USB option.
  4. Connect your Android device to your computer via a USB cable.
  5. Enable USB debugging and choose the MTP mode. You will be ready!
2. Wireless method
  1. Now click the WiFi option after selecting Android on AnyMiro’s main screen.
  2. Scan the code from the screen and download the AnyMiro app on your Android device.
  3. Open the app on your Android device and select WiFi connection.
  4. Select the computer name you want to mirror by clicking Connect.
You can use the wireless method if you have a stable internet connection. It ensures a seamless screen-mirroring experience without needing any extra tools. Otherwise, you can try the wired method, which involves a USB cable to connect your Android to your computer.
AnyMiro – Real-Time Screen Mirroring Tool
  • More than 10 hours of stable screen mirroring connection.
  • Up to 4K resolution providing a stunning visual experience.
  • Integrates with live streaming tools such as OBS and Streamlabs.
  • Auto-sync video and background audio with timestamp adjustments.
100% Clean & Safe
100% Clean & Safe
Streaming your Android content to OBS has never been easier, thanks to tools like AnyMiro. Hopefully, after reading this article, you have learned to stream Android to OBS. Whether you choose a wired or wireless method, AnyMiro enables seamless screen mirroring. It allows you to captivate viewers on platforms like YouTube and Twitch.
Download AnyMiro today and take your gameplay streams to the next level by sharing your Android content on a larger scale. Start streaming and connecting with your audience like never before. Happy streaming!
Joy Taylor
