Easy Guide For Beginners to Share Android Screen with PC
  • Fast response time within 10 ms and 60fps frame rate.
  • A stunning visual experience with no color difference.
  • Lag-free screen mirroring and 4k resolution.
  • Works well on both Windows and macOS.
Available for both Win & Mac
Home Screen Mirror Easy Guide For Beginners to Share Android Screen with PC
Discover three amazing tools to share Android screen with PC. Follow their step-by-step guides to enjoy games, movies, and other content on a bigger screen.
Joy Taylor | Last Updated: Aug. 21, 2024
2066 words|6minute
Are you curious about how to share Android screen with PC? Have you ever wished to view your phone’s content on a bigger screen? If yes, then you are in for a treat.
As well all know, screen mirroring has become a popular way to display phone content on PC or TV. It can be helpful in various ways. You can use screen mirroring for your presentations, game streams, or when showing your phone’s media to a group of people.
In this article, we are going to explore three different tools that help to screen mirror Android to PC. We will also make a comparison to let you pick the best one for you.
So, let’s get started!
Screen Share vs Screen Mirror: What’s The Difference?
When viewing your Android screen on a PC, you might come across the terms “Screen share” and “Screen mirror.” Although these phrases sound the same, they have different meanings. We need to understand both terms so you can decide what exactly you want.
Screen share:
The term “screen share” means sharing your PC or phone’s screen with other people. It allows others to see what’s happening on your device in real-time. It’s like giving someone a window into your device’s activities.
Screen sharing can be useful during group discussions and meetings. It can help you showcase apps, documents, etc., to others on a big screen.
What is Screen Sharing
Screen mirror:
On the other hand, the term “screen mirror Android to PC” means creating an exact copy of your Android screen on your PC. Whatever you do on your Android device will be shown on your PC.
Screen mirroring can be useful for gaming or watching media content on a bigger screen. It just enhances the experience of your digital activities.
What is Screen Mirroring
Let’s move toward the process to share Android screen with PC.
Share Android Screen with PC in Windows 10/11 – Try Wireless Display
Wireless Display, also known as Miracast, is the common method when it comes to screen share Android to PC. It is a built-in feature introduced in Windows 8, and since then, it has been a part of every new Windows OS.
With the Wireless Display feature in Windows 10/11, you can view your Android screen’s content on a PC. The best part is you don’t need cable or Software to do that. You can directly screen mirror Android to PC. Let’s see how!
Steps to Screen Mirror Android to PC using Wireless Display
Before starting, ensure that your PC supports Wireless Display, then follow the below instructions:
Step 1. Right-click the Windows Start button, then open Device Manager > Network Adapters. If you see Intel ® Dual Band Wireless-AC 3160, or something similar, your device supports Wireless Display.
Check Wireless Display Supported File on PC
Step 2. Turn on the Wi-Fi and Bluetooth on your PC.
Step 3. Press Windows + I to open Settings. Then, click System > Projecting to this PC. Enable the toggle as displayed in the below picture.
Enable Projecting on This PC
Step 4. In Windows Settings > Projecting to this PC menu. Click Launch the Wireless Display app to project to this PC.
Open Launch the Wireless Display App to Project to This PC to Mirror Android to Windows 11
Step 5. Open the drop-down menu on your Android and enable the Smart View or Cast Screen option. Select your PC and your phone screen will be displayed on your PC.
Use Android Built-in Feature to Screen Mirror
Enable Smart View to screen mirror Android
Limitations of Wireless Display
Although Wireless Display is convenient, it has limitations, which may include the following:
For some reason, if you cannot use Wireless Display, have a try on the next method.
Share Android Screen with PC via AnyMiro – Screen Mirror & Stream
If you are looking for a more convenient and reliable way, AnyMiro is the solution! It allows you to screen mirror Android to PC without any limitations. Whether you are a beginner or a pro, its easy-to-use interface lets you mirror your phone in a few steps.
Additionally, with AnyMiro, you can stream mobile games to PC. It offers better visuals and audio to enhance your gaming experience. You can easily integrate it with your streaming tools and enjoy gameplay on a bigger screen.
Here’s how you can screen mirror Android to PC using AnyMiro:
*With this method you need to download both the AnyMiro software and the mobile app.
