Home Screen Mirror Screen Mirroring Motorola to PC
This guide explores different ways to screen mirror your Motorola to a PC, including AnyMiro, Motorola’s Screen Share, and HDMI. We’ll compare these screen mirroring Motorola methods regarding compatibility, connection method, and cost. Whether you need it for work or entertainment, we recommend using AnyMiro – a reliable screen mirroring tool – for the best and smoothest experience!
Joy Taylor | Last Updated: Oct. 12, 2024
1367 words|4minute
One excellent option to share your phone’s screen for presentations, gaming, or just watching videos on a larger screen is to screen mirror your Motorola phone to a PC. It enables you to view or project everything happening on your phone’s screen to a larger computer screen. This article will walk you through the simplest methods of connecting your Motorola phone to your PC while at home or work. You have a few options: use the built-in screen-sharing capability on Motorola, connect via HDMI, or use third-party programs. So, let’s begin to explore this screen-mirroring Motorola guide!
Screen Mirroring Motorola to PC via AnyMiro
AnyMiro is an exceptional screen mirroring tool for connecting your Motorola to a PC, offering an effortless and stable experience. You can enjoy up to 10 hours of smooth streaming, which is very suitable for gaming, presentations, or other creative sessions. It also has high-resolution mirroring of up to 4K, ensuring that every detail on your phone is sharp and viewed.
Additionally, AnyMiro provides real-time audiovisual sync, so your game audio and visuals are perfectly aligned during live streams. Whether you’re streaming on platforms like Twitch, YouTube, or Facebook, AnyMiro ensures a seamless experience, with features like live annotations and screenshot capabilities to enhance interactivity and capture important moments.
Key Features:
Here are the steps for screen mirroring Motorola to PC via AnyMiro using two methods:
Screen Mirroring Motorola to PC via USB
Step 1. Before starting, free download and install AnyMiro on your computer.
Step 2. Once the installation is complete, open AnyMiro on your PC.
Step 3. Select the “Android” option to connect your Motorola device.
Mirror Android to Computer
Step 4. Click on the “USB” icon, then connect your phone to the computer using a USB cable.
Select the USB Option for Screen Mirroring Android to PC
Step 5. Enable “USB debugging” on your phone and select “MTP Mode” when prompted after connecting.
Enable USB Debugging and MTP Mode for a USB Connection
Step 6. Once your device is connected, the screen will appear on your computer, and your Motorola phone is mirrored successfully!
Note: If your device isn’t recognized, try troubleshooting by checking the USB cable and settings.
Screen Mirroring Motorola to PC Via WiFi:
Step 1. Begin by installing AnyMiro on your computer.
Step 2. Once installation is complete, open AnyMiroon on your computer.
Step 3. Select the “Android” option.
Step 4. Then click on the “Wi-Fi” icon to connect your phone using Wi-Fi.
Mirror Android to Computer via WiFi
Step 5. On your phone, go to Google Play, search for AnyMiro, or scan the QR code to download the app.
Download AnyMiro App on Your Phone
Step 6. Open the AnyMiro App on your phone and select “Wi-Fi Connection.” Now, select your computer from the list. Your phone’s screen will then successfully mirror to the computer.
Tap WiFi Connection
Tap WiFi Connection
How to use Motorola Phone from PC via Screen Share
Using your Motorola phone from your PC is easy with the “Ready For” feature. By extending the capabilities of your smartphone, you can now operate it directly from your computer screen via this cutting-edge solution. With a simple wrist flick, you can use your phone as a motion-sensing remote control for instant tasks. With the home and back buttons, you can easily explore your apps and files on a larger screen. All in all, this seamless connectivity option lets you multitask more effectively for work or play. To use this method:
Setting up Ready For Assistant for Screen Sharing
Step 1. On your PC, visit apps.microsoft.com and download the Ready For Assistant app. For this, begin by searching “Ready For Assistant” by Lenovo.
Step 2. Your phone and PC must have a similar Wi-Fi network or connect them with a USB cable.
Step 3. Access the Ready For Assistant application on your PC.
Open Ready for App
Open Ready for App
Step 4. On your phone, swipe to find the Ready For quick tile or go to Settings > Connected devices > Ready For.
Go to Connected Devices
Step 5. Tap “Add” and follow the instructions to scan the QR code on your PC screen.
Using Ready For:
Step 1. Access the Ready For application on your phone.
Step 2. Tap on “Screen Share.”
Step 3. Choose “Mirror Phone” to show your phone’s screen on the PC or select “Virtual Phone” to control your phone from the PC. You can switch between these options whenever you like.
Step 4. Tap “Start Screen Share” to begin.
Screen Mirror Motorola to PC via HDMI
An excellent method to improve your viewing experience is to use HDMI to mirror your Motorola phone to a PC. You may effortlessly share your phone’s screen on a bigger screen with the correct configuration. This is ideal for delivering presentations, playing games, and viewing videos. By selecting this option, you may be guaranteed a steady connection and uninterrupted performance. It also offers excellent graphics that highlight every detail. For this method:
Step 1. Connect your phone to an external display using a USB-C to HDMI or VGA cable.
Step 2. If prompted, select “Get started.” Swipe right to proceed.
Select Get Started
Select Get Started
Step 3. Tap “OK” to confirm. Your Motorola phone is now successfully connected via HDMI.
Step 4. Return to the Start screen on your phone.
Return To The Start Screen
Comparison of These Methods
AnyMiro Ready For HDMI Cable
Compatibility Works with Android, iPhone, Windows, and Mac Exclusive to Motorola phones with Ready For Compatible with most Motorola phones and external monitors/TVs
Connection Method Connects via Wi-Fi or USB cable Connects via Wi-Fi or USB cable Connects using USB-C to HDMI/VGA cable
Price (Year) Free; $3.00/month Free (Built-in feature for Motorola devices) Varies depending on the brand, length, and type
FAQs on Screen Mirroring Motorola Phone
Can I mirror my Motorola phone to my PC wirelessly?
Yes, you can mirror your Motorola phone to a PC using Wi-Fi. Both Motorola’s Ready For and third-party apps like AnyMiro support wireless connections. Ensure your phone and PC are on the same network for seamless mirroring.
Is screen mirroring lag-free?
Screen mirroring quality depends on the connection method. Wired connections, such as HDMI, typically offer minimal lag. Wireless methods like Wi-Fi might experience slight delays, but reliable tools like AnyMiro ensure stable, lag-free mirroring, especially for gaming or streaming.
Can I control my Motorola phone from my PC during screen mirroring?
Yes, you can interact with your phone’s screen directly from your PC using Motorola’s Ready For feature. This includes controlling apps and games and navigating your phone’s interface using your mouse and keyboard for a more convenient experience.
Final Words
In conclusion, screen mirroring your Motorola phone to a PC is straightforward. Each method has its benefits, depending on your needs. However, for a simple and high-quality solution, we recommend AnyMiro. It provides 4K quality mirroring, no time limits, and works with multiple devices.
Joy Taylor
