5 Best Screen Mirroring App for Android: Everything You Need to Know
Check the list of the Android screen mirroring apps and try AnyMiro
  • Fast response time within 10 ms and 60fps frame rate.
  • A stunning visual experience with no color difference.
  • Lag-free screen mirroring and 4k resolution.
Available for both Win & Mac
Home Screen Mirror Screen Mirroring App for Android: Everything You Need to Know
Discover the best screen mirroring app for Android. Learn what factors to consider while choosing an app. Also, compare five different apps to choose the best.
Joy Taylor | Last Updated: Aug. 28, 2024
2456 words|8minute
Are you tired of squinting at your Android phone screen? Do you want to share your favorite content from your Android phone on a bigger display? If yes, then you are at the right place.
We all know that screen mirroring has become a popular way to display the phone’s content on a bigger screen. While there are various methods available, some users are still on the hunt to find the best screen mirroring app for Android.
If you are one of them, then don’t worry! In this article, you are going to explore everything you need to know about the free screen mirroring app for Android to find the best one.
Let’s get started!
Why Need A Screen Mirroring App for Android?
In today’s world, our smartphones play an important role in our lives. We use them for work, entertainment, and communication. But have you ever thought of sharing your Android phone screen with a larger audience?
Well, this is where screen mirroring apps come in use. Most of the Android phones come with a built-in screen mirroring feature. However, there are many reasons to use a third-party screen mirroring app for Android.
An Example of Screen Mirroring Android to PC
Reasons to Use A Screen Mirroring App for Android
The benefits of using a third-party screen mirroring app are as follows:
These were the benefits of using a screen mirroring app for Android. Now, let’s find out how to choose the best app.
5 Best Screen Mirroring Apps for Android
With many screen mirroring apps for Android available in the market, it might be challenging to find the best one. That’s why we’ve done the work for you. Here are the five best Android mirroring apps that every user should know.
1. AnyMiro
One name immediately pops out when talking about screen mirroring Android apps. It’s “AnyMiro” that was developed by iMobie. It is known as one of the most convenient and reliable apps when it comes to screen mirroring.
AnyMiro offers a smooth mirroring experience with high-quality audio/visuals. It supports a wide range of both iOS and Android devices and seamlessly mirrors them to PC and Mac. The best part? It’s done with superb clarity and with greater stability.
Mobile Screen Mirrored on the Computer with AnyMiro
Let’s shed some light on the pros and cons of AnyMiro app.
Pros:
Here are the pros of the AnyMiro app:
Cons:
Here are the cons of the AnyMiro app:
Specs Information:
The supported devices and prices of the AnyMiro app are as follows:
Windows Windows 7, 8, 10, 11 (64bit & 32bit).
Mac macOS 10.13 (High Sierra) and above.
iOS/iPad iOS 11 and later/iPad 13 and later.
Android   Android 5 and later.
Prices $15.99/month, $19.99/quarter, 29.99/year.
Why Recommended as Per Author:
“I recently had the opportunity to try the AnyMiro app, and I was very impressed. It was easy to use and performed stably during my testing. If you are looking for a screen mirroring app for Android, AnyMiro is a great option. It has all the features you need and more”.
2. AirDroid Cast
Another app that fulfills screen mirroring needs is AirDroid Cast. It has a remote control option and is designed to enhance the connectivity between Android and PC. It supports various Android devices and offers many features. AirDroid Cast sets a standard for one of the best screen mirroring apps for Android.
AirDroid Cast Screen Mirroring
Let’s have a look at the pros and cons of AirDroid Cast app:
Pros:
The pros of the AirDroid Cast app are as follows:
Cons:
The Cons of the AirDroid Cast app are as follows:
Specs Information:
The supported devices and prices of the AirDroid Cast are as follows:
Windows Windows 7 and above/ For remote control feature: Windows 10 and above.
Mac macOS 10.11 and higher, 500MB and above free space.
iOS iOS 11 or higher.
Android Android 5.0 or higher.
Web Safari, Chrome, Microsoft Edge, and Yandex.
Prices (Remote Casting) $2.49/month, 19.99/year.
Prices (Cast and Control) $3.49/month, 29.99/year.
“I like the user interface of the AirDroid Cast app. It is easy to use, even for people with no technical expertise. However, I have experienced some connection issues when using the app. If you do not have enough space on your device to download the app, you can use its web version. Overall, I would recommend the AirDroid Cast app, but I suggest exploring other options as well”.
3. Scrcpy
Scrcpy, also known as Screen Copy, is a free and open-source screen mirroring app for Android. It allows you to mirror and control your Android device from your PC using an ADB connection over USB. Rooting your device is not required.