Step 1. Download and install AnyMiro Software on your PC.
Step 2. Launch the app and select Android as your mobile type.
Mirror Android to Computer
Step 3. Now select USB as your connection mode. Then connect your Android phone to your PC via a USB cable. (You can also select WiFi if you have a stable connection)
Mirror Android to Computer via USB
Step 4. Enable USB debugging and select the MTP mode.
Enable USB Debugging and MTP Mode for a USB Connection
Step 5. Tab USB connection on AnyMiro app. Once your Android device is connected, you will see its screen displayed on your PC.
Select the Connection Method
Let’s explore what else AnyMiro has to offer you!
Key Features of AnyMiro
Here are some key features of AnyMiro that make it the best choice for screen mirroring:
Let’s see if there’s something else to cater to our screen mirroring needs!
Share Android Screen with PC – View and Control
Vysor is another powerful tool to share Android to PC. It not only mirrors your screen but also allows you to control it from your PC with its remote control feature. Now you don’t need a phone in your hands all the time; you can mirror your screen with Vysor and control it directly from your PC.
The best thing is it is also compatible with all OS like AnyMiro.
You can follow the instructions given below to screen share Android to PC using Vysor:
Step 1. Open Vysor’s official website on the browser. Then download and Install the Vysor app on your PC.
Step 2. Once the installation is completed, launch the applications on your PC. You will probably see the below interface.
Step 3. Connect your Android phone to your PC via a USB cable. Then follow the prompts on the phone to enable the USB debugging mode.
Click Connect USB Device in Vysor Extension
Step 4. Now, in the Vysor app on your PC, you will see a list of available devices. Select your Android device from the list.
Step 5. After selecting your device, a pop-up will appear. Select “Allow,” and you will see your Android phone screen displayed on your PC.
After a successful connection, locate and enable the “Remote Control” mode within the Vysor app. You can now interact with your Android phone using a mouse and keyboard.
You must be wondering what you should choose between all the above screen mirroring methods. Well, we are going to make it easy for you in the next step.
Let’s see how!
Wireless Display vs. AnyMiro vs. Vysor
We have explored Wireless Display, AnyMiro, and Vysor to share Android screen with PC. All three tools have their pros and cons.
However, you can walk through the below table to find out which tool best fits your needs. You can compare the features and accessibility to pick up the best one.
Features Wireless Display AnyMiro Vysor
Mode of connection Wireless and HDMI Wireless and USB cable Wireless and USB cable
Compatibility Android, Smart TV Windows, Mac, iOS, Android Android, iOS, and all OS (with limitations)
Ease of use Built-in feature with limited control options User-friendly with an easy setup process Moderate interface may require additional setup steps
Audio mirroring Varies by device Offer high-quality audio mirroring Support audio mirroring
Screen recording No No Built-in screen recording feature
Latency Varies Low-latency Varies
Cost Free (built-in) Free (Basic) and Premium Free (Basic) and Premium
As we can see, AnyMiro is the best option of all. It has everything one could ask for. It offers wireless mirroring, high-quality audio/visual, streaming platform integration, and more. So if you need a screen mirroring tool with a complete package, AnyMiro is for you.
FAQs on Android Screen Mirroring
Q. How do I share my Android screen?
You can effortlessly share your Android screen with PC using a third-party app like AnyMiro or Vysor. We have explained a step-by-step guide above to use these apps. You can walk through the instructions and enjoy your screen mirroring.
Q. How can I share my Android screen with my TV?
You can also screen mirror Android to TV using Chromecast or Miracast. Simply connect your TV and Android device to the same Wi-Fi network. Then use the “Cast” or “Screen Mirroring” option on your device to display content on the TV.
Final Thought
Hopefully, this article has been helpful for you to find a screen mirroring tool. Android screen sharing offers various ways to display your phone on a bigger screen. We explored three different tools with their step-by-step guide on how to use them. We also made a comparison table for better understanding.
However, AnyMiro is a top pick for its simple interface and useful features. It lets you share Android screen with a PC hassle-free. So, If you want a handy tool with amazing features and quality mirroring, go for AnyMiro.
AnyMiro – Real-Time Screen Mirroring Tool
Joy Taylor
