Try AnyMiro to mirror Huawei Phones to Computers for free via USB and WiFi.
This guide describes how to use AnyMiro, MirrorShare, Wireless Projection, and Chromecast, among other methods, to share the screen of your Huawei phone with a PC or TV. Each screen mirroring Huawei method is explained with easy steps, allowing you to connect your phone to a larger display.
It’s practical to share the screen of your Huawei phone with a PC or TV when playing games, watching movies, or even showcasing presentations on a bigger screen. Modern technologies allow people to wirelessly sync their phones with other devices.
Some of the greatest choices for screen mirroring are provided here in this Huawei screen mirroring guide. You will learn how to link it to a PC using programs like AnyMiro and Mirror Share. It can even be seen on a TV using wireless projection or a gadget like Chromecast.
Thus, let’s get started!
You can have a seamless experience when screen mirroring your Huawei phone to your PC using AnyMiro, the premier tool for stable, smooth, and lag-free streaming. AnyMiro offers up to 10 hours of lag-free mobile game streaming and guarantees a crystal-clear 4K resolution display with no color difference, whether you’re gaming, producing art, or giving presentations. Smooth sound and visual synchronization in real-time make it excellent for live broadcasting.
Additionally, you can easily stream your Huawei screen to OBS Studio and other tools with no quality loss. For streamers, the ability to capture or record highlights during streaming is a game-changer, while the live annotation feature allows for interactive presentations that engage your audience.
Key Features:
Here are the steps to screen mirror your Huawei to PC via AnyMiro:
Step 1. Free download and install AnyMiro on your computer, ensuring a stable internet connection.
Step 2. Launch AnyMiro on your PC once the installation is complete.
Step 3. Select the “Android” option within AnyMiro to connect your Huawei device.
Mirror Android to Computer
Step 4. Tap the “WiFi” icon to connect your Huawei phone via WiFi.
Mirror Android to Computer via WiFi
Step 5. Download the AnyMiro app on your Huawei by searching it on Google Play or scanning the QR code.
Step 6. Open the AnyMiro app on your phone and choose “WiFi Connection” from the home screen. Select your computer name from the list of available devices to begin mirroring. Once connected, your Huawei screen will successfully mirror your PC.
Tap WiFi Connection
MirrorShare is an inbuilt feature in most modern Huawei phones that makes mirroring your screen to a PC simple. MirrorShare can be found at the bottom of your Huawei phone’s notification bar once you swipe it down. Its operation requires your phone and PC to be connected to the same WiFi network.
With MirrorShare, you can easily mirror your phone’s screen without a cable while showcasing slides, movies, or images. It is a convenient and efficient way of making an enlarged screen on your phone without requiring other software or wires. For this method:
Step 1. Open the “Settings” app on your Huawei phone and tap “Device connection.” Alternatively, you can swipe down the notification bar. Tap on “MirrorShare” and wait for available devices to appear.
Note: Make sure your WiFi is turned on from the notification bar.
Tap MirrorShare
Step 2. Select your TV or PC from the list of available devices.
Step 3. Your TV or PC will ask for permission to mirror your Huawei screen. Allow access to start mirroring.
Some Huawei phone models enable you to display what is on your device’s screen on a monitor without using any cables through wireless projection. Wireless projection is a more developed concept than MirrorShare. It can include features like the execution of the applications on the phone while projecting the screen on the PC. Models running EMUI 9.0 support this feature, making it ideal for screen mirroring Huawei P30 and other devices. It’s perfect for presentations or sharing content seamlessly. To use this method:
Step 1. Go to “Settings” on your Windows PC and click “System“.
Step 2. Select “Projecting to this PC” and click “Optional features“. Then, choose “Add a feature.”
Step 3. Search for “Wireless Display” and install it.
Search Wireless Display
Step 4. On your Huawei, pull down the status bar, turn on WiFi, and enable “Wireless Projection.”
Wireless Projection
Step 5. Your phone will automatically search for devices. Once your PC appears, tap on it to connect.
Chromecast allows streaming videos and casting all the content from your mobile phone to your TV. You can stream apps and games, photos, and more directly to your television. The screen mirroring Huawei to the TV using Chromecast gives you peace of mind with a seamless experience and a wonderful way to see all of your content on a much larger screen with minimal setup. To screen mirror using this approach:
Step 1. Insert your Chromecast device into your TV’s HDMI port. Download the Chromecast app from the Play Store on your Huawei phone.
Step 2. Your phone and Chromecast must have the same WiFi network.
Step 3. Open the Chromecast app and let it search for nearby devices.
Step 5. From the list, select your Chromecast and connect to it. Once connected, your Huawei screen will be mirrored to the TV successfully.
Can I mirror my Huawei phone to my PC without cables?
You can mirror your Huawei phone wirelessly using MirrorShare or Wireless Projection. Both options let you connect your phone to your PC without any cables.
Why is my Huawei screen mirroring lagging?
Screen mirroring may lag if your WiFi connection is unstable or your device is slow. To reduce lag, ensure both devices are connected to a strong network.
Can I mirror my Huawei to a PC using a third-party app?
Yes, you can use third-party apps like AnyMiro for reliable mirroring. It provides a stable connection, making the experience smooth and easy with minimal interruptions.
Lastly, screen mirroring technology allows individuals to access a bigger screen for work, playing video games, and much more on PCs or TVs. Depending on which one you prefer, Using MirrorShare, Wireless Projection, or Chromecast provides many benefits. We recommend using AnyMiro, which guarantees stable connections and no interruptions in mirroring, thus ensuring a smoother experience while casting your screen.