Scrcpy claims to have very low latency. This means there is little to no delay between your phone and computer. Therefore, it is a good option for gamers and other users who need a responsive screen mirroring experience.
Scrcpy Android Screen Mirror
Let’s shed some light on the pros and cons of the Scrcpy app.
Pros:
Here are the pros of the Scrcpy app:
Cons:
Here are the cons of the Scrcpy app:
Specs Information:
The supported devices and prices of the Scrcpy app are as follows:
Windows Windows 7, 8, and 10.
Mac macOS 10.12 and above.
Linux Ubuntu, Fedora, Debian, and more.
iOS/iPad Not Compatible
Android Android 5 and above.
Prices Free
“Scrcpy is a screen mirroring app for Android that’s both a blessing and a curse. On the one hand, it’s free, open-source, and has very low latency. On the other hand, it requires a USB connection and has limited wireless support. And whether or not it works perfectly with your Android device is a toss-up. So, before you decide if Scrcpy is right for you, weigh the good, the bad, and the ugly”.
4. ApowerMirror
ApowerMirror is the screen mirroring app that’s got it all. Along with many features, it uses mainstream mirroring technology to bring your Android screen to life. It supports mirroring with both audio and video. Moreover, its user-friendly interface makes it a breeze to use. Whether you’re looking to interact, entertain, or get productive, you can choose ApowerMirror!
ApowerMirror Interface
ApowerMirror
Let’s have a look at the pros and cons of the ApowerMirror app:
Pros:
The pros of the ApowerMirror app are as follows:
Cons:
The cons of the ApowerMirror app are as follows:
Specs Information:
The supported devices and prices of the ApowerMirror app are as follows:
Mac macOS 10.13 and above.
iOS/iPad iOS 11 and above/iPad 13 and above.
Prices   $29.9/month, $69.9/year, 199.9/lifetime.
“I have had the opportunity to explore ApoweMirror. I must say it comes with its set of strengths and weaknesses. Though it offers multiple useful features, I didn’t find its interface attractive. Also, I had connectivity issues in the beginning. Plus, the paid version is too pricey. However, using ApowerMirror may depend on your needs and preferences”.
5. DouWan
DouWan is also a screen mirroring app to mirror your Android phone to your computer. You can easily stream your favorite content, which may include movies, TV shows, games, and apps, from your phone to your big screen.
It’s also great for casting your phone’s screen to a projector for business or educational purposes. DouWan is compatible with a wide range of devices. It’s also easy to use, even if you’re not tech-savvy.
Android Screen Mirroring DouWan
Let’s shed some light on the pros and cons of the DouWan app:
Pros:
The pros of the DouWan app are as follows:
Cons:
The cons of the DouWan app are as follows:
Specs Information:
The supported devices and prices of the DouWan app are as follows:
Windows Windows 7, and later.
iOS/iPad iOS 9 to iOS 17.
Android Android 5 – 14
Prices   Starting from $9.99.
“I recommend DouWan for screen mirroring because it’s the easiest way to get my content onto the big screen. No fuss, no muss, just plug and play. Whether I’m streaming videos, playing games, or giving presentations, DouWan makes it a breeze”.
Comparison Chart of Android Screen Mirroring Apps
Features AnyMiro AirDroid Cast Scrcpy ApowerMirror DouWan
Supported Devices Windows, Mac, iOS, and Android Windows, Mac, iOS, and Android Windows, Mac, Linux, and Android. Windows, Mac, iOS, and Android Windows, Mac, iOS, and Android
Casting Methods USB and Wireless USB and Wireless USB and Wireless USB and Wireless USB and Wireless
Resolution Up to 4k Up to 1080p Varies by the target device Up to 1080p Varies by the target device
Pricing/Month $15.99/month $3.49/month Free $29.9/month $9.99/month
How Do We Choose the Best Android Screen Mirroring App?
It’s important to select the ideal screen mirroring app for an enhanced experience. However, there are various factors that you should consider while choosing a screen mirroring app. The key factors are as follows:
Now that we know what factors to consider while choosing a screen mirroring app, let’s explore the options.
There are various Android mirroring apps in the market. But choosing the right one can be tough. Hopefully, this article has helped you understand what features make a good mirroring app. We have explored the top five screen mirroring Android apps. Each of them offers unique features to fit different needs. However, AnyMiro stands out with its amazing features, cross-platform compatibility, and user-friendly interface.
So, download AnyMiro now to enhance your mirroring experience!
Joy Taylor
