Share iPad screen on Mac with free and handy tool – AnyMiro
Available for both Win & Mac
Looking for easy ways to share your iPad screen on Mac? In this article, we have discussed 4 simple ways to share iPad screen on Mac, via USB, and wirelessly.
Imagine having to give a presentation you made on your iPad. Or you are inviting your friends over for a thrilling gaming session for a game that’s on your iPad. You can’t just let everyone huddle around your iPad; that would be awkward!
This calls for projecting your iPad screen on a bigger screen, like your MacBook!
The rising need for iPad screen sharing on Mac computers has become undeniable. Whether it is collaborating on a project or testing app functionality, the demand is soaring.
In this article, we have put together not one, not two, but FOUR incredible ways to share iPad screen on Mac.
So, let’s dive straight into it!
If you’re an Apple user, you must definitely be aware of AirPlay. It is a wireless technology by Apple that allows users to share the wonders of their iPad screen on Mac or Apple TV.
However, while AirPlay offers convenience, it does have some limitations to be aware of. For instance:
But if you’re looking for a quick way to share your iPad’s screen, you can always AirPlay iPad to Mac.
Steps to AirPlay iPad to Mac
Follow these steps to share iPad screen to Mac wirelessly using AirPlay:
Step 1. Open the Control Center on your iPad by swiping down from the upper-right corner, and tap the icon with two boxes to enable screen mirroring via AirPlay.
Screen iPad to Mac via AirPlay
Step 2. Select your MacBook from the list of available devices.
Select Mac from List to Share iPad Screen on Mac
However, as we mentioned earlier that AirPlay is not compatible with older iPhones, including iPhone 4s and earlier. Therefore, if you have an older iPhone model, you can use QuickTime to share iPad screen on Mac.
QuickTime is a multimedia framework and player crafted by Apple Inc. With its compatibility with various audio, video, and image formats, QuickTime has become a reliable favourite among both Mac and Windows users.
It is suitable for users looking to:
Steps to share iPad Screen on Mac QuickTime
Here are the easy steps to share iPad screen on Mac QuickTime:
Step 1. Connect your iPad to your MacBook using a USB cable.
Step 2. Launch QuickTime on your MacBook, and go to “New Movie Recording” from the File option at the top.
Select New Movie Recording to Mirror iPhone to Mac QuickTime
Step 3. Select your iPad from the list of available devices to share the iPad screen on the MacBook.
How to Mirror iPad to Mac Quicktime
Screen mirroring your iPad on your MacBook via QuickTime is a pretty old-school method and does not offer a smooth and stable mirroring experience compared to other apps.
Therefore, for a smooth and uninterrupted screen-mirroring session, we suggest trying out third-party apps.
This brings us to the following method…
If you’re tired of limitations and loopholes, you need an app that is compatible with all operating systems and supports flexible mirroring methods, an app like iMobie AnyMiro.
AnyMiro is a powerful screen mirroring app that allows you to share your iPad screen on Mac without limitations.
With this app, you can use both USB and WiFi to share iPad screen on Mac. This means that you can mirror your iPad even if you don’t have a WiFi connection available. Plus, it is compatible with Windows, Mac, iOS, and Android, giving you complete freedom to mirror your devices with each other.
Steps to Share iPad Screen on Mac using AnyMiro
To mirror your iPad screen on Mac via AnyMiro, here’s what you have to do:
Step 1. Download and launch AnyMiro on your MacBook, and select “Mirror iOS/iPadOS” from the interface.
Select Devices to Share iPad Screen on Mac
Step 2. Connect your iPhone to your MacBook using a lightning cable and select “USB” from the left menu bar.
Choose USB Connection to Share iPad Screen on Mac
Step 3. Once connected, you will receive a pop-up on your iPad whether you trust the computer. Select “Trust” to continue.
Tap Trust to Share iPad Screen on MacBook
This will instantly start casting your iPad screen on your Mac.
The upside of this method is that it does not rely on a Wi-Fi connection, and provides a smooth and uninterrupted screen mirroring experience for up to 10 hours! But that’s just one of the many reasons you should opt for AnyMiro!
Let’s look at some other reasons to choose AnyMiro.
Reasons to Choose AnyMiro
If you’re wondering why we are emphasizing so much on using AnyMiro to share iPad screens to Mac, here’s why:
However, there are several other third-party screen mirroring apps as well that serve as good alternatives to AnyMiro.
Reflector 4 is the ultimate screen-mirroring solution for seamless wireless mirroring from iPhone, iPad, or Android devices to your Windows or Mac PC.
However, the downside of using Reflector 4 is that you cannot operate your iPad through your MacBook while screen mirroring. Even though it is not a deal breaker, it can be pretty inconvenient.
Steps to Share iPad Screen on Mac via Reflector 4
Here are the steps to screen mirror your iPad to your MacBook:
Step 1. Download and launch Reflector 4 on your MacBook.
Step 2. Connect your iPad and MacBook to the same Wi-Fi network.
Step 3. Open the Control Center on your iPad, tap on the screen mirroring icon, and select your MacBook’s name from the list of available devices.
Stream iPhone Screen to PC with Reflector 4
Now that you know 4 different ways how to share iPad screen on Mac with and without wires, let’s clear some confusion by answering some frequently asked user queries.
1. How do I share my iPad screen with my computer?
You can share your iPad screen with your computer in several ways. This includes using the built-in AirPlay feature to mirror the screen wirelessly or using third-party apps that support wireless mirroring like AnyMiro or Reflector 4.
However, if you’re looking for a wired connection, you can share your screen using QuickTime or AnyMiro, as it supports USB mirroring as well.
2. How do I use my iPad as a second monitor?
You can use your iPad as a second monitor with the help of several tools including Apple’s built-in feature, SideCar. But as it works only on iOS devices, you can use AnyMiro to use your iPad as a second monitor for your Windows PC.
3. Is AirPlay the same as the Sidecar?
No, AirPlay and Sidecar are not the same. AirPlay is a wireless streaming technology that allows you to share audio, video, photos, and screens between Apple devices. Sidecar is a feature that lets you use your iPad as a second display for your Mac over a USB connection.
4. Can you screen share with AirPlay?
Yes, you can screen share with AirPlay. However, it is important to note that AirPlay only allows you to mirror your screen, not extend it. This means that whatever is on your iPad screen will also be displayed on your Mac screen.
In this article, we have discussed 4 different ways to share iPad screen on Mac, wirelessly and using a USB connection. And while all the methods mentioned are great in their way, AnyMiro tops the list with its wide range of features.
It supports wireless and wired screen mirroring and is compatible with all operating systems. Also, it offers 40 minutes of free screen mirroring every day.
So, if you want to unlock the true potential of iPhone screen mirroring on your MacBook without any restrictions and enjoy top-notch quality, give AnyMiro a try. Embrace the power of seamless mirroring with ultimate stability; it is time to take your tech game to new heights!
