iPhone to PC/Mac screen mirroring tool – AnyMiro
Available for both Win & Mac
Learn how to fix iPhone screen mirroring not working issues using methods like updating devices, checking settings, and so on. A third-party screen mirroring app is recommended in this article.
AirPlay is a convenient screen mirroring tool that helps users share content and enjoy videos and photos on a bigger screen with friends and family.
However, sometimes screen mirroring doesn’t work as intended, which can be frustrating.
Don’t worry! In this article, we’ll cover some of the most common reasons why screen mirroring isn’t working and provide easy solutions to help you get back to enjoying your content on the big screen.
Let’s get started!
AirPlay is a proprietary wireless communication protocol stack developed by Apple Inc. that allows streaming between devices of audio, video, device screens, and photos, together with related metadata. If you encounter problems with the app, it may be caused by the following reasons:
Now we know the reasons why your AirPlay is not working. Let’s see how to fix iPhone screen mirroring not working in 5 efficient ways.
If your device is incompatible with AirPlay, the iPhone screen mirroring feature may not be working. Apple has published a list of compatible Airplay devices, you can check if your device is on the list:
Devices You Can Stream Audio From Using AirPlay
Devices You Can Stream Video From Using AirPlay
You should connect your two devices to the same Wi-Fi network to screen mirror successfully. If one of the devices is connected to Ethernet or mobile data, it should be changed to the W-iFi Network.
On iOS, you can go to Settings > Wi-Fi and view the current network name.
iOS WiFi Setting
On macOS, you may click the Wi-Fi icon in the menu bar to see the name of the network being used.
macOS WiFi Setting
On, you can view the current network in the Settings > Network menu.
Apple TV WiFi Setting
To ensure that your AirPlay devices are running the latest software, it’s important to check for updates. Here are some ways to do so:
For iOS devices, go to Settings > General > Software Update to check for updates on your iPhone or iPad.
On macOS, go to System Preferences > Software Update to check for updates on your Mac.
On HomePod, open its settings in the Home app for iOS/iPadOS and select Software Update.
On tvOS, go to Settings > System > Software Update.
The poor and unstable Internet connection is another possible reason for the screen mirroring not working issue. To troubleshoot this issue, start by checking your Internet connection. You can do this by restarting your Wi-Fi router. If the network is working properly but you are still having issues, move on to the next solution.
Due to the privacy statements of the new iPhones, you can’t just share or transfer files using AirPlay at the instance. The privacy feature could be the center of the issue of screen mirroring not working on iPhone. To fix this, you will need to change a few settings on your iPhone. You may go to the settings > navigate to Screen Time > turn off the Screen Time.
How to Turn Off Screen Time on iPhone/iPad
If you’re looking for a simple and easy way to mirror your iPhone screen, we recommend using AnyMiro.
AnyMiro is a screen mirroring app that enables screen mirroring iPhone to PC using a USB and wirelessly. We have put this wonderful tool on our recommendation list for the following reasons:
Now let’s see how to mirror iPhone to PC Using AnyMiro.
Mirror iPhone to PC via USB
Step 1. Download and run AnyMiro on your computer.
Step 2. Select mirror iPhone/iPad to enter iPhone mirroring.
Mirror iPhone to Computer
Step 3. Connect your iPhone to your PC with a lightning cable.
Mirror iOS Device to Computer via USB
Step 4. Tap “Trust” on your iPhone, and wait a few seconds, you can see the iPhone screen on the computer.
Trust Your Computer on iPhone
Mirror iPhone to PC Wirelessly
Step 2. Go to iPhone/iPad mirror section.
Step 3. Switch to the WiFi connection part. Connect your iPhone and PC to the same WiFi.
Step 4. Follow the on-screen steps, select your PC from the list, and start mirroring your iPhone.
1. How can I activate screen mirroring?
Open Settings > Tap Display > Cast Screen > Tap the checkbox for Enable wireless display to enable it.
2. How do I screen mirror without AirPlay?
We recommend downloading AnyMiro app to stream your iPhone to PC without Apple TV or AirPlay. AnyMiro is a useful screen mirroring app supporting mirroring your phone screen to your PC with a USB cable or the same WiFi network. It’s simple and easy to use.
3. Why won’t my iPhone let me AirPlay to my TV?
You should first make sure that your AirPlay-compatible devices are turned on and near each other. Check that the devices are updated to the latest software and are on the same Wi-Fi network. Then restart the devices that you want to use with AirPlay or screen mirroring.
AirPlay is a powerful tool that lets you quickly and easily mirror your device. You can cast video, audio, or pictures from your iPhone screen. However, some issues may arise when using AirPlay, especially when you’re trying to connect to an incompatible device. In this article, we have discussed in detail how to fix screen mirroring not working on iPhone issues. You may solve the problems in the ways mentioned in the article, or use another screen mirroring app AnyMiro.
